How can you tell the difference between MDF and Pressboard? I have a guy says he's selling pressboard and I asked him and he said it was MDF. It's a good price but I don't know how to tell the difference.
Particle board or presswood
Wiki says:
Particleboard is cheaper, denser and more uniform than conventional wood and plywood and is substituted for them when appearance and strength are less important than cost. However, particleboard can be made more attractive by painting or the use of wood veneers that are glued onto surfaces that will be visible. Though it is denser than conventional wood, it is the lightest and weakest type of fiberboard, except for insulation board. Medium-density fibreboard and hardboard, also called high-density fiberboard, are stronger and denser than particleboard. Different grades of particleboard have different densities, with higher density connoting greater strength and greater resistance to failure of screw fasteners.
A major disadvantage of particleboard is that it is very prone to expansion and discoloration due to moisture, particularly when it is not covered with paint or another sealer. Therefore, it is rarely used outdoors or places that have high levels of moisture, with the exception of some bathrooms, kitchens and laundries, where it is commonly used as an underlayment beneath a continuous sheet of vinyl flooring. It does, however, have some advantages when it comes to constructing the cabinet box and shelves. For example, it is well suited for attaching cabinet door hinges to the sides of frameless cabinets. Plywood has the potential to feather off in sheaves when extreme weight is placed on the hinges. In contrast, particle board holds the screws in place under similar weight.[1] Additionally, particleboard is favored for cabinet shelves that need to span a long width (30"or more) since it will not bow under the weight like plywood.
[edit]History and development
Thanks that pic helps a lot from the small image I have seen of it it looks like MDF
Here is an image I have
Thanks IBCivic I read that but it doesn't help me visually tell the difference
that picture looks like sub flooring..which is not MDF, but the sheets show some difference that might mean some could be MDF...but the front pieces do not appear to be MDF.
anything coated with white...is melamine....and that is for sure particle board.
The front sheet is OSB. I did notice a couple coated sheets but the rest looked like MDF. I figure at 5 bucks a sheet it's worth a drive
i can't imagine why there would be MDF on a job site...but whatever it is its worth $5 bucks a sheet
Good Luck!!
It's mainly used for custom cabinets since it's easier on saw blades.
Also the guy referring to the MDF as Pressboard isn't completely wrong since MDF is a type of pressed wood product.
I could easily see an oldschool guy referring to MDF as pressboard since many of the older gentlemen at the wood supply house back in 1991ish I used to buy my MDF from didn't make much distinction between MDF and particleboard.
They were used to working with real wood so to them it was all garbage.....it was only the more knowledgable guys that knew exactly what it was.
While the composition of MDF is different to that of OSB and partcleboard they are all pressed products.
Mdf is like taking fine sawdust, mixing with glue and pressing into dense panels. Particle is like taking coarse sawdust or even chips and glue pressed together. It is flaky and brittle. The vibrations will break up the material.
2012 toyota 4runner, Alpine 920hd hu
Audible psychics NZ3, Dayton 225 fronts, Focal polyglass rear, Massive bit nano amps, Focal sub
As is plywood - all wood panel products are formed and pressed in the manufacturing process. (it's a really BIG press...)
John
Well yes except if it's void free ply they're thin wood veneers while the MDF and other wood composites have anything from fine wood dust(MDF) to small chips of wood(particle board) to rather large pieces of wood(OSB).
