Mounting custom center console - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-03-2013   #1
Rep Power: 102 brianhj will become famous soon enoughbrianhj will become famous soon enoughbrianhj will become famous soon enoughbrianhj will become famous soon enoughbrianhj will become famous soon enoughbrianhj will become famous soon enough
Default Mounting custom center console
I never see any details on how these heavy mdf custom center consoles are actually mounted securely to the car.. Any advice? I want it to be clean, not in plain view and hopefully not having to cut carpet outside of stock console area..
brianhj is offline   Reply With Quote Quick reply to this message
Old 04-03-2013   #2
Aaron'z 2.5RS/WRX's Avatar
Rep Power: 286 Aaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond repute
L brackets on the inside..
Sent from an other planet (Tapatalk)
Aaron'z 2.5RS/WRX is offline   Reply With Quote Quick reply to this message
Old 04-03-2013   #3
xtremekustomz's Avatar
Rep Power: 131 xtremekustomz will become famous soon enoughxtremekustomz will become famous soon enoughxtremekustomz will become famous soon enoughxtremekustomz will become famous soon enoughxtremekustomz will become famous soon enoughxtremekustomz will become famous soon enough
Default Re: Mounting custom center console
Honestly? Most people don't secure them which makes them a projectile in a crash. I've made a removable panel on the top that I can get to the bottom and secure it that way. I've also used wing anchor bolts or regular bolts secured to the console and hanging out of the bottom. I then drilled holes through the floorboard and secured the console with washers and nuts under the vehicle. Another way mentioned above is with L brackets. Secure to the under side of the console and run through a small slit in the carpet. Pull the carpet back and secure to the floor.
You could always build your console out of this stuff:
How to build a custom center console - YouTube
xtremekustomz is offline   Reply With Quote Quick reply to this message
Old 04-03-2013   #4
Rep Power: 0 xXTX_ChallengerXx will become famous soon enoughxXTX_ChallengerXx will become famous soon enoughxXTX_ChallengerXx will become famous soon enoughxXTX_ChallengerXx will become famous soon enoughxXTX_ChallengerXx will become famous soon enoughxXTX_ChallengerXx will become famous soon enough
^^^ thanks for sharing. Good info
xXTX_ChallengerXx is offline   Reply With Quote Quick reply to this message
Old 04-04-2013   #5
Rep Power: 118 designerfh will become famous soon enoughdesignerfh will become famous soon enoughdesignerfh will become famous soon enoughdesignerfh will become famous soon enoughdesignerfh will become famous soon enoughdesignerfh will become famous soon enough
When I built the console for my Silverado, I just used this:
Shop The Hillman Group Plated Slotted Flat at Lowes.com
I bolted the straps to the enclosure, and then the straps went to the stock mounting point for what was the center seat. Worked nice.
designerfh is offline   Reply With Quote Quick reply to this message
Old 04-11-2013   #6
Rep Power: 114 scdean will become famous soon enoughscdean will become famous soon enoughscdean will become famous soon enoughscdean will become famous soon enoughscdean will become famous soon enoughscdean will become famous soon enough
Can you cut slots in the carpet and run metal strap (16-18Gauge) to seat bolts?
scdean is offline   Reply With Quote Quick reply to this message
