Pod construction - alternative to fiberglass perhaps?s? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 6 Days Ago   #1
ARCuhTEK's Avatar
Rep Power: 117 ARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enough
Default Pod construction - alternative to fiberglass perhaps?
I just saw this video from an installer in Australia who used Selleys Knead It, a putty/epoxy product that I thought worked pretty easily for his tweeter pod project. I thought this could either serve as the actual pod or even as a base that you could then fiberglass over (not sure if that would work or not).
Either way, the most impressive part was how well it stuck to his sail panel and held the tweeter cup until he could position it.
https://www.youtube.com/watch?v=FmIUBagX05I
Note, Selleys is an Australian product, so I am not sure if you can get it in the USA, but when I did a Google search and alternative product came up: Locktite Repair Epoxy. Not sure if it is the same, but the details look similar.
https://www.amazon.com/Loctite-19991.../dp/B000BOB8P6
Anyway, not everyone has glassing skills and I thought I would just put this in the technical file...
ARCuhTEK is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #2
Babs's Avatar
Scott
Rep Power: 180 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
Default Re: Pod construction - alternative to fiberglass perhaps?
Cool! Yeah anything that works is fair game. Should try body filler though. It's actually not bad. It just stinks. Typically for that kind of project you'd CA glue the rings, then fleece it with CA glue, fill with filler, sand then finish.
2008 Civic Si Sedan - Sony RSX-GS9, Helix DSP Pro-2 & Director, JL Audio XD1000/5v2 (2), Audiofrog GB10/GB25/GB60, Acoustic Elegance SBP12 (2)
Build Log
Babs is online now   Reply With Quote Quick reply to this message
Old 6 Days Ago   #3
ARCuhTEK's Avatar
Default Re: Pod construction - alternative to fiberglass perhaps?s?
Funny you mention smell....the aussie complained about the smell of that stuff too. Epoxy does stink...
Old 6 Days Ago   #4
Rep Power: 76 SPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura aboutSPLEclipse has a spectacular aura about
For those in the US, you can buy moldable epoxy at Walmart. It's in the home plumbing/electrical department near the toilet repair kits and dryer vents.
Originally Posted by Orion525iT View Post
Beyond the technical aspects, there are things with which only the individual can find value, regardless of outcome. There are some things to which the process has more value than the end result .
SPLEclipse is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #5
Theslaking's Avatar
DIYMA member
Rep Power: 61 Theslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enough
That seems to be just like Quick Steel. I use it all the time. Didn't even consider it for tweeter pods.
The best way to dummy proof is to get rid of the dummies
Theslaking is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #6
Rep Power: 103 AccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished road
The alternative to Resin is using ABS or Expanded PVC to build it using CA glue and then filler. Less messy and can be done in a few hours if you use the right filler..
But this is just another tool in the toolbox..
Jose -02 VW Passat Wagon
Beyma Speakers - Soundigital Amps - TwK88 - Nexus 7
AccordUno is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #7
Rep Power: 141 AAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enough
I've used paper mashe... mix of water and flour and use shredded news paper strips. For smallish it's surprisingly solid. Still need some kind of finish on top to seal it so moisture doesn't get to it...but at least you can do that outside the car so it doesn't stink up the vehicle. It's also easy to sand and cheep to make.
