How to design rings to accomodate a custom grill - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-06-2008   #1
Ge0
Ge0's Avatar
Rep Power: 137 Ge0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enough
Default How to design rings to accomodate a custom grill
I am in the process of making small custom kicks to accomodate a pair of Scanspeak 12m midranges. I want the ring to be barely larger than the Speaker AND I want to recess mount them and place a custom grill over them to protect them.
I've seen a few examples of people wrapping ABS plastic around a MDF ring to recess the driver and make cleareance for a grill.
I get the concept but fail to see how you would "fill in" the area outside where the Speaker recesses into. Does Bondo / fiberglass resin stick to abs plastic?
What are some alternatives to using abs? I was thinking MDF but fear the difference between I.D. and O.D. of the material would be too small.
Anyone with a useful link to demonstrate this please step in...
Ge0
Ge0 is offline   Reply With Quote Quick reply to this message
Old 07-06-2008   #2
SQ4ME2's Avatar
Rep Power: 121 SQ4ME2 will become famous soon enoughSQ4ME2 will become famous soon enoughSQ4ME2 will become famous soon enoughSQ4ME2 will become famous soon enoughSQ4ME2 will become famous soon enoughSQ4ME2 will become famous soon enough
Default Re: How to design rings to accomodate a custom grill
bondo sticks to textured abs as long as the bondo is mixed well. abs to fiberglass, thats different. i have done it in the past by drilling holes in the abs to allow a sandwich effect of the resin going through the holes and acting like nails. also if you use a staple gun to staple the fiber mat to the abs, but that has only worked on one occasion for me
SQ4ME2 is offline   Reply With Quote Quick reply to this message
Old 07-06-2008   #3
Ge0
Ge0's Avatar
Ok, this is along the lines of the advice I am looking for. Thanks. So abs is not much different than other grades of plastic such as Poly Pro, TPO, etc... Alternates to abs for this purpose?
Is it feasible to machine an MDF ring with 1/8" difference between I.D. and O.D.? Using a circular cutting tool that attached to a drill press to cut these rings. They are small enough for the job. The smallest ring I have made out of MDF sofar is 1/4" difference between I.D. and O.D. Seems pretty sturdy until I drill holes in it.
Ge0
Old 07-06-2008   #4
GlasSman's Avatar
Rep Power: 165 GlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enough
1/8" is too thin for MDF.
I've accidently cut it into thin strip on my table saw just shaving a large piece that I then attempted to wrap around a baffle to get this effect...but it breaks.
---Custom fabricated speaker baffles and templates---
GlasSman is offline   Reply With Quote Quick reply to this message
Old 07-06-2008   #5
GlasSman's Avatar
The original technique that you're reffering to was introduced by N.A.M.E. which had a fabrication video series in the mid 90's.
They had this stuff called water proof panel board which is a 1/8" sheet of cardboard that has a water proof coating on it.
It's actually too thick and tends to wrinkle when wrapping a smaller radius..around 5" or smaller.
I found what works best are the For Sale or Beware Of Dog signs.
Very thin, wet proof, and don't wrinkle when in tight radiuses.
Use a bead of super glue to seal the area where it meets the baffle.
Old 07-06-2008   #6
SQ4ME2's Avatar
glassman is on a better track. also hit up your local plastics shop. they usually carry plexi and thin plastics as well as resin. DON'T use lexan though
Old 07-06-2008   #7
GlasSman's Avatar
I found ABS too brittle and can crack and split when bending into tight radiuses.
I forgot to mention I double or triple up on the For Sale sign plastic.
Cutting it into straight strips can be tricky.
If you have a paper cutter/guiloteen(sic) that would be PERFECT!
Old 07-06-2008   #8
Rep Power: 116 rockondon will become famous soon enoughrockondon will become famous soon enoughrockondon will become famous soon enoughrockondon will become famous soon enoughrockondon will become famous soon enoughrockondon will become famous soon enough
More cool ideas.
Geo ,I just finished mine. But i ended up doing a Speaker mounting ring. With another larger ring layered on top. To create the recess.
This is all grafted on to my factory [ABS] kick.
rockondon is offline   Reply With Quote Quick reply to this message
Old 07-06-2008   #9
customtronic's Avatar
Rep Power: 125 customtronic will become famous soon enoughcustomtronic will become famous soon enoughcustomtronic will become famous soon enoughcustomtronic will become famous soon enoughcustomtronic will become famous soon enoughcustomtronic will become famous soon enough
The "For Sale" sign is a great idea. Never thought of it before. Alot of you guys are throwing good idea out there. I made my first set of kick pods with what I learned from the N.A.M.E. videos back in about '92 or so. I just built on that knowledge.
Build in Progress!
1989 IROC-Z|Bottlehead HU|Helix DSP|HAT SE Front|HAT C15 Sub|Old School Zapco AG amps
Support the Special Operations Warrior Foundation at http://specialops.org/
"College scholarships for the surviving children of fallen Special Operations Forces"
customtronic is online now   Reply With Quote Quick reply to this message
Old 07-06-2008   #10
Ge0
Ge0's Avatar
Ok everyone.
I like glassman's "beware of dog" sign idea. However, I'm still failing to see how you blend this in to make it look like a finished product.
How do you treat the O.D. surface? I understand the I.D. part where the Speaker actually fits into. It's just the O.D. I have problems with. If nothing sticks to plastic how do you glue cloth to it / apply filler to it to blend in the lip?
BTW: a picture is worth a thousand words.
Thanks so much for the help so far. Sorry for the delayed response, but, its my birthday weekend after all!!!
Ge0
Old 07-09-2008   #11
Ge0
Ge0's Avatar
I'm too impatient and did not wait around for answers regarding the "beware of dog" strategy. Summer is half over and I have a lot more fabrication work to do before cold weather sets in.
So, here is what I decided to do but have hit a temporary road block:
Cut 1" strips of abs plastic. Started my wrap with a screw to hold it to the ring:
Slowly apply heat and bend. Heat and bend. Heat and bend. Oh shit, burned my finger! Secure the wrap to the ring with small brad nails spaced about every 2" apart:
Done heating and bending:
Secured the opposite end of the wrap to the ring using a second screw to hold it securely:
Question now. I've successfully bent the abs and have wrapped it around the mdf rings. Now, how to permanently hold it in place? More screws, adhesive? I'll probably use some silicon to seal off the seam between the two if using screws. However, if there is a decent adhesive out there that will hold to abs tight I could secure and seal in one step.
Opinions?
Ge0
Old 07-09-2008   #12
Swampperman's Avatar
Rep Power: 0 Swampperman will become famous soon enoughSwampperman will become famous soon enoughSwampperman will become famous soon enoughSwampperman will become famous soon enoughSwampperman will become famous soon enoughSwampperman will become famous soon enough
You could take a soldering gun with the right tip and melt the seam together and it should stay together.
Swampperman is offline   Reply With Quote Quick reply to this message
Old 07-09-2008   #13
Ge0
Ge0's Avatar
Yep, that would work. But, I was able to do that with the heat gun to very satisfactory results. The seam between the ends was not my primary concern though. I'm more interested in ideas behind securing the plastic ring to the mdf. What have others done? I could simply add more wood screws, but is this necessarily the best means?
Ge0
Old 07-09-2008   #14
A good epoxy would probably bond them.
Old 07-10-2008   #15
Ge0
Ge0's Avatar
My concern with epoxy is its bond to ABS plastic over time. If the bond weakens and cracks away, the pod may rattle or hum. Thus the reason I'm being so damn anal about this subject. I'm mounting a $600 pair of midranges in it. I want them to perform their best!
Perhaps with the assistance of wood screws to help preserve the bond this would not be an issue?
Ge0
Old 07-10-2008   #16
2167's Avatar
Rep Power: 115 2167 will become famous soon enough2167 will become famous soon enough2167 will become famous soon enough2167 will become famous soon enough2167 will become famous soon enough2167 will become famous soon enough
What about adding a mikshake (using resin & filler w/ short hair fiberglass) inside, after stretching fabric and glassing, that would bond the fabric,speaker ring & plastic edging
"Have a Positive Day"
2167 is offline   Reply With Quote Quick reply to this message
Old 07-10-2008   #17
96dak's Avatar
Rep Power: 113 96dak will become famous soon enough96dak will become famous soon enough96dak will become famous soon enough96dak will become famous soon enough96dak will become famous soon enough96dak will become famous soon enough
fiberglass will not stick to the abs.
just do what glassman said in one of his posts, run a small bead of ca glue (superglue) on the inside seam where the abs meets the mdf and you will be fine (ca glue sticks quite well to both abs and mdf)
DEH-P800prs , JL 300/4 and 500/1, JL XR comps active, 4 JL 12w1's in cut through.
96dak is offline   Reply With Quote Quick reply to this message
Old 07-10-2008   #18
Ge0
Ge0's Avatar
I read glassmans comment but was just a tad bit skeptical. I figured the MDF would just soak up the glue. Maybe not!!!
Thanks,
Ge0
Old 07-10-2008   #19
Ge0
Ge0's Avatar
I will be doing this with the interior seam between the resined t-shirt cloth and the abs standoff. That should beef up this region enough.
Ge0
Old 07-10-2008   #20
shinjohn's Avatar
Rep Power: 144 shinjohn will become famous soon enoughshinjohn will become famous soon enoughshinjohn will become famous soon enoughshinjohn will become famous soon enoughshinjohn will become famous soon enoughshinjohn will become famous soon enough
I get that with the plastic, you can make a tall, thin, lip, but was wondering why you didn't just cut the lip as a recess directly out of MDF. A little more router work, but it would remain a single piece. If thickness is a concern, stack two layers of MDF together and glue them...
I hope to start building some kicks for the very same midrange drivers in my vehicle and that was what I was planning to do...
shinjohn is offline   Reply With Quote Quick reply to this message
Old 07-10-2008   #21
Wouldn't the piece be to brittle at that thickness?
Old 07-11-2008   #22
Ge0
Ge0's Avatar
Hey SJ,
Ditching the Horns in favor of a 3-way stage?
Your recommendation is exactly what I originally wanted to do. If the whole thing was mdf I would have ZERO issues with resin or adhesives sticking to it. Adding plastic complicated things.
I cut these rings with a circle cutter that bolts onto a drill press, not a router. Up until a few days ago I did not have a small router (wife bought me one for my birthday). However, I still could not use the brand new router since I don't have a Jasper jig thingamabobby (my wife bought the wrong one). I need to find time to get to the store and exchange it
I could have cut two different rings and glued them together using the circle cutter. However, the top ring, the one that forms the lip, would only be 1/8" thick. Numerous people mentioned it would be nearly impossible to pull this off without the mdf cracking apart so I did not waste the time trying it.
Good luck with your project. Let us know how its going.
Ge0
Old 07-11-2008   #23
Rep Power: 160 Mless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enough
Originally Posted by Ge0 View Post
Hey SJ,
Ge0
I've been thinking about making the top ring out of some sort of plastic/acrylic. Than doing the grill from the same thickness and material + grill cloth.
Old 07-11-2008   #24
96dak's Avatar
just make sure that when you wrap that with cloth that you run a bead of ca glue around where the t-shirt touches the abs. just glue it from the outside after wrapping it
Old 07-11-2008   #25
Ge0
Ge0's Avatar
Thanks!!! I hadn't thought of that.
Ge0
FREE 12" 1.11cube sealed box custom design mobeious Car Audio Classifieds 5 01-19-2011 10:23 AM
Adire...out of business? Exalted512 Technical & Advanced Car Audio Discussion 91 07-04-2007 12:56 PM
WTB Custom MDF Rings RMAT Car Audio Classifieds 7 04-23-2007 07:23 PM
Full Custom System in a 2003 Corvette C5 by JML Audio jmlaudio Build Logs & Project Install Gallery 6 04-05-2007 06:21 PM
Would protecting the voice coil with grill cloth affect design intent t3sn4f2 Technical & Advanced Car Audio Discussion 6 02-24-2007 05:12 PM
