Old 08-06-2008   #1
... Squirrel!!!...
Rep Power: 418 bikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond repute
Default Sandwiching door skins with mdf.
Since installing my new mids I'm having a lot of rattles in my doors and it's very much attributed to the extremely thin sheet metal that my driver/ring are mounted to. So, to remedy this, I'm going to try sandwiching in my door skin using a sheet of mdf on the inner portion of the skin. The plan is to use 1/4" mdf, cut a template out to the shape of the sheet metal on the inner side and beef up the skin using this. I'm not completely sure I can get another sheet of 1/4" on the outer portion of that skin, but I'm going to try that, too. Then I will have essentially increased the thickness of that portion of the panel by 500% if I can get 2 sheets of mdf, and even 300% if only one sheet. I'm really hoping this will just about kill any chance of flex/rattles in the door alone. In a nutshell, I'm making the "baffle" as thick as I would a small subbox in about a 2sq foot area.
Has anyone else done this on their panels, and if so, did it help as much as I’m thinking it will?
The large contributing factor for doing this is that I need to do my best to stop all flex at the point of the driver. If I can do this, then the need to seal the access hole up with something very sturdy will have diminished greatly, and thus I can *hopefully* get away with simply laying deadener over the hole and not have to use wood or something equally as thick. I’m trying my best to avoid adding thickness in the access hole area because my door panel won’t fit back on my doors due to the odd shape of the door skin itself.
If all goes well, I'll start on this tonight or tomorrow and try my best to get pictures of the process. I'm hoping this will work. In theory it's all good, but who knows what'll happen in actuality.
Follow my blog:
http://medleysmusings.com/
Cool site with subwoofer testing:
Data-bass.com
Old 08-06-2008   #2
Inferno333's Avatar
Rep Power: 94 Inferno333 will become famous soon enoughInferno333 will become famous soon enoughInferno333 will become famous soon enoughInferno333 will become famous soon enoughInferno333 will become famous soon enoughInferno333 will become famous soon enough
Default Re: Sandwiching door skins with mdf.
I'm looking forward to the pics!
Inferno333 is offline   Reply With Quote
Old 08-06-2008   #3
... Squirrel!!!...
My big question is how well will the wood 'fit' to the skin, though. I know it's not perfectly flat, so it may cause issues. I also wonder if it's worth the trouble to put clay on the portions that touch the sheet metal; I think not. Likely just going to deaden and put some sort of foam over them. I'll have to use overkill on the inside, but I won't have enough to do 2 sheets per door, so I'll have ot use some other sort of foam for the outer portions. Wal-Mart, here I come.
Follow my blog:
Data-bass.com
Old 08-06-2008   #4
Rep Power: 0 Whiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enough
I covered the surface area/volume between the metal and .75 inch MDF with liquid nails type construction material. This provided some adhesion, provided some rattle prevention, and provided some additional mass.
Whiterabbit is offline   Reply With Quote
Old 08-06-2008   #5
... Squirrel!!!...
^ Do you think it was worth the effort? Honestly, it seems like it would really work well, but it's still nice to get opinions before I go through the trouble.
I'm looking at bolting the 2 sheets of mdf together using a typical nut/bolt assembly and sandwiching the skin b/t the 2 sheets. IF I can get 2 sheets on there.
Follow my blog:
Data-bass.com
Old 08-06-2008   #6
Mooble's Avatar
Rep Power: 141 Mooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond reputeMooble has a reputation beyond repute
STOP!!!!
Don't use MDF, especially in the doors! No matter how well you seal it, the doors get very wet. The water will find a way in somehow-both into the door and into the MDF. I can picture the MDF swelling in your doors right now and torquing them all to hell. I can even see your door not closing properly or your windows not sealing. I would REALLY VERY STRONGLY recommend something else. Glass them up and see how that works, but don't use MDF. I've seen MDF that I left outside swell up 2x or even 3x its normal size.
Pioneer 880PRS, Tru SSLD6, Morel Supremo Piccolo, Hertz ML 1600, Morel 12" Ultimo, Tru Copper C7.4, Clarion DPX11551
Mooble is offline   Reply With Quote
Old 08-06-2008   #7
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
Sales and Customer Service
Rep Power: 126 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
Have you thought about using cutting boards/HDP instead of MDF? It can be had really cheap at a Big Lots/Tuesday Morning type of place. Then weather wouldn't be a concern. Just some food for thought bro.
Zach
Old 08-06-2008   #8
Ge0
Ge0's Avatar
Rep Power: 93 Ge0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enoughGe0 will become famous soon enough
Originally Posted by Mooble View Post
STOP!!!!
That was going to be my contribution to this thread. But, you beat me to it.
Ge0
Ge0 is offline   Reply With Quote
Old 08-06-2008   #9
Aaron'z 2.5RS/WRX's Avatar
Cutting boards man... cutting boards...
Old 08-06-2008   #10
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
Listen to the guy with the orange roll cage, he speaks the truth!! Except for the difference between pink and Cherry Hill red. ROFL!!
Come to think of it, I think that you can get the cutting boards for cheaper than you can buy MDF. And you won't have to deal with the god awful dust that MDF throws when it's being cut. It's a win/win situation.
Old 08-06-2008   #11
Rep Power: 284 azngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond repute
i would use sheet metal or aluminum flashing to cover up your door holes, then deadening on top of that...thats what i did in the Celica with the addition of Vertex Barrier Pad. The doors were DEAD and no rattles...too bad the car is totalled
azngotskills is offline   Reply With Quote
Old 08-06-2008   #12
chuyler1's Avatar
Rep Power: 105 chuyler1 will become famous soon enoughchuyler1 will become famous soon enoughchuyler1 will become famous soon enoughchuyler1 will become famous soon enoughchuyler1 will become famous soon enoughchuyler1 will become famous soon enough
Yeah, that aint gonna work out so hot unless you cover the MDF completely with paint or fiberglass to seal it.
PPI DCX-730 / DLS A5+A8 / TBI TWEP51 / DLS Iridium 6 / DLS OA12 / Work Log
chuyler1 is offline   Reply With Quote
Old 08-06-2008   #13
... Squirrel!!!...
I actually already have 2 15"x20" cutting boards at home I was going to use for this a very long time ago. Thanks for the reminders, lol!
Follow my blog:
Data-bass.com
Old 08-06-2008   #14
... Squirrel!!!...
The original plan (before remembering I have some cutting boards from last November) was to deaden the mdf.
Some of you guys who swear up and down that it'll get wet?... I had cardboard in my doors for 2.5 YEARS... and just removed that... not wet at all; not falling apart, nada, zilch. The only thing I had ever done was covered it in deadener.
Follow my blog:
Data-bass.com
Old 08-06-2008   #15
Rep Power: 102 HondAudio will become famous soon enoughHondAudio will become famous soon enoughHondAudio will become famous soon enoughHondAudio will become famous soon enoughHondAudio will become famous soon enoughHondAudio will become famous soon enoughHondAudio will become famous soon enough
Are you trying to make your doors weigh 100 pounds each??
HondAudio is online now   Reply With Quote
Old 08-06-2008   #16
... Squirrel!!!...
could be. ; )
Follow my blog:
Data-bass.com
Old 08-06-2008   #17
Rep Power: 81 capnxtreme will become famous soon enoughcapnxtreme will become famous soon enoughcapnxtreme will become famous soon enoughcapnxtreme will become famous soon enoughcapnxtreme will become famous soon enoughcapnxtreme will become famous soon enough
Considering that deadener is waterproof, I'm gonna go out on a limb here and suggest that maybe, covering the cardboard in deadener is what made it waterproof. Seems silly to not provide full details of your original plan, and then criticize the (unanimous) suggestions. Cardboard doesn't swell like MDF will, either, so that was a much safer experiment. Good luck with the project.
capnxtreme is offline   Reply With Quote
Old 08-06-2008   #18
... Squirrel!!!...
That was the point... I kind of thought you guys would know that I would put deadener over the mdf. The post you just quoted (and somehow misconstrued my reply for criticism) was to point out that I had deadener over the cardboard and things worked out well for that... but, see, I didn't explicitly say I was putting deadener over the MDF. Assume = ass (out of) u (and) me
Now, before this thread turns into a typical OT thread... let's get back on track. I'll use deadener/mdf or the cutting board I have. Don't know yet. Likely a mix of the two since the cutting board sheets are about $10/each and I already have tons of 1/4" mdf.
Follow my blog:
Data-bass.com
Old 08-06-2008   #19
GlasSman's Avatar
Rep Power: 119 GlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enough
If you want to go cheap as possible use the 1/4" MDF and make a template of the hole you want cut the middle out and glass the middle....that way it's not heavy....no worries about water damage...and any weird contours of the door skin will be easliy overcome.
You also aren't restricted to a flat one dimensional panel.
My first choice would be the cutting board.
GlasSman is offline   Reply With Quote
Old 08-06-2008   #20
Mooble's Avatar
I still really strongly caution against MDF. It doesn't even take flowing water to make it swell. Even high humidity can do it. I've seen it with my own eyes. I can envision your MDF panel expanding and warping your door panel with it. You probably could use enough sealant on MDF to make it watertight, but after all that work, you'll kick yourself for not using plastic or glass.
Old 08-06-2008   #21
... Squirrel!!!...
alright, alright!
Plastic it is. What sucks is that I can't seem to cut the cutting board I bought with a jigsaw; using different blades and going slow doesn't seem to make a difference.
Follow my blog:
Data-bass.com
Old 08-06-2008   #22
Ge0
Ge0's Avatar
I have untreated MDF braces inside my door between outer and inner skins to stiffen the door structure up. They are dry as a bone and have not swelled. Now, my MDF rings for the midbasses are sealed with thick layers of clear coat paint. I removed my door panel the other day just to check things out. They swelled up at the bottom! Looks Like I'll need to go with my original plan of Corian to re-construct them.
Ge0
Old 08-06-2008   #23
Rep Power: 0 bretti_kivi will become famous soon enoughbretti_kivi will become famous soon enoughbretti_kivi will become famous soon enoughbretti_kivi will become famous soon enoughbretti_kivi will become famous soon enoughbretti_kivi will become famous soon enough
... why not just brace with aluminum "L" or "T" and glass that in place?
bretti_kivi is offline   Reply With Quote
Old 08-07-2008   #24
Rep Power: 109 Luke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant future
Why not use thin lead flashing sheet, fairly cheap depending on where you get it, but also has great acoustic properties, and it will curve to some degree to any odd shapes your door panels may have.
Gradually learning to do more and more with less and less until I can do everything with nothing.
Standard operating procedure.. like blowjobs in porn.
Luke352 is offline   Reply With Quote
Old 08-07-2008   #25
... Squirrel!!!...
not sure if that would add enough mass... and that's the name of the game here.
Follow my blog:
Data-bass.com
How do you seal MDF to do a lacquer finish? Mooble Fabrication, Tools & Tricks of the trade 9 07-05-2009 11:36 PM
attaching MDF spacers to door EEB Fabrication, Tools & Tricks of the trade 6 07-22-2008 07:11 PM
Bending Mdf getonerd Fabrication, Tools & Tricks of the trade 10 06-22-2008 09:39 AM
MDF question/complaint MattinTheCrown Technical & Advanced Car Audio Discussion 40 01-23-2007 02:53 PM
Steps in building Box, MDF and F-glass. demon2091tb Technical & Advanced Car Audio Discussion 8 08-23-2005 08:36 AM
