Method to prevent epoxy from sticking to a surface when molding? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-05-2008   #1
braves6117's Avatar
Rep Power: 125 braves6117 will become famous soon enoughbraves6117 will become famous soon enoughbraves6117 will become famous soon enoughbraves6117 will become famous soon enoughbraves6117 will become famous soon enoughbraves6117 will become famous soon enough
Default Method to prevent epoxy from sticking to a surface when molding?
How do you prevent the epoxy from sticking to a surface once it dries? I heard something about aluminum foil?
Thanks
Audison/Usher/Morel/Dyn/IDQ
braves6117 is offline   Reply With Quote Quick reply to this message
Old 10-05-2008   #2
Rep Power: 123 johnny52 will become famous soon enoughjohnny52 will become famous soon enoughjohnny52 will become famous soon enoughjohnny52 will become famous soon enoughjohnny52 will become famous soon enoughjohnny52 will become famous soon enough
Default Re: Method to prevent epoxy from sticking to a surface when molding?
I use Partall #10 film release agent
http://www.rexco-usa.com/part2.htm
Apply at least 6 to 8 coats of it on the surface with a brush. It dry fast.
Incredible product.
johnny52 is offline   Reply With Quote Quick reply to this message
Old 10-10-2008   #3
Rep Power: 0 tcandey will become famous soon enoughtcandey will become famous soon enoughtcandey will become famous soon enoughtcandey will become famous soon enoughtcandey will become famous soon enoughtcandey will become famous soon enough
Thanks
Aluminum foil will work, but it will be stuck to the epoxy..... If you're trying to make a mold, best thing I've found is to use several coats of johnsons paste wax. 6-8 coats, buffing off excess between each and after last one.
this will ensure that there are no visable defects in the surface coat left by the release agent. You can use Part-all or pva as it's genericaly known as a barrier. PVA is generally used only as a last little bit of insurance that the parts don't stick and also as protection measure for the tools. Best results come from spraying it in one or 2 very fine mist coats after the part has ben suitably waxed. Brushing on multiple coats will work but it will also leave lots of brush texture in the surface of the mold which you probably want to avoid.
hth
todd
tcandey is offline   Reply With Quote Quick reply to this message
