Do you put Sound deadener inside Fiberglass Sub box? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-15-2010   #1
Rep Power: 92 cobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enough
Default Do you put Sound deadener inside Fiberglass Sub box?
I have a roll of sound deadener( Fatmat 80mils) and was wondering if I should put 1 layer inside my FG sub box or it wont do anything?
Thanks!
cobraa is offline   Reply With Quote Quick reply to this message
Old 01-15-2010   #2
Do work
M.E.C.P certified
Rep Power: 106 tinctorus will become famous soon enoughtinctorus will become famous soon enoughtinctorus will become famous soon enoughtinctorus will become famous soon enoughtinctorus will become famous soon enoughtinctorus will become famous soon enough
Send a message via AIM to tinctorus
Default Re: Do you put Sound deadener inside Fiberglass Sub box?
I wouldnt I would fill it with resin to seal it up and if it is a sealed box possibly stuff it with polyfill, That is if you need the polyfill.
On my box I built for the corner of my srt I had to Build it a bit undersized in order to get it to fit how I wanted it to so I stuffed about 3 pounds of polyfill in there to make up for some of the space I needed
It wont "hurt" anything to fill it with deadener but I think you could make better use of it in other places
tinctorus is offline   Reply With Quote Quick reply to this message
Old 01-17-2010   #3
glidn's Avatar
VW OEM retrofit
IT Technician / Installer
Rep Power: 126 glidn will become famous soon enoughglidn will become famous soon enoughglidn will become famous soon enoughglidn will become famous soon enoughglidn will become famous soon enoughglidn will become famous soon enough
Send a message via MSN to glidn
I started sound deadening my sub boxes around 15 months ago. Now no longer need stuffing in box and also completely seals box, So two methods of making sure box is sealed.
I noticed my 8" sub play alot lower with sound deadened fibreglass box, than fibreglass box with SD. Just make sure SD has no reflective surface, If it does, Run a couple of pads of Dynazorb behind the sub driver.
glidn is offline   Reply With Quote Quick reply to this message
Old 01-17-2010   #4
Rep Power: 90 danielp will become famous soon enoughdanielp will become famous soon enoughdanielp will become famous soon enoughdanielp will become famous soon enoughdanielp will become famous soon enoughdanielp will become famous soon enough
If you used Resin to seal the box then there is no need to use the deadener.
Rather use it some where else.
I have seen SPL guys using deadener inside their enclosures but i doubt it makes that much of a difference. If the box is sealed with resin, how much more do you want to seal it?
danielp is offline   Reply With Quote Quick reply to this message
Old 01-18-2010   #5
glidn's Avatar
VW OEM retrofit
It's not so much as sealing the box, as it's killing or absorbing some of the rebound sound waves playing against the box back at the sub.
It's the main reason I do it. Again I have also found it seems to have a cleaner deeper sound. Which is all good.
Old 01-18-2010   #6
I understand. Good bracing is Key then..
Old 01-23-2010   #7
GlasSman's Avatar
Rep Power: 167 GlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enough
Brace the box properly....if you need to use resin to seal the box you're using the wrong material.
And if you had to seal it up for some reason Titebond II or III would be vastly superior to a brittle, 2 part, toxic resin....on many levels.
---Custom fabricated speaker baffles and templates---
GlasSman is offline   Reply With Quote Quick reply to this message
Old 01-25-2010   #8
AutoDesign NYC
lead fabricator
Rep Power: 90 petermakar will become famous soon enoughpetermakar will become famous soon enoughpetermakar will become famous soon enoughpetermakar will become famous soon enoughpetermakar will become famous soon enoughpetermakar will become famous soon enough
not neccessary. but wouldnt hurt....
petermakar is offline   Reply With Quote Quick reply to this message
Old 02-07-2010   #9
Rep Power: 101 fallbrookchris will become famous soon enoughfallbrookchris will become famous soon enoughfallbrookchris will become famous soon enoughfallbrookchris will become famous soon enoughfallbrookchris will become famous soon enoughfallbrookchris will become famous soon enough
I have never used SD mats in Speaker boxes but I have used sound absorbing mats in my HT speakers and subs, I have bought the good stuff from parts express and use carpenters backing (the grey with different color threads in it) as well
I generally seal my FG boxes with FB resin by pouring it in the finished box and moving the box around so it is completely coated, if I "feel" like I need it I then add some SA tiles (egg crate looking stuff) especially in subwoofer boxes, or another type of closed cell foam in boxes with diagonal walls to "catch" the back wave of from the Speaker and in other area's in the box as well, I can't really see any benefit to adding SD to the inside of a heavy, well built FG box that has solid strong thick walls, if the box doesn't sound solid when you give it the fist/tap test it isn't strong enough and you have to add a few more layers
fallbrookchris is offline   Reply With Quote Quick reply to this message
Old 02-08-2010   #10
don_chuwish's Avatar
Rep Power: 95 don_chuwish will become famous soon enoughdon_chuwish will become famous soon enoughdon_chuwish will become famous soon enoughdon_chuwish will become famous soon enoughdon_chuwish will become famous soon enoughdon_chuwish will become famous soon enough
Anyone besides Whitledge tried this stuff? http://cascadeaudio.com/car_noise_control/vb_fd.htm
- D
2007 Toyota Prius pkg #2
Road Noise Abatement, Audio Upgrades
don_chuwish is offline   Reply With Quote Quick reply to this message
Old 02-08-2010   #11
fourthmeal's Avatar
DIYMA Been here long time
Rep Power: 914 fourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond repute
Anybody still use the "milkshake" technique of coating the box's insides? That's what I do. Part kitty-hair or short-stranded goo, part Resin. Mix it up, pour it in, and move the box around so all of it is coated.
2017 Colorado just starting
Old 02-09-2010   #12
nineball's Avatar
Rep Power: 146 nineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the rough
i understand the concept but i always thought it was a waste. for example we will say you are making a corner box. the only part that would possibly need "sealing" on the inside would be the seam, not the entire box, so why waste product? unless you laid the glass wrong (and that is a problem unto itself) there should be no possible chance of air escaping anywhere other than the seam. i like using a small amount of duraglass on the inside seam.
Freedom of speech includes the freedom to offend people. - Brad Thor
nineball is offline   Reply With Quote Quick reply to this message
Old 02-09-2010   #13
fourthmeal's Avatar
I think it is just to create a more solid layer, and fill in pin-holes.
I suck at FG though. Probably because I lack the patience needed for it.
Old 02-09-2010   #14
nineball's Avatar
if you have holes on the inside after laying 5-9 layers of glass on the outside you have bigger worries fg is easy but you do have to take your time.
Old 02-09-2010   #15
Rep Power: 109 RBeachTL will become famous soon enoughRBeachTL will become famous soon enoughRBeachTL will become famous soon enoughRBeachTL will become famous soon enoughRBeachTL will become famous soon enoughRBeachTL will become famous soon enough
I used CLD on the inside of my fiberglass enclosure. The enclosure is covered with carpet but still had structural resonance. I would use the rap test and I could definitely hear the structure ring. When I added the CLD the enclosure is now pretty dead.
RBeachTL is offline   Reply With Quote Quick reply to this message
