Really appreciate the experimenting if you do manage to compare the two scenarios. All this information and personal responses you give are above and beyond of what I have experienced in the past in terms of customer service. Cheers Jim!
2003 GMC Sierra 5.3l RCSB - Type R Components
2 Type R 10's
Phoenix Gold Amps
Hey Jim....I think I am picking up one (for now) on Sunday (my only day off for a LONG time I have a center console tuned to 34 and is aprox. 1.3cuft already with a boston g5 10. Do you think that a pair of the 8s will prosper in this setup? It would be great because I can add a new 2x 8" baffle to go over the single ten...(its all downfiring so as long as it doesnt interfere with the bolts its an EASY swap out I will do a test box/boxes as a .65ish ported and a .4 sealed sample as well......If its worth while and I have the power available....and I want to build a whole new box I can do 3 sealed (two down firing and one rear) I have a boston gt2200 on tap for subpower right now...900x1 at 2ohm. I presume this would be great for the pair..... Or I can do a GT2125 per sub giving about 650 each? I am a little leary doing two subs ported in a shared area with two different (but the same) amps?
Whats your take on my situation....I am really excited to beat the piss out of these for a while
Jim I have a quick question. I read that you used these in a camaro as midbass. Care to elaborate on how they performed in that role? Also are there any plans to create a shallow version specifically for midbass/ door mount? And rexroadj how does these compare to the jblgto?
Pioneer premier prs800, peerless 830986, 2 spg555 subs. About to prove a point with low budget amps...no forum boner wither...
1.3@34Hz is great for a pair. Looking forward to the results in there.
I think your sealed box is a tad large, but may give you a little more extension. Have a~ .1 chunk of wood or foam handy to slap in the box to test it with a .3-.33 as well. I though they were a bit more fun in smaller enclosures.
650W RMS each will give you more than enough power to break them if you want, but that's what I've been running on them in my setup for a while now (M12) with no issue and only once did I smell engineer cologne. But, the dual amp setup in shared airspace is tricky. If you can verify they are putting out the same power with a couple of different test tones (try 20,40,60 and 100), then I don't see a problem with it and headroom is always a good thing
There will be no shallow version of these, sadly for me (cause I've already got it all drawn up and ready to proto!!!). They're 4.5" deep which is too deep for just about anything outside of a full side of Toyota FJ ... But the tiny .1-.2 enclosure does lend them to kick panel installs for te adventurous guys.
The feedback we received at CES as midbass/front subs was very positive. I know at least one member on here was able to hear that demo and really liked them as well.
My personal impression was that I was blown away how fast and powerful they were. Super detailed and dynamic. One of our test tracks was Billy Joel's "It's still rock and roll to me" and the drum pan at 1:25 is AMAZING on these, literally walking across the dashboard. A lot of the staging and placement comes from the processing we did with the H800, but the sound itself, the accuracy and the speed comes straight from the driver.
Jim
Cool! I figured the 1.3 matched up pretty well for the pair.... I will start with that since its built already...just needs an additional baffle put over the one for the 10".
I was incorrect about the 3 sealed....I can actually do 4! 3 downfiring and one rear.... I dont "want" to go that route unless there would be DRASTIC gains?
I have no way to test the amps to ensure equal output so I will try a few different single amp options.....
I really want to get this project up and running but I have yet to hear back from 3 of the local dealers????????????? Its really frigging annoying. They have email addresses but dont respond? I work 70hrs a week and dont think to call during normal hours so I send emails asking for price and availability and if they are open on Sundays? (I have also found that the website schedules might not always be what the reality is
You know....You try and do things the right way and its still a pain in the ass? Could have ordered gray goods and probably already got them and for less????? Although I have terrible luck and its just not a risk I am usually willing to take
I promise to put up a review on them when done and will post a link here. I am really excited for this....Most excited I have been to try a new sub in a LONG LONG LONG time! Again...if its like the new 12" offering I am truly impressed! Tons of impact and accuracy.... They let me put a 12" in a prefab box in my truck for a day to play with it and I was in love with it just sitting on my backseat!!!
Manish: I will give my thoughts on it as soon as I get my hands on it. I love the JBL Gto8 (as everyone knows Its a phenominal budget sub and far out does its price point and "status". I have a feeling these little babies are going to be a substantial upgrade all around.... I hope anyway?
Also...... That is one of the funniest things I have ever heard!!!!!!!!!!!!!
Engineer cologne I may have to put that in my sig!!
Curious about the grill, what kind of time frame are we looking at? I'm thinking a few of these need to go in to the cargo floor of my HHR but they need to be wife-proof.
Speaking of that, my mom punctured a hole into a morel ultimo with a shopping bag
Looking like we are about 8 weeks out or less. My approval samples are on the way this week.
Jim
I currently have two of the 1023d's behind the seat of my truck in smallish sealed boxes (.4cu ea or so) but really considering these eights. The idea is two in (~.5cu) ported boxes. Do you think I will be able to get louder with these eights ported vs tens sealed? I am running about 600wrms for both subs now and will probably run the same amp. I also am unsatisfied with my low end extension in the small sealed boxes, what sort of frequency response in comparison will i be able to achieve with these bad boys.
Haven't gotten there yet, been a rough week .. sorry. I will get to it this week though.
Who hauls sticks in a trunk with a ultimo anyway? But has anyone got their hands on one of these 8's. I would love a review comparing them with the other top 8's on the market.
Done.
Honestly, closer than I thought it would be.
Power = PDX M12
843D .55 @ 35Hz
1043D 0.48 sealed
Songs: Grove St Party, All of the Lights, Aston Martin Music
One thing to recognize is that these woofers are roughly the same efficiency, so they are very evenly matched at mid listening levels until you get into a track with solid 30-40Hz energy. The ported box walks away at that point, however, with enough power on tap, the extra excursion (read stronger motor at the same stroke, more efficient at SPL) the 10" catches up. I'm taking 800-1000W, but the 10 sealed surprised me that it could kind of "come back" as the volume increased, even if it gets a bit dirty at this ridiculous excursion level.
In the end, the 10 can get louder from 50Hz up and 25Hz down, but (just as with any) the ported box can wreck it in the 30-50 range.
As far as speed and accuracy, the 8 is more controlled than 10, even when ported, pretty awesome to my ears. The 10 sounds great though, not dogging it .. Instead I was surprised how well it could keep up in a tiny sealed box.
Hope that helps
Jim
That's 0.5 net after port displacement, but yes. I prefer the ported install. I guess I need to know how loud you're trying to get and how much you are going to miss the sound of flat extension down into the low 30s vs. sealed.
Have you had sealed woofers in your system before? If yes, then you know what to expect .. just don't want to have you disappointed when you're roll-off starts at 50 vs. 30Hz
The fact that they remain well composed and sound great ported pushes me to recommend you to try ported first.
You can see my box in the pictures. It is 0.59 each before I put the woofer into the box. Going down to 0.50 would lose 1-2dB between 30-40Hz, but it'll still be a great setup.
All of that said, 4 sealed would be an absolutely awesome setup for SQ, coupled with that amp ... I know you'll be very content with it.
Thanks for the post Jim. Looks like my dealer is going to get a call on Tuesday . The only other thing is what is your port area and length. I am going to try and mimic what you have built(box size and tuning... maybe a touch lower tuning). Looks like I am going to bite the bullet and push some more power to the subs too.
2 Type R 10's
Phoenix Gold Amps
I'm using tiny ports 5.25in^2 at 16.25", 1/2 roundover on the exit and the inside edge, no bends. The issue you are going to have with the small box is the length of the port. It's not a problem once you get into a shared chamber (even with just two), but as a single woofer box, the port gets long in a hurry.
For you're box .. I'd run dual 823Ds in a total of 1.3 cubes (net) tuned at 33Hz.
12.5 in^2 of port (4" round equivalent) at 21.5" long. This should be a hell of a setup, linear and powerful down to just about 30Hz, you'll run into the limits right at ~500W each.
