Mounting amps on sub boxes, bad idea??? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-04-2011   #1
Rep Power: 105 Lance_S will become famous soon enoughLance_S will become famous soon enoughLance_S will become famous soon enoughLance_S will become famous soon enoughLance_S will become famous soon enoughLance_S will become famous soon enough
Default Mounting amps on sub boxes, bad idea???
Hey guys,
Mounting amps today. I was planning on mounting them to the sub box but then gave a second thought to vibration. Should I mount the amps off the box to avoid long term vibration effects to the amps?
I was planning on putting rubber spacers between them amps and the box but still don't know if that would make enough difference.
Thanks in advance.
L
Lance_S is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #2
Rep Power: 144 dragonrage will become famous soon enoughdragonrage will become famous soon enoughdragonrage will become famous soon enoughdragonrage will become famous soon enoughdragonrage will become famous soon enoughdragonrage will become famous soon enough
Default Re: Mounting amps on sub boxes, bad idea???
A lot of people do it and are fine, but of course it will be more stressful to the solder joints and such. It's definitely riskier to mount it where it will vibrate more... The call is yours to make.
dragonrage is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #3
Dragon,
Thanks, reviewing it now. Gotta think about it. I have done it in the past without much thought but the amps I have are old school and I don't want to stress them any more than I have to. The box is only a single 12" and won't run it for SPL, just SQ. I like a balance tone so it won't be run hard. But again, just thinking of the vibs effect on the amps. Even tho it won't be run hard, it's still almost constantly moving.
Thanks,
L
Old 04-04-2011   #4
hottcakes's Avatar
Rep Power: 91 hottcakes will become famous soon enoughhottcakes will become famous soon enoughhottcakes will become famous soon enoughhottcakes will become famous soon enoughhottcakes will become famous soon enoughhottcakes will become famous soon enoughhottcakes will become famous soon enough
well if you're going to do it, may as well do it the "right" way. and i use that term loosely.
bcae1.com mounting is aboot half way down.
does the music cause us to do what we do, or do we cause the music to do what it does?
hottcakes is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #5
Rep Power: 114 newsqguy will become famous soon enoughnewsqguy will become famous soon enoughnewsqguy will become famous soon enoughnewsqguy will become famous soon enoughnewsqguy will become famous soon enoughnewsqguy will become famous soon enough
many people don't like doing it for the vibration and fatigue on the amps other people say it makes no difference i try not to do it when i can avoid it sometimes thats what people want sometimes they don't care
newsqguy is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #6
Scott@GZUSA's Avatar
Ground Zero USA
Rep Power: 255 Scott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond reputeScott@GZUSA has a reputation beyond repute
I dont see a difference in vibration. Mount it to some sheet metal, that will vibrate more than the MDF enclosure. I have never seen a problem arise form mounting them on the box. I wouldnt do it, but back in the day, thats how it was done alot. Bass is gonna make everything vibrate and rattle, so I think its moot.
Scott@GZUSA is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #7
The box is 3/4 MDF and it's only a foot of cubic space with one 12" driver so the box flex isn't a terribly big concern. It comes down to a space issue.
Old 04-04-2011   #8
Rep Power: 151 fish will become famous soon enoughfish will become famous soon enoughfish will become famous soon enoughfish will become famous soon enoughfish will become famous soon enoughfish will become famous soon enough
Another way to think about it is it makes a nice, quick & easy getaway combo pack for a thief.
P01 - HD600/4(2) - T1500-1bdCP - LPG 26NA - Peerless NE95W - Usher 1001B - Soloclassic 15(2)
fish is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #9
you can also bolt down said box......
Old 04-04-2011   #10
Bayboy's Avatar
Rep Power: 148 Bayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to beholdBayboy is a splendid one to behold
I've done it in the past, but have gotten away from it after damaging a couple of amps in the long run. Solder joints were loosened and a light tap would make it turn back on (just for confirmation). If you can build a rock solid box that doesn't transfer much vibration, I think you will be ok. Of course I would rule out anything rigged for SPL.
I also find amp racks or amps stealthily installed more cosmetically pleasing. Plus it makes it a lot easier if you want try different subs. Just plug, tune & play.....
Bayboy is online now   Reply With Quote Quick reply to this message
Old 04-04-2011   #11
Rep Power: 190 sqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the rough
I've fixed broken amps from vibration. It also depends on power for example a well built box under 300rms its likely not an issue. Some amps are more prone to it than others.
Old 04-04-2011   #12
mires's Avatar
Rep Power: 90 mires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura aboutmires has a spectacular aura about
This
mires is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #13
Rep Power: 79 memphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enough
I've been doing this for years in friends vehicles that just wanted a quick cheap install. Never once had a problem as long as the box didn't move around ripping out wires. Most of the time just used velcro to keep it in place.
memphiskane is offline   Reply With Quote Quick reply to this message
Old 04-04-2011   #14
Yeah, the thief thing is for real. Fortunately they usually don't steal what they don't see. Everything is hidden from view which is good.
L
