Old 01-13-2012   #1
thomasluke's Avatar
Rep Power: 41 thomasluke will become famous soon enoughthomasluke will become famous soon enoughthomasluke will become famous soon enoughthomasluke will become famous soon enoughthomasluke will become famous soon enoughthomasluke will become famous soon enough
Default Remote turn on
Say you take 12 gauge wire from the + on the batt to a toggle switch whereever you want to put it.
Then from toggle to amps.
The idea is to prevent pops during powering up and down.
thomasluke is online now   Reply With Quote
Old 01-13-2012   #2
Rep Power: 284 azngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond repute
Default Re: Remote turn on
yes you can do that but there are other solutions like a relay or delay timer/circuit as well
azngotskills is offline   Reply With Quote
Old 01-13-2012   #3
thomasluke's Avatar
Ya, Its just what i got laying around. I dont have any pops as of right now.
But After adding an ms8 and two more amps its just something i'm thinking about.
As well as where the hell i'm about to stuff all this shit.
Old 01-14-2012   #4
Rep Power: 103 bobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enough
The problem with the toggle off the battery is that sooner or later you will forget to turn it off.
bobduch is offline   Reply With Quote
Old 01-14-2012   #5
TrickyRicky's Avatar
Rep Power: 83 TrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to allTrickyRicky is a name known to all
If there is a turn on or off pop, there is a high chance its the amplifier and not the remote cable. Unless you got a weird headunit which sends a 12v signal in the remote before acutally turning on itself. Or if the amplifier is very old and doesnt have a turn on delay or speaker relay in the circuit.
All I can say is do it and let us know the outcome.
TrickyRicky is online now   Reply With Quote
Old 01-14-2012   #6
steffanan's Avatar
Redline Audio & Cellular
car audio installer
Rep Power: 34 steffanan will become famous soon enoughsteffanan will become famous soon enoughsteffanan will become famous soon enoughsteffanan will become famous soon enoughsteffanan will become famous soon enoughsteffanan will become famous soon enough
dude, DONT DO THAT
find vehicle ignition on google, and tap into it, there is nothing more ghetto rigged than a flippin remote turn on, on a switch. in theory, it sounds fine, but you will HATE flipping a switch on and off all the time
ZAPCO EVERYTHING! booyah
steffanan is offline   Reply With Quote
Old 01-14-2012   #7
Rep Power: 31 Mike_Dee is on a distinguished roadMike_Dee is on a distinguished roadMike_Dee is on a distinguished roadMike_Dee is on a distinguished roadMike_Dee is on a distinguished road
I'm pretty sure a SP/ST switch will do absolutely nothing to eliminate a turn on/off pop.
Usually a result of in-rush current. As mentioned earlier, a relay is the way to go.
Mike_Dee is offline   Reply With Quote
Old 01-15-2012   #8
Rep Power: 0 rex450se will become famous soon enoughrex450se will become famous soon enoughrex450se will become famous soon enoughrex450se will become famous soon enoughrex450se will become famous soon enoughrex450se will become famous soon enough
Originally Posted by steffanan View Post
dude, DONT DO THAT
I don't think there's anything wrong with a switch on the remote wire. I have one on mine so I can easily turn off the sub when the kids are in the truck with me. It's easy and you can use any cheap switch since it doesn't need to handle much at all. Just my .02
Victor
rex450se is offline   Reply With Quote
Old 01-15-2012   #9
Rep Power: 21 bhammer will become famous soon enoughbhammer will become famous soon enoughbhammer will become famous soon enoughbhammer will become famous soon enoughbhammer will become famous soon enoughbhammer will become famous soon enough
If you are adding an ms8,use its remote turn on to turn on the amps. I think it specifically states this in the directions as well. The 8 will be fully powered up before sending the remote.
bhammer is offline   Reply With Quote
Old 01-15-2012   #10
ecbmxer's Avatar
Rep Power: 41 ecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enough
Also, if you have a bunch of amps, it would probably be a good idea to run a relay with the rem turn out wire. Put a relay in place of the switch you wanted, and feed that the remote turn on signal out of the MS8.
2010 Subaru WRX: H-Audio Trinity and Ebony, sealed IDQ10v3, Massive Audio NX5 and NX2 amps, Alpine INA-W900BT with H100 Imprint, RAAMat/Ensolite, KnuKoncept/DIY wiring
ecbmxer is offline   Reply With Quote
Old 01-15-2012   #11
steffanan's Avatar
car audio installer
Don't do that. amp turn on signal is so weak, that you would need like 20 amps to even have a chance of them not turning on.
Old 01-15-2012   #12
steffanan's Avatar
car audio installer
yeah, most processors have a remote output that's great to use. I use mine to turn three amps, and 3 relays on. My processor basically has a built in relay and puts battery power through the remote turn on output, so I could run lights and stuff if I wanted
Old 01-15-2012   #13
PPI-ART COLLECTOR's Avatar
Diyma Ninja
BMI Inspections
Rep Power: 110 PPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond repute
I use this device to control turn on noise for my seven amps.
It also mutes any noise between songs.
Here's the pdf owner's manual link for it:
http://www.precisionpower.com/Manual...ise%20Gate.pdf
PPI ACM-420 Noise Gate (3rd one from the top)
Bret
PPI-ART COLLECTOR
EVERYTHING LOUDER THAN EVERYTHING ELSE-Meat Loaf
TEAM GRIZZ
PPI-ART COLLECTOR is online now   Reply With Quote
Old 01-15-2012   #14
thomasluke's Avatar
It's the 3rd one down from the top:
Bret
PPI-ART COLLECTOR
I dont have any pops or anything and no noise but.......
Ya got an extra one?
"What screws us up the most in life is the picture in our head of how it is supposed to be."
Old 01-15-2012   #15
audiolab
installer
Rep Power: 45 deesz will become famous soon enoughdeesz will become famous soon enoughdeesz will become famous soon enoughdeesz will become famous soon enoughdeesz will become famous soon enoughdeesz will become famous soon enough
You can add a relay to the remote turn on, Or you can get it to go away with a diode. rare but sometimes its enough. Or just add the switch to the remote turn on wire so you dont have to run anything into the engine compartment.
deesz is offline   Reply With Quote
Old 01-15-2012   #16
Diyma Ninja
BMI Inspections
No, not at this time.
I saw two or three of them pop up on ebay during the last year.
I just read through the owner's manual again and realized that I had forgot what a clever little toy it is.
And yes it will work with all systems; not just PPI.
Bret
PPI-ART COLLECTOR
TEAM GRIZZ
Old 01-15-2012   #17
thomasluke's Avatar
Bret
PPI-ART COLLECTOR
Ok, thanks anyway though.
Old 01-15-2012   #18
Rep Power: 21 slipchuck will become famous soon enoughslipchuck will become famous soon enoughslipchuck will become famous soon enoughslipchuck will become famous soon enoughslipchuck will become famous soon enoughslipchuck will become famous soon enough
I use one of these for remote turn on to the antenna, powered subs, and 2 amps.
Single Pole Double Throw (SPDT), Single Pole Single Throw (SPST) Automotive Relays
randy
slipchuck is offline   Reply With Quote
Old 03-03-2012   #19
DaCid's Avatar
Rep Power: 35 DaCid will become famous soon enoughDaCid will become famous soon enoughDaCid will become famous soon enoughDaCid will become famous soon enoughDaCid will become famous soon enoughDaCid will become famous soon enough
So I was just looking through this thread because I am installing a relay for my turn on to protect my HU. My question is I don't want to deal with wiring it to the battery if I can help it, could I connect the relay to my under-dash fusebox with a 20A fuse, then run the ground and wires to the amps and HU?
Thanks for the help!
1995 Honda Civic Rebuild: Clarion DRZ 9255 | 12" IDMax D4v3 | Steven Audio Ultra MH's | ID x65 Woofers | Old School Zapco Z300 powering sub | Kenwood KAC-5204 powering horns | Kenwood KAC-7205 powering woofers
DaCid is online now   Reply With Quote
