Old 03-22-2012   #76
jockhater2's Avatar
Rep Power: 31 jockhater2 will become famous soon enoughjockhater2 will become famous soon enoughjockhater2 will become famous soon enoughjockhater2 will become famous soon enoughjockhater2 will become famous soon enoughjockhater2 will become famous soon enough
Default Re: XS Power-Audio Savings-Group Buy
Originally Posted by Colbyjack View Post
So did I miss the second run of 3000's, because I've been checking the site and haven't seen them come available again.
I have been checking every day for 2 weeks. I am thinking the same thing.
Head Unit Pioneer P99RS ,380 Amp & 320 Amp Iraggi Alternators, Exile X5 (for sale) running 2 12 inch Ascendant Audio Mayhems, Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
jockhater2 is offline   Reply With Quote
Old 04-03-2012   #77
XS Power
Marketing Manager
Rep Power: 38 Nathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond reputeNathan@XSPower has a reputation beyond repute
They are on the site now. Sale ends on the 13th, so take advantage of the discount while it lasts.
Nathan@XSPower is offline   Reply With Quote
Old 04-06-2012   #78
XS Power
Marketing Manager
Only 1 week left.
Old 04-24-2012   #79
Rep Power: 105 xencloud will become famous soon enoughxencloud will become famous soon enoughxencloud will become famous soon enoughxencloud will become famous soon enoughxencloud will become famous soon enoughxencloud will become famous soon enough
Hi guys, looking for a secondary trunk power cell for a true 2500-3000 watt system. Amps are some oldschool class A/B current hogs. Already have a big deep cycle, 220amp alternator, and big 3 upgraded, just looking to really set it up right. Which XS cell is for me? Thanks!
xencloud is offline   Reply With Quote
Old 05-12-2012   #80
Rep Power: 24 Richv72 will become famous soon enoughRichv72 will become famous soon enoughRichv72 will become famous soon enoughRichv72 will become famous soon enoughRichv72 will become famous soon enoughRichv72 will become famous soon enough
Are these still on sale?
Richv72 is offline   Reply With Quote
Old 05-13-2012   #81
Rep Power: 0 redheadedrod will become famous soon enoughredheadedrod will become famous soon enoughredheadedrod will become famous soon enoughredheadedrod will become famous soon enoughredheadedrod will become famous soon enoughredheadedrod will become famous soon enough
I have a 2003 Chevy Avalanche With power/heated seats. This truck has a 105 amp alternator in it stock.
I am looking to install a CarPC system into this vehicle that will pull under 160W.
If I install the system I am considering I will have 6 "old school" unregulated 50MS Audio Art amplifiers that at 14 volts could max out at about 2000W.
Case rating of 2x50W but documentation rates these at 75x2 at 14V and 1x350 at 14V. Yes these were considered "cheater" amps when they were new.
My setup will be as follows:
2x75 driving Passive Diamond 3way Audio HEX speakers (6.5, 4, and tweet)
2x75 driving Passive Diamond 2way Audio Hex speakers (6.5, tweet)
1x350 or 2x75 driving 6.5 HART series Subwoofers (80-150hz roughly. Will use two amplifiers regardless of configuration. Don't know how they will match up yet otherwise. in 1x350 mode it will be heavily attenuated.)
1x350 x 2 driving 10" HART series Subwoofers (0-80 hz).
So with this setup I would max out at 1700 or 1150 depending on the setup of the smaller subs. (Would be 1075 if I use 1 amp to drive both 6.5 subs at 2x75 but with the level of attenuation will be closer to 1400 than 1700 if I drive each with its own)
I am considering a dual battery system more for the CarPC than the system since I would seldom run the system much lower while parked. I do have an aftermarket WRANGLER alternator I may add to this system. This Alternator has an external regulator and is supposed to be 120amps hot or cold. It has dual outputs on it to power 2 batteries directly.
I know that GM has a secondary battery tray available for these trucks. I may consider a second battery just for the Sound system and PC and keep the main battery for the truck.
With a 2 battery system I was taught you really want to run with 2 identical batteries.
So what would you suggest here?
This truck comes with side "posts" and I normally don't like this setup because it can be hard to jump but GM was nice enough to have a remote jumping terminal that has a large easy to access post.
I realize the sale is likely over.. Just looking for information at this point.
redheadedrod is offline   Reply With Quote
Old 05-23-2012   #82
Bulk Sales Pass
AcuraTLSQ's Avatar
Rep Power: 103 AcuraTLSQ will become famous soon enoughAcuraTLSQ will become famous soon enoughAcuraTLSQ will become famous soon enoughAcuraTLSQ will become famous soon enoughAcuraTLSQ will become famous soon enoughAcuraTLSQ will become famous soon enough
Send a message via AIM to AcuraTLSQ
D6500 all dressed up.
[IMG][/IMG]
2005 Acura TL-Zapco-AudioTechnology-Compustar-Toolmaker-Morel
AcuraTLSQ is offline   Reply With Quote
Old 05-27-2012   #83
[IMG][/IMG]
Thats the coolest looking battery connectors ive ever seen. Nice!
Old 12-09-2012   #84
Rep Power: 47 cobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enoughcobraa will become famous soon enough
Very cool battery connector indeed? are they for sale?
cobraa is offline   Reply With Quote
Old 12-09-2012   #85
jockhater2's Avatar
My xs power batteries.
Old 12-09-2012   #86
I dont think xs power ever checks this subforum or updates it. Ive seen some questions go unaswered for weeks and weeks.
