Old 07-22-2012   #1
Rep Power: 0 recycledfarmequipment will become famous soon enoughrecycledfarmequipment will become famous soon enoughrecycledfarmequipment will become famous soon enoughrecycledfarmequipment will become famous soon enoughrecycledfarmequipment will become famous soon enoughrecycledfarmequipment will become famous soon enough
Question Radio Reception on Eclipse
I have an Eclipse AVN726EA head unit installed into a 2006 VW Touareg. With the OEM radio in the VW reception was excellent on AM and FM. Since installing the Eclipse unit the reception has been poor. The installer fitted an amplifier into the aerial to boost but that did not help. I later had another installer look at it and they replaced the amplifier and reception improved on AM and slightly on FM. As I live in a country area with surrounding hills reception is a challenge. I have contacted Eclipse and they say that reception on their unit can't match the VW OEM radio. It uses wires built into the side rear windows. Can anyone suggest an alternate approach. Is there an external antenna that would fit a Touareg? It would need to be short and fitted to the roof. Any suggestions appreciated.
recycledfarmequipment is offline   Reply With Quote
Old 07-22-2012   #2
spl152db's Avatar
Rep Power: 80 spl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enough
Is the anetanna adapter just wires or does it have a bid metal cylinder with a blue wire on it? Vw needs a power source to work correctly and you should have good reception with it.
Sent from my ADR6400L using Tapatalk
spl152db is offline   Reply With Quote
Old 07-23-2012   #3
Default Re: Radio Reception on Eclipse
I believe it has a power source to it. I have not seen it only been told by the installer.
Old 07-30-2012   #4
Rickna's Avatar
Rep Power: 0 Rickna will become famous soon enoughRickna will become famous soon enoughRickna will become famous soon enoughRickna will become famous soon enoughRickna will become famous soon enoughRickna will become famous soon enough
I had radio reception problems with an Eclipse AVN6600. The 1st car I had it in was a 2003 Hyundai Tiburon (Coupe). This car had a mast antenna with no radio problems. The 2nd car was an 2001 Audi A4 witha grid antenna. As long as I hooked up the power antenna lead to the antenna amp near the rear window, no problems. My current car 2002 BMW 330xi had terrible problems especially with AM. I picked an HD Radio add-on box on ebay and much to my suprise, the reception increased tremendously. Grid antennas with aftermarket radios seem to be problematic with Euro cars here. Some say it's hit or miss (not much help). I wouldl recomend you make sure that the power antenna lead is connected securley and you use a high quality adapter.
Rickna is offline   Reply With Quote
Old 07-31-2012   #5
Columbus Car Audio
12v Product Specialist
Rep Power: 22 D-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enough
does the antenna adapter have a metal cylinder in the middle and a power wire coming off the middle of it? it does it just adapt the ends?
I've seen a lot of shops just use regular european antenna adapters because they don't stock the amplified antenna version(or even know about it).
Metra 40-EU10 EnfigCarStereo.com
Picture 1 of 2 for Metra 40-EU55
D-Bass is offline   Reply With Quote
Old 07-31-2012   #6
Rickna's Avatar
I've tried the amplifiers, no difference. As for the adapters, there is a difference in quality depending on the brand of the adapter.
Old 07-31-2012   #7
Rep Power: 28 Pimpnyou204 will become famous soon enoughPimpnyou204 will become famous soon enoughPimpnyou204 will become famous soon enoughPimpnyou204 will become famous soon enoughPimpnyou204 will become famous soon enoughPimpnyou204 will become famous soon enough
I had the exact same problem with my avn too. I can't do anything about it either.
Pimpnyou204 is offline   Reply With Quote
Old 07-31-2012   #8
Rickna's Avatar
I'm curious, what car was it installed in?
Old 07-31-2012   #9
It's in an 2010 Altima coupe if u have any ideas throw em out lol
Old 07-31-2012   #10
Rickna's Avatar
One thing I've learned is to ground the radio chassis to the car frame. I've also had problems with cheap adapters. The metal can fatigue after time and not grip properly. Carefully applying contact grease can help. There is one hidden antenna That I have had good results with here- Tune Trapper Hidden AM FM Antennas For Cars, Trucks, RV's, Tractors, Golf Carts, Vehicles
Old 08-01-2012   #11
Rep Power: 94 Jroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enough
its been years since I had my eclipse, but the radio reception was horrible. I wasnt bothered much because I really didnt listen to the radio.The times I did click on radio, I listen to AM for talk and sports radio. Once I left city limits I knew to put a cd back in becaue the reception quickly went to piss.
Jroo is offline   Reply With Quote
