**Stupidest thing anyone has said to you (audio wise)** - Page 115 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-08-2016   #2851
schmiddr2's Avatar
do it yourself
Rep Power: 40116 schmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond repute
Default Re: **Stupidest thing anyone has said to you (audio wise)**
Apparently he thinks water can't get to a speaker through the box or port, or that salt water is not bad for speakers.
https://www.washingtonpost.com/natio...b66_story.html
schmiddr2 is online now   Reply With Quote Quick reply to this message
Old 10-08-2016   #2852
Hillbilly SQ's Avatar
iNCORRECT pOLITICALLY
Complacent Audio
Incoherent rambler
Rep Power: 249 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Guess he thought the tub thumb of that bandpass was worth saving...
Old 10-08-2016   #2853
Rep Power: 49 Bitter will become famous soon enoughBitter will become famous soon enoughBitter will become famous soon enoughBitter will become famous soon enoughBitter will become famous soon enoughBitter will become famous soon enough
May have been the most valuable thing he thought he could salvage.
Bitter is offline   Reply With Quote Quick reply to this message
Old 10-08-2016   #2854
ryanr7386's Avatar
Rep Power: 86 ryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enough
Originally Posted by cheebs View Post
i was on offer up and i saw this ad for some Boston Acoustics 6x9s and 6.5s for $130. he said that one set were boston z6. I was like cool. I call him and it turns out it is a pawn shop. So i text him for pics and he tells me that they are in great shape and working. so i ask for a picture. he sends me these.
Free Air Version!
1994 Ford Thunderbird SC System - Alpine 7909, Helix DSP Pro, ADS MX Amps & ADS Speakers. On Going Build
ryanr7386 is online now   Reply With Quote Quick reply to this message
Old 10-11-2016   #2855
Ok. Not audio but electrical, Ford built the 91 Capri headlight circuit with two single points of failure. All headlight power passes through a single 30A fuse which is a case style and then through a single set of switch contacts. What the heck! Any short will smoke the fuse which puts out high and low beams both sides! And will likely melt the plastics housing on the switch or at least heat the brass bar inside enough to case connectivity problems going forward. Now you might say that fuses don't often pop and wires are pretty stationary. Nope, pop up lights!
I'm wiring up a set of dedicated relays and power direct from the battery to take load off the switch and reduce the scope of a failure to a single filament. A little redundant but lights are such a safety critical part of the car.
Old 10-11-2016   #2856
fcarpio's Avatar
Hungry all the time
Rep Power: 140 fcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enough
Originally Posted by QualitySound View Post
But in both cases, each of them is unaware of the responses, or misunderstands the responses, of other people. If so, could that be related to narcissism? An inability or unwillingness to empathize?
Nah, I think they are just clueless.
fcarpio is offline   Reply With Quote Quick reply to this message
Old 10-12-2016   #2857
Rep Power: 100 ebrahim will become famous soon enoughebrahim will become famous soon enoughebrahim will become famous soon enoughebrahim will become famous soon enoughebrahim will become famous soon enoughebrahim will become famous soon enough
One of the girls I use to go to university worked at a pawn shop. Basically if the speaker makes a sound from the amp that it was hooked up to they claim it works. However one of my co workers got burned when they sold him a subwoofer that needed refoamed
ebrahim is offline   Reply With Quote Quick reply to this message
Old 01-06-2017   #2858
Classifieds Access
restless.skies's Avatar
Rep Power: 0 restless.skies will become famous soon enoughrestless.skies will become famous soon enoughrestless.skies will become famous soon enoughrestless.skies will become famous soon enoughrestless.skies will become famous soon enoughrestless.skies will become famous soon enough
"An infinite baffle? In 2016? Subs go in a sealed or ported box and that's it."
Turned around and left immediately. This coming from the owner of a shop nearby who has supposedly been in the car audio scene since the late 80's...
restless.skies is offline   Reply With Quote Quick reply to this message
Old 01-06-2017   #2859
quality_sound's Avatar
Rep Power: 235 quality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nice
"I blew my BMs because I used an amp that was too small and it clipped."
Old 01-06-2017   #2860
PorkCereal's Avatar
Rep Power: 100 PorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enough
Ya, that was a little funny
'15 Focus ST, SI M25, TM65v1, BM MKiv x2, ARC 1200.6, JBL MS 8
PorkCereal is offline   Reply With Quote Quick reply to this message
Old 01-06-2017   #2861
Rep Power: 75 HulkSmash will become famous soon enoughHulkSmash will become famous soon enoughHulkSmash will become famous soon enoughHulkSmash will become famous soon enoughHulkSmash will become famous soon enoughHulkSmash will become famous soon enough
I called a nearby shop to talk to them about a few ideas. I mentioned using a IB sub. He asked me how old I was...I laughed and told him (40). He said that I had to be around his age to ask about IB these days.
HulkSmash is offline   Reply With Quote Quick reply to this message
Old 01-06-2017   #2862
PorkCereal's Avatar
Was told this the other day. I couldn't get this guy to understand anything other than his view
'so staging vocals and sound is something you should do in a car? buy a 4 door car and screw who ever is in the back seat so they can't hear anything, while you jam out in the front seat? makes sense for a coupe with useless back seat or a roadster'
Old 01-06-2017   #2863
I800C0LLECT's Avatar
Rep Power: 132 I800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of light
A salesman told me that Hertz subwoofer was THE ONLY sub whose sensitivity went up the lower it played
Sent from my Pixel XL using Tapatalk
My '13 Jetta build...not finished
I800C0LLECT is online now   Reply With Quote Quick reply to this message
Old 01-06-2017   #2864
Pariah Zero's Avatar
Rep Power: 17 Pariah Zero will become famous soon enoughPariah Zero will become famous soon enoughPariah Zero will become famous soon enoughPariah Zero will become famous soon enoughPariah Zero will become famous soon enoughPariah Zero will become famous soon enough
Ah salesmen. They know enough buzzwords to sound knowledgeable to the average clueless schmuck, and like an idiot with a word a day calendar to everyone else.
Fun fact: The loudest posible undistorted SPL is ~ 194 dB.
Pariah Zero is offline   Reply With Quote Quick reply to this message
Old 01-09-2017   #2865
LaserSVT's Avatar
L&D Automotive
Rep Power: 124 LaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enough
Yeah that guy is an idiot.
Old 01-09-2017   #2866
LaserSVT's Avatar
L&D Automotive
Yes, I should have said "hurt" and not "blew". I figured people would take "blown" as just damaged which is what I was attempting to convey. I forget we live in a world of extreme specifics and if the exact correct term is not used you (I) am now stupid.
Old 01-09-2017   #2867
fcarpio's Avatar
Hungry all the time
LOL, that is called plain English.
Old 01-10-2017   #2868
LaserSVT's Avatar
L&D Automotive
Sorry, second language.
Old 01-10-2017   #2869
fcarpio's Avatar
Hungry all the time
Not an excuse because 'Murica!
Btw, English is not my first language either.
Old 01-11-2017   #2870
Complacent Audio
Incoherent rambler
What's your first language? How much I enunciate depends on the company, but tend to pour on the southern draw when I'm telling life stories that usually involves something that happened on the lake or in the woods
Old 01-11-2017   #2871
LaserSVT's Avatar
L&D Automotive
Bad English is my first language.
Old 01-12-2017   #2872
I had this weird ass mix of English (proper tea and crumpets English, my mother is English) and coonass (I'm from Louisiana). Oddly, my dad has never had much of an accent but he moved to the US from Mexico when he was 11 so I guess he had more time to assimilate before I was born. I like to think he sounded like the Dos Equis guy.
Old 01-12-2017   #2873
Complacent Audio
Incoherent rambler
Does he drink the same beer the most interesting man in the world drinks "occasionally"?
I have a boss from Mass. and the other night I asked him if moving to the deep south was a culture shock for him. He said people thought he was a jerk because he didn't use an over-abundance of words. He said what he needed to say and that was it. Sometimes it's obvious he's trying too hard to fit in, but he's good people. Sometimes you just gotta be yourself.
Old 03-12-2017   #2874
Rep Power: 0 Bruteforce650 will become famous soon enoughBruteforce650 will become famous soon enoughBruteforce650 will become famous soon enoughBruteforce650 will become famous soon enoughBruteforce650 will become famous soon enoughBruteforce650 will become famous soon enough
New here, 1st post, Installed professionally from late 80's to about 2003. I have seen and heard a lot. I have seen band-aids used like electrical tape, But I have never had anyone ask to make their trunk or car rattle more. Spent lots of time and money stopping rattles. WOW!
Bruteforce650 is offline   Reply With Quote Quick reply to this message
Old 03-12-2017   #2875
Rep Power: 28 GEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enough
I think the trend of trying to run every driver as low as possible, even without good reason based upon some assumption that the result will invariably be better is probably the thing that annoys me the most currently.
GEM592 is online now   Reply With Quote Quick reply to this message
