Anyone do an install on a 2010 -2013 Camaro with Boston Acoustic Factory Amp - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 03-20-2013   #1
mattyjman's Avatar
Rep Power: 119 mattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enough
Default Anyone do an install on a 2010 -2013 Camaro with Boston Acoustic Factory Amp
I've got some questions in regards to factory integration and I can't seem to find the answers.
Wondering if the best place to grab the inputs for the processor is pre amp or post amp.
Also wondering in either of those situations if the outputs are full range or if they are modified, as well as if there is a "loudness" curve built into the system (sounds like it is) and if that is programmed at the headunit vs the amp.
If anyone could start here by answering these questions, that would be fantastic!
(oh, and I don't want to lose back up sensor beebs, chimes, bluetooth audio, etc... - is this done at the amp. If so can I keep this functionality while removing the amp?)
THanks!
2013 Camaro 2SS 1LE - HLCD Coming Soon!
mattyjman is offline   Reply With Quote Quick reply to this message
Old 03-20-2013   #2
jowens500's Avatar
a boombox is not a toy
Malibu's Auto Center
Janitor/Install Manager
Rep Power: 118 jowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enough
All the chimes/nav voices/Bluetooth are in the amp.
2009 USACi Basic Consumer World Champion (Installer)
2009 USACi mod2000-4000 4th place (Installer)
2009 USACi SB3 3rd place (Installer)
jowens500 is offline   Reply With Quote Quick reply to this message
Old 03-20-2013   #3
mattyjman's Avatar
Default Re: Anyone do an install on a 2010 -2013 Camaro with Boston Acoustic Factory Amp
so if i take the outputs preamp, i'll lose functionality of all those things? is there anyway to keep them?
Old 03-20-2013   #4
edzyy's Avatar
Rep Power: 89 edzyy will become famous soon enoughedzyy will become famous soon enoughedzyy will become famous soon enoughedzyy will become famous soon enoughedzyy will become famous soon enoughedzyy will become famous soon enoughedzyy will become famous soon enough
Yes, you'll lose them.
Tap post amp.
Not sure if the signal is flat, though.
edzyy is offline   Reply With Quote Quick reply to this message
Old 03-20-2013   #5
jowens500's Avatar
I've left the amp in with all the speakers disconnected. Then used an old hands free kit Speaker to do the chimes/nav stuff. That would not work for BT streaming though.
Old 03-20-2013   #6
Rep Power: 108 so cal eddie will become famous soon enoughso cal eddie will become famous soon enoughso cal eddie will become famous soon enoughso cal eddie will become famous soon enoughso cal eddie will become famous soon enoughso cal eddie will become famous soon enough
I used the Speaker outputs from the stock trunk amp going to a jl cleansweep, and the system sounded just fine. New fronts, rears, and subs with a couple amps, and we didn't have any noise issues and all of the functions still worked. This install was last year, but I think someone makes an amp replacement kit now.
so cal eddie is offline   Reply With Quote Quick reply to this message
Old 03-20-2013   #7
kustomkaraudio's Avatar
kustom kar audio
owner
Rep Power: 100 kustomkaraudio will become famous soon enoughkustomkaraudio will become famous soon enoughkustomkaraudio will become famous soon enoughkustomkaraudio will become famous soon enoughkustomkaraudio will become famous soon enoughkustomkaraudio will become famous soon enough
Talking Re: Anyone do an install on a 2010 -2013 Camaro with Boston Acoustic Factory Amp
Check out SubThump - , they sell a harness kit to remove the factory amp, it looks very complete. Should make life easy.
Builder of 2010 MECA World Champion MODEX class Gary Summers 2006 mercedes C-Class
kustomkaraudio is offline   Reply With Quote Quick reply to this message
Old 03-21-2013   #8
Rep Power: 69 Datsubishi will become famous soon enoughDatsubishi will become famous soon enoughDatsubishi will become famous soon enoughDatsubishi will become famous soon enoughDatsubishi will become famous soon enoughDatsubishi will become famous soon enough
I'm doing an install soon with some stuff from subthump. My buddy did some research before he bought and their stuff seems legit. Hoping for the best.
Datsubishi is offline   Reply With Quote Quick reply to this message
Old 03-21-2013   #9
mattyjman's Avatar
i've emailed them, waiting for a response currently.
Old 03-21-2013   #10
DrivenAudio
owner
Rep Power: 105 pentavolvo will become famous soon enoughpentavolvo will become famous soon enoughpentavolvo will become famous soon enoughpentavolvo will become famous soon enoughpentavolvo will become famous soon enoughpentavolvo will become famous soon enough
It's flat if you tap before the amp
pentavolvo is offline   Reply With Quote Quick reply to this message
Old 03-19-2016   #11
Rep Power: 0 Usarlr1 will become famous soon enoughUsarlr1 will become famous soon enoughUsarlr1 will become famous soon enoughUsarlr1 will become famous soon enoughUsarlr1 will become famous soon enoughUsarlr1 will become famous soon enough
I have a question about 2010 camaro with Boston acoustics system. If I use a certain popular amp bypass harness to bypass my factory amp and install a new aftermarket amp can I put any kind of speakers in the rear deck? Like 2 way,3way and so on?
Usarlr1 is offline   Reply With Quote Quick reply to this message
Old 05-26-2016   #12
imdyinhere's Avatar
Rep Power: 24 imdyinhere will become famous soon enoughimdyinhere will become famous soon enoughimdyinhere will become famous soon enoughimdyinhere will become famous soon enoughimdyinhere will become famous soon enoughimdyinhere will become famous soon enough
Sure can. I removed the 6x9 speakers in my 2011 SS and replaced with 6.5" midbass drivers. SubThump makes an adapter. I originally had a component set in there with tweeters (adapter accommodated those as well, but it was too much so I just disconnected them.
imdyinhere is offline   Reply With Quote Quick reply to this message
