Strange popping sound from sub! - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-19-2013   #1
Rep Power: 0 truckstoy will become famous soon enoughtruckstoy will become famous soon enoughtruckstoy will become famous soon enoughtruckstoy will become famous soon enoughtruckstoy will become famous soon enoughtruckstoy will become famous soon enough
Default Strange popping sound from sub!
this is my friends car/install
car: 2012 Kia Optima sub: JL audio 13W7 (sealed) amp: JL audio 1000/1
was installed by some audio place using a loc on the rear speaker.
when they 1st installed they were getting a pop on the sub and it almost sounded like it was blown, (i sold stuff to him so i know it was good) they never adjusted the subsonic filter for the ported box and that seemed to fix it.
he was getting rid of the stuff so i bought it back, put it in a sealed box and it worked fine in my Car for 6 months,
going a diffrent route now and he wanted it back so just installed it back in his Car yesterday & getting a pop sound only once in a while and not on every song.
they are powering the loc from the amp`s +12, could this be the problem? i am going to run him a new pwr Wire for the loc, but not sure that is the issue.
i never had that popping sound before the sale or after i got it back. (i had the sub/amp for several years)
could it be the cheap loc they used?
was thinking maybe getting him LC2i to replace it
sorry for the long post but thought that info. was useful
mike
truckstoy is offline   Reply With Quote Quick reply to this message
Old 04-19-2013   #2
minbari's Avatar
DIYMA super monkey!
Rep Power: 192 minbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to all
Default Re: Strange popping sound from sub!
most LOC are just isolation transformers. there is really nothing to pop. does it do this noise at all volumes or just high volume?
do you have a different sub or amplifier to test with?
try connecting an mp3 player to the sub amplifier directly and see if the noise goes away.
Original post whore!
Bent Nail Brewery
2013 Fiesta, Stock Sync HU |AC LC2i | Phoenix Gold EQ215i | Soundstream SA120 -> ID CD1eMH | Phoenix Gold T500.2 -> ID X65 | JL 500/1 -> (2) 15" Pyle PL1590BL in IB
Old 04-19-2013   #3
i think only @ high volumes when there are low bass notes
no, not @ the moment
had all that gear in my Car & never happened once, so that is why i think it is in the install/wireing that they did or maybe in the signal from the stock h/u or the Speaker they tapped for the loc
Old 04-19-2013   #4
minbari's Avatar
DIYMA super monkey!
I would do the mp3 player test. a simple 3.5mm to rca cable and eliminate the entire Car as a sound source.
if it still makes the noise, then Power wire, amplfier, or sub are the problem. if it goes away, you know it is the LOC or the HU.
Bent Nail Brewery
Old 04-19-2013   #5
o.k. thanks will try that
Old 04-19-2013   #6
minbari's Avatar
DIYMA super monkey!
Originally Posted by murphman View Post
you were also running a sealed box in your car- sounds like the amp is losing control of the sub at high volumes in the ported box....
lol, amplifiers dont lose control of speakers.
He said he uses an appropriate SSF, so the sub should be protected. The W7 is pretty sturdy, too. (not too say it cant be damaged)
Bent Nail Brewery
Old 04-19-2013   #7
no, he used to have a ported box, i built a sealed box and that is what the sub is in now
Old 04-19-2013   #8
Get a new sub that can handle the Power or turn it down.
Old 04-19-2013   #9
i know the sub/amp are good i had it in my Car like a month ago, never heard any strange sounds
it is only when it is installed in his Car ( i didn't do the inital install some audio place did)
i wasn't sure is the way they are feeding the +12 to the loc could be the issue. they are tapping the amps +12 . figured that would cause some sort of loop
Old 04-19-2013   #10
the sub can easily handle the Power of the amp and the gain is set low.
Old 04-19-2013   #11
minbari's Avatar
DIYMA super monkey!
not likely. those LOCs take miliamps of current. If you had the model It would help.
if you are not sure, just run a temporary Wire to the battery for the LOC, if you eliminate it as a probable cause.
Bent Nail Brewery
Old 04-19-2013   #12
Rep Power: 90 dvsntt will become famous soon enoughdvsntt will become famous soon enoughdvsntt will become famous soon enoughdvsntt will become famous soon enoughdvsntt will become famous soon enoughdvsntt will become famous soon enough
It's not ideal, they should have used a distribution block, or obtained a single run of a fused 12v line from the fuse panel, but splicing it from the amp should not introduce a noise, especially a pop. It may be worth doing right though since you are I there, and maybe it will fix it, I have been wrong before, probably twice today.
dvsntt is offline   Reply With Quote Quick reply to this message
Old 04-19-2013   #13
Maylar's Avatar
Rep Power: 54 Maylar will become famous soon enoughMaylar will become famous soon enoughMaylar will become famous soon enoughMaylar will become famous soon enoughMaylar will become famous soon enoughMaylar will become famous soon enough
Could the sub be hitting xmax in the ported box?
JVC KW-HDR720, Audiocontrol EQL, HAT Imagine 5.25 Mids & Morel Maximo tweets, PPI 900.4 Amp, BA 6X9 Rear Fill, Boston G310 sub in 1/2 cu ft sealed -
1999 Buick Park Ave Ultra
Maylar is offline   Reply With Quote Quick reply to this message
Old 04-19-2013   #14
Popping noises are from ??
I mean other than a totally beat to death Speaker or too much Power ?
Old 05-23-2013   #15
Update
JL audio suggested that it could be his car's electrical system not being able to give the amp enough power. told him he needed a new alt or better battery. we tried adding a capacitor to maybe help but it didn't. So i ended up taking the gear back, I installed back in my Car the same way he has it and it runs perfect, no poppig sounds eevn on the same songs he had them on. so i know my gear is good.
thanks for all the help! now have to see what i am going to do w/ this stuff.
Old 05-23-2013   #16
Rep Power: 53 syc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enough
Update
Did u use a voltmeter to check the voltage, or did u u just assume that was the problem?
Old 05-23-2013   #17
BuickGN's Avatar
Rep Power: 160 BuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to behold
Thanks for the follow up. There's no way that sub was bottoming with over 4" of peak to peak travel. It would hit its thermal limit first. I was curious if it was the install or the cars electrical system in your friends Car but at least the sub has a better home now.
'84 GN 10.60@ 127mph.
'07 Epic Expert
'06 TL.
Old 05-23-2013   #18
no, he was supposed to have that checked @ an audio shop but he never got around to it. people just kept saying the sub was blown! so i took it back so i could test it. it works fine back in my car. so it is either his Car or the wiring they did. I have never heard a noise like that, it was an electrical buzz/pop on certin notes. I thought if it was the sub it would make stange sounds all the time. I will have a shop verify that the sub/amp are good before i do anything w/ them. i would like to resell them as i have no need for them.
