Helix DSP Pro - Who has info? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 09-14-2014   #1
Architect7's Avatar
SQ Crazy
Rep Power: 109 Architect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enough
Default Helix DSP Pro - Who has info?
I see the upcoming Helix DSP Pro has been mentioned in the Helix DSP thread but I'd like to start a new discussion for this dsp. Anyone have info like pricing, DAC/DSP chip #'s, opamp specs, IO capability, etc.? I will possibly be in the market for a high end DSP and want to consider all options before committing to my final solution. Thanks in advance!
Architect7 is offline   Reply With Quote Quick reply to this message
Old 09-14-2014   #2
Classifieds Access
Huckleberry Sound's Avatar
Rep Power: 109 Huckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enough
Default Re: Helix DSP Pro - Who has info?
I'm reading!!!
Huckleberry Sound
Huckleberry Sound is offline   Reply With Quote Quick reply to this message
Old 09-14-2014   #3
Rep Power: 111 subterFUSE will become famous soon enoughsubterFUSE will become famous soon enoughsubterFUSE will become famous soon enoughsubterFUSE will become famous soon enoughsubterFUSE will become famous soon enoughsubterFUSE will become famous soon enoughsubterFUSE will become famous soon enough
All I know is what has been posted on the Helix facebook page.
But I'm planning to put this in my Car ASAP.
It's supposed to be released this month.
2013 Audi S6 Quattro
Old 09-14-2014   #4
Architect7's Avatar
SQ Crazy
Cool, I was not aware of the Facebook posts. Here's what they've reported so far:
10 output channels at 6v
56 bit DSP chip
96khz
Built in sampling frequency converter gfor up to 192khz input
Up to 8 channels of low/high level inputs
Optical/coax digital inputs
2 channel AUX input
Expansion slot
30 band eq per channel
.25db eq steps
3.5mm TA steps
10-44khz response
0.000568% THD
116db SNR digital input
108db SNR analog input
Crosstalk >90db
https://www.facebook.com/pages/Brax-...ref=ts&fref=ts
Old 09-14-2014   #5
Bikinpunk
Rep Power: 25973 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
I have one on order and was told by my local dealer the realistic ETA may be December. Initially the Facebook page said September, IIRC.
Follow my blog:
http://medleysmusings.com/
Time Delay Calculator:
Old 09-14-2014   #6
Classifieds Access
Thats cool.
That is right about the time money from gifts start rolling in!!!
Huckleberry Sound
Old 09-14-2014   #7
Awww man. That really stinks for me. I'm up against a serious time crunch to get my system upgrade complete before I move out-of-state. No chance I can wait that long. Will have to install the PS8 I have waiting on the sidelines.
Old 09-14-2014   #8
Bikinpunk
Just get the current helix. Unless you really need 10 channels as that's the biggest difference. That's what I run. The only real reason I'm upgrading is to run rear fill.
Follow my blog:
Old 09-14-2014   #9
Classifieds Access
We will notice people will make the jump to the Heix Pro. Which is fine if you plan on using all the functions of it.
Huckleberry Sound
Old 09-14-2014   #10
I was hoping for other upgrades, actually. Like more than 2 presets for switching between settings, more digital inputs and a better controller solution.
I am going to be running a MoBridge DA1 and an Audison BitPlay HD as my sources. Ideally, both would run digital... but that really depends on the DSP. If I use the PS8 then I'll have to get a DAC for the MoBridge because there is no way to use 2 different digital sources on that unit.
Old 09-14-2014   #11
Wow... finally a 10ch DSP. I'm so getting this when it's released. Saves me the hassle of tuning rear channels from the P99...
I assume it's a true parametric EQ?
Old 09-14-2014   #12
Yes. It will be at least a 30 band parametric EQ. And it's possible there will also be phase angle adjustments independent of time alignment. The sub channel will certainly have that, but I wouldn't be surprised if all channels did.
Old 09-14-2014   #13
Diyma Ninja
Rep Power: 247 thehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud of
If it had 30 bands parametric EQ and phase on more channels, then there wouldn't be anything like it on the market for the car.
Old 09-15-2014   #14
A-Ron's Avatar
DIYMA Browser
Rep Power: 88 A-Ron will become famous soon enoughA-Ron will become famous soon enoughA-Ron will become famous soon enoughA-Ron will become famous soon enoughA-Ron will become famous soon enoughA-Ron will become famous soon enough
Sub'd!
A-Ron is offline   Reply With Quote Quick reply to this message
Old 09-16-2014   #15
Classifieds Access
I just received contact that they will release it by the end of the month.
Time will tell and we will see.
Huckleberry Sound
Old 09-16-2014   #16
A-Ron's Avatar
DIYMA Browser
I need to find a dealer near New Orleans... Anyone know of one?
Old 09-19-2014   #17
Rep Power: 127 wdemetrius1 will become famous soon enoughwdemetrius1 will become famous soon enoughwdemetrius1 will become famous soon enoughwdemetrius1 will become famous soon enoughwdemetrius1 will become famous soon enoughwdemetrius1 will become famous soon enough
What's the cost?
2012 MECA World Finals Street National Runner Up!!!
2012 MECA Street National Points Champion!!!
2012 MECA Street Georgia State Champion!!!
2011 MECA Street Georgia State Champion!!!
wdemetrius1 is offline   Reply With Quote Quick reply to this message
Old 09-19-2014   #18
Rep Power: 141 miniSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the rough
any idea when the 3.0 software will be released?
2013 Hyundai Elantra GT
HelixDSP / Director
PG Elite.5
KAXBLTWT/Sinfoni Maestoso
IDQ8
miniSQ is offline   Reply With Quote Quick reply to this message
Old 09-19-2014   #19
Originally Posted by wdemetrius1 View Post
What's the cost?
Expected to be around $1000
Old 09-19-2014   #20
Classifieds Access
I will be curious to see if they remove the previous version of the processor from there line up.
Huckleberry Sound
Old 09-19-2014   #21
doubtful they will replace a $600 processor with a $1000 processor and eliminate the $600 one. 8 channels should be fine for 90% of the people.
HelixDSP / Director
PG Elite.5
IDQ8
Old 09-19-2014   #22
SkizeR's Avatar
DIYMAddict
Rep Power: 192 SkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the roughSkizeR is a jewel in the rough
Is there any this this can do that the other helix dsp can't do? (Besides the ten channels)
1990 300zx Build Log
Old 09-19-2014   #23
Architect7's Avatar
SQ Crazy
db increment and THD are both improved with the Pro according to their updates. Not sure what else...
Old 09-19-2014   #24
Coppertone's Avatar
DRKNESS
Rep Power: 123 Coppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of light
I agree that 90% of the people will be fine with the regular one. It's the elitist that will take it to the next level with the Pro. Either that or those who convince themselves that one day they will run 10 channels ( hint hint ) lol.
(2.5GT) Limited Legacy / Alpine INA-W910 / Alpine PXA-H800 / Alpine C800 / Sinfoni T25T / Sinfoni T65W / Brax X2400.2 / Brax X2000.2 / JL Audio 12TW3-D4
(Ram 1500) Clarion NX706/ Sinfoni Tempo 10 / Sinfoni T65W / Sundown Audio 12" SD-3 / Alpine PDX V9
Old 09-19-2014   #25
SkizeR's Avatar
DIYMAddict
Is that really worth the extra 400?
