Need 13 Band EQ Step Formula - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-11-2017   #1
Rep Power: 9 Swaglife81 will become famous soon enoughSwaglife81 will become famous soon enoughSwaglife81 will become famous soon enoughSwaglife81 will become famous soon enoughSwaglife81 will become famous soon enoughSwaglife81 will become famous soon enough
Default Need 13 Band EQ Step Formula
I think the title is the correct title. When searching EQ forumulas I'm only seeing 10-11 band or 31 band formulas. I have a Pioneer X2800BHS with a 13 band.
What I'm looking for is the formula used for 13 bands of EQ. Pioneer usually goes from 50 - 80 - 125 - 200 and so on. What I want to know is when boosting or cutting let's say 50 is it 50 and below equally or is it split with the next frequency that's 80 so would bumping 50 go up to the halfway point in between 80 boosting to 65. And the 80hz boost ING or cutting starts with 65,66 and up. I don't have experience a DSP, gonna tune what I can with crossover, slopes, and graphical EQ. I'll use my ear first and try RoomEQ or some type of software to see what I'm hearing. I've searched everywhere and see different EQ steps like Kenwood starts at 60 or another brand starts at 30. Hope this makes sense what I'm asking for. I obviously know a 31 band L/R EQ is much better. I want to crawl before walking and I think I can get a great user experience for starters without going DSP just yet. I have a full Build in front of me as soon as I find the raw 6.5's I want that are actually in stock (TM65 or Dayton DSA175, etc etc.
Swaglife81 is offline   Reply With Quote Quick reply to this message
Old 01-11-2017   #2
Hillbilly SQ's Avatar
iNCORRECT pOLITICALLY
Complacent Audio
Incoherent rambler
Rep Power: 247 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Default Re: Need 13 Band EQ Step Formula
Best way would be to do the install and then boost and cut each frequency with rta going. At least that's how I would do it to find out how it's set up. I've put thought into this and this is one of the reasons I don't like graphic, but they're great for nudging the tonality curve after the main tune is done with an outboard dsp.
Hillbilly SQ is online now   Reply With Quote Quick reply to this message
Old 01-11-2017   #3
fcarpio's Avatar
Hungry all the time
Rep Power: 138 fcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enoughfcarpio will become famous soon enough
You can buy something like this for 15 bucks:
Dayton audio iMM-6 Calibrated Measurement Microphone for Tablets iPhone iPad and Android
Then download an app like this one:
https://play.google.com/store/apps/d....net.rta&hl=en
Then do what Hillbilly SQ is suggesting.
fcarpio is offline   Reply With Quote Quick reply to this message
Old 01-11-2017   #4
Jazzi's Avatar
Acoustical Mad Scientist
Rep Power: 81 Jazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura about
The graphic equalizer will effect the center frequency the most (80hz in your example) and it will also effect frequencies above and below the center frequency. The amount of cut or boost to adjacent frequencies will reduce the further away from the center frequency. So 81hz will be changed just about the same as 80hz will be, but 100hz or 63hz will be changed much less so. The frequencies above and below the center frequency are adjusted equally in this regard.
Each frequency band has a property called Q which describes how wide or narrow the band is, which effects how much the adjacent frequencies are effected. A smaller Q means a wider band, which is what you will find in equalizers will less bands to choose from (like a 7-band, or in your case a 13-band). An equalizer with many bands to choose from, like a typical 31-band, will have a larger Q for each band meaning each band will effect only the close neighbors (in this case, a 31-band equalizer usually has a Q just slightly above 4.0).
If you adjust two bands that are adjacent, such as the 80hz and 100hz bands, then the effect of both bands will overlap a little bit. Also, a graphic equalizer is one where the frequencies and Q values are preset and not adjustable. A parametric equalizer means you can change the center frequencies and the Q values to get much more precise control (but also infinitely more ways to get it wrong if you're not sure what you're doing).
The last minute or so of this video shows what a 31-band EQ looks like when you adjust the 80hz band (starting at 9:33)
https://youtu.be/DKdpOLh78SU?t=573
Does that help?
Old 01-12-2017   #5
Appreciate it guys. Helped alot, sadly I wish there was a exact type of formula one could see.
Old 01-12-2017   #6
Jazzi's Avatar
What sort of formula are you looking for? Do you want some equations or math that describes this?
Old 01-12-2017   #7
Rep Power: 60 Jepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enough
What I'm looking for is the formula used for 13 bands of EQ. What I want to know is when boosting or cutting let's say 50 is it 50 and below equally or is it split with the next frequency that's 80 so would bumping 50 go up to the halfway point in between 80 boosting to 65.
Your EQ conceptually consists of 13 constant-Q bandpass filters centered on each band's frequency. 'Constant-Q' means the bandwidth of each filter is constant regardless of the amount of boost or cut.
Your manual spec's the EQ like this:
Frequency: 50Hz, 80Hz, 125Hz, 200Hz, 315Hz, 500Hz, 800Hz, 1.25kHz, 2kHz, 3.15kHz, 5kHz, 8kHz, 12.5kHz
Gain: ±12dB 2dB step
We cannot provide an exact formula without knowing what the 3dB BW and filter-order of your EQ is.
This pic is not your EQ, but it gives you a general idea of how the filter responses overlap...
>signature goes here<
Jepalan is offline   Reply With Quote Quick reply to this message
Old 01-12-2017   #8
Jazzi's Avatar
That's a great picture to show the overlap. Where did you find it? I was hoping to share something similar but couldn't find such a thing.
Old 01-12-2017   #9
Rep Power: 26 soundstreamer will become famous soon enoughsoundstreamer will become famous soon enoughsoundstreamer will become famous soon enoughsoundstreamer will become famous soon enoughsoundstreamer will become famous soon enoughsoundstreamer will become famous soon enough
That's some helpful information as I will probably doing the same thing the OP is doing. I have the same head unit and want to adjust it as best I can until I get a DSP. Since I'm going active as well would it be good to set the output level of each Speaker still or will that matter much? I'm new to this so I hope it's not a stupid question.
soundstreamer is offline   Reply With Quote Quick reply to this message
