Install Help - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-20-2017   #1
Rep Power: 0 Tire Guy will become famous soon enoughTire Guy will become famous soon enoughTire Guy will become famous soon enoughTire Guy will become famous soon enoughTire Guy will become famous soon enoughTire Guy will become famous soon enough
Default Install Help
I have a Rockford Fosgate R2 shallow mount 10" sub which is 400 watts-200 RMS. My mid and tweets are also fosgate set up. My amp is an Autotek 1050.4 which is RMS power 125x4@4 ohms-250x4@2 ohms and bridged it is 500x2, but only on 2 channels. My problem is that when the sub is wired in either series or parallel and I attempt to bridge the amp on channels 3/4 the amp will shut down and go into protection. I have done everything that I know to do, however, it has been at least 15 years since I have put a stereo in. I am fairly certain that it is something simple that I am overlooking. I can unhook the sub and the amp will run the mids and highs no problem. Any help would be appreciated, I am at my wits end. Sorry I also have 8 gauge wire running everything.
Tire Guy is online now Report Post
Tire Guy is offline   Reply With Quote Quick reply to this message
Old 04-20-2017   #2
Rep Power: 96 Sine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enough
Default Re: Install Help
The amp runs fine without the sub hooked up?
Will the amp run fine if you swap the mids/tweeters to channels 3/4?
I would also consider running 4 gauge wire to that amp instead of 8 gauge.
A true 1000 RMS amp will need more than 8 gauge wiring.
Kenwood DNX5120 - MS8 - 2 x PPI Art Ax400 - JBL GTO 1200.1ii - Scanspeak Illuminator R3004/6020 - Morel CAW938's - 2 x JBL P1222
Old 04-20-2017   #3
My bad I see the amp is rated at Max power, not RMS.
Try swapping to 3/4 and see if it still runs
Old 04-20-2017   #4
Thank you for your feedback. Yes the mids and highs still work on channels 3/4 just when the sub is hooked up is when i starts cutting off. at low volumes it sounds great and when i turn it up to a louder volume it goes into protection.
Old 04-21-2017   #5
Do you have multimeter? If not a $15 one will probably do just fine.
Set to ohms and measure the speaker load.
It should be 4 ohms if you are bridging it as the amp is not designed for less in bridged mode.
Does it cut out still if you turn the gain down?
Old 04-21-2017   #6
I cannot say that I have had turned all the way down and tried that. It also does it with the bluetooth being on and the all the way up....not sure how that could be connected but it does. Sorry just trying give all the details
