rattle in door rods - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 6 Days Ago   #1
Rep Power: 45 eddie7978 will become famous soon enougheddie7978 will become famous soon enougheddie7978 will become famous soon enougheddie7978 will become famous soon enougheddie7978 will become famous soon enougheddie7978 will become famous soon enough
Default rattle in door rods
my civic has these rods that connect to the door lock and it rattles like crazy is there any fix for this?
eddie7978 is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #2
Rep Power: 74 seafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enoughseafish will become famous soon enough
Default Re: rattle in door rods
An effective way to deal with that is to wrap the rods in a thin, closed cell foam in a way that does no interfere with their operation. You can use self adhesive foam and roll it over the rods or regular foam and use zip ties to hold it in place around the rods. If the rattle is also coming from where the rod inserts in the bracket you can use a piece of butyl rubber rope to "sandwich" the bracket around the rod...the butyl rubber rope is very sticky but also stretchy so it will still allow the rod/bracket to operate while still damping vibration.
seafish is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #3
Rep Power: 0 Gouki will become famous soon enoughGouki will become famous soon enoughGouki will become famous soon enoughGouki will become famous soon enoughGouki will become famous soon enoughGouki will become famous soon enough
I had a 99 Si that was doing the same thing. I ended up using ensolite foam around the connection points, but it was tricky getting them just right so it wouldn't encumber the the locking mechanism. Also sound deadening the doors helped as well.
I currently use this stuff:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
And am partial to the Stinger version of Dynamat due to its value:
https://smile.amazon.com/Stinger-RKX...inger+roadkill
36 square feet for 86 Murican.
Gouki is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #4
i have some ccf maby ill try that i just thought it would me too thick.. there's no kind of special tape they make for this issue?
Old 6 Days Ago   #5
Theslaking's Avatar
DIYMA member
Rep Power: 59 Theslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enoughTheslaking will become famous soon enough
Pull the rod out of the bracket near the lock. Put a dab of 100% silicone in the plastic hole and the put the rod back in. Let it dry. Once the caulk is dry break the rod free by hand in the natural movement of the rod. Reconnect the handle and live the rattle free life. Another trick is bearing grease but that only works for a few years. The silicone works very well.
The best way to dummy proof is to get rid of the dummies
Theslaking is online now   Reply With Quote Quick reply to this message
Old 5 Days Ago   #6
Rep Power: 9 llebcire will become famous soon enoughllebcire will become famous soon enoughllebcire will become famous soon enoughllebcire will become famous soon enoughllebcire will become famous soon enoughllebcire will become famous soon enough
Great idea!
So the silicone dries and creates a "cushion" and as 100% silicone caulking is naturally slippery it doesn't bind?
Genius.
-Eric
llebcire is offline   Reply With Quote Quick reply to this message
Old 5 Days Ago   #7
Approved Vendor
Second Skin
owner
Rep Power: 88 Second Skin is on a distinguished roadSecond Skin is on a distinguished roadSecond Skin is on a distinguished roadSecond Skin is on a distinguished roadSecond Skin is on a distinguished road
Cover the rods in closed cell foam like our 1/8" Over Kill Pro
Good luck with your build.
Team Second Skin
Second Skin is offline   Reply With Quote Quick reply to this message
