I'm a noob looking for some sound advice from the experts. Looks like I'm in the right place...
My awesome plan was to upgrade my OEM speakers to Focal ES 165 KX2 (2ohm) components. After reading around this forum I decided I needed to go "active", so I figured I'd buy a DSP, four channel amplifier - and ditch the crossovers.
I've ordered the Focal FPX 4.400SQ and was planning to buy a miniDSP C-DSP 6x8. Now I'm regretting this decision, because I'm probably trying to complicate things for what - a 10% better experience going active?
I'd like to know if I can safely bridge this amplifier into two channels and run passive before I drop cash on a DSP. Can you interpret the amplifier specifications and tell me if this is possible?
CEA power (4 ohms): 4x70 Watts RMS
Max. power (2 ohms): 4x100 Watts RMS
Max. power (4 ohms bridged): 2x200 Watts RMS
There is no spec for bridged 2ohm. If I bridge to two channels and run the 2ohm components with crossovers, is that "4ohms bridged"?
Thanks for any advice you guys have, including - "Why would you ever go passive you moron" - I'll take that too.
