Car Audio Forum
Car Audio Classifieds
12v Glossary
AmpGuts.com
Buy Car Audio
Advertise
Register
Upgrade Your Account
My Threads
Search
Today's Posts
DIYMA Car Audio Forum
Glossar
12v Glossary
Username:
Remember Me?
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Page 1 of 26
6
7
8
9
10
11
12
13
14
15
16
21
Last
Search entries
Advanced Search
Table of content
Add new entry
Show
630
results
The search took
0.02
seconds.
Search entries
Added on
Entry
Added by
Last Edit
03-28-2012
09:35 PM
A-B Test
A test of performance between two components. For example, a test of ambient noise between two different amplifiers can be compared. For the test to...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
ABX Comparator
A device that randomly selects between two components for subjective testing. The listener doesn't know which devise is being listened to. A high...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
AC
See Alternating Current.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
AC-3
Acronym for Audio Codec-3. Perceptual coding data reduction system developed by Dolby Laboratories to deliver six discrete audio channels (Left,...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Accessory (Position)
Refers to the position of the key in the ignition switch; a wire showing 12 Volts (+) when in this position.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Acoustic Absorption
The sound deadening properties of any substance, measured in Sabine units. One Sabine is equal to the absorption of one square foot of surface, which...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Acoustic Feedback
A squealing sound when the output of an audio circuit is fed back in phase into the circuit's input.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Acoustic Suspension
A sealed or closed box speaker enclosure.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Acoustical Energy
Energy consisting of fluctuation waves of pressure called sound waves.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Acoustics
The study of sound. It's the science of the production, effects, and transmission of sound waves through various mediums and the effects of...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Active Arming
A method for arming a security system that requires some action, such as pressing a button on a remote transmitter or entering a code on a keypad.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Active Crossover
An electronic circuit that divides a line level audio signal into two or more frequency bandwidths and routes each to their appropriate amplifier.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Active Display
A step-up display feature that generates animated patterns for both segment and dot matrix LCDs that precedes the sequential display of information,...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Active or Powered Subwoofer
A subwoofer system that includes a built in amplifier(s).
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
A-D Convertor
Electronic circuit that converts an analog audio signal that varies in amplitude into a digital signal, read as a numeric code created by series of...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
AES/EBU
Balanced digital connection. For example, it's used to connect a CD transport to a DAC. The AES/EBU standard uses XLR type connectors.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Air Gap
The space between the top plate and the pole piece. This is where the voice coil sits.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Aliasing Noise
The result of the sampling frequency not being at least double the highest analog frequency during the digital encoding of an analog signal.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alignment
A class of enclosure parameters that provides optimum performance for a woofer with a given value of Q.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alpha
Term used in sealed enclosure designs to mean the ratio of Vas to Vb, where Vb is the volume of the box you will build.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alternate-Channel Selectivity
A measurement of a tuner's ability to select one radio station's signal and reject the signal of another radio station two channels (0.4 Mhz) away....
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alternating Current (AC)
An electrical current that reverses direction, alternating between positive and negative at a constant frequency. The rate of change is measured in...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alternator
A device that is turned by a motor to produce AC voltage, which is then rectified (turned into DC) and used to supply voltage to the vehicle's...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Alternator Whine
A siren-like whining that is heard when the RPMs of an engine increase. The noise is usually the result of a voltage differential created by more...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Ambience
The acoustic characteristics of a space with regard to reverberation or sound reflection. A room with a lot of reverb is said to be "live,†one...
[Read more]
03-28-2012
09:35 PM
by
Page 1 of 26
6
7
8
9
10
11
12
13
14
15
16
21
Last
You
are allowed
to add new entries.
You
are allowed
to upload new attachments.
You
are not allowed
to edit your entries.
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
12v Glossary
Powered by
ForumFactory
05:27 PM
-- DIY Mobile Audio
-- Mobile Skin
Contact Us
DIYMA.com - Car Audio Forum & 12 volt Community Board
Archive
Search Engine Optimization by
vBSEO
3.6.0
Ad Management by
RedTyger
Meet Our Team
Forum
Privacy and Rules
Advertise
Archive
Search
Contact Us
Home
User CP
Members List
New Posts
ITrader
Faq
Post Spy
