Car Audio Forum
Car Audio Classifieds
12v Glossary
AmpGuts.com
Buy Car Audio
Advertise
Register
Upgrade Your Account
My Threads
Search
Today's Posts
Car Audio | DIYMA.com
Glossar
12v Glossary
Username:
Remember Me?
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Search entries
Advanced Search
Table of content
Add new entry
Show
23
results
The search took
0.02
seconds.
Search entries
Added on
Entry
Added by
Last Edit
03-28-2012
09:35 PM
EBP
Acronym for Efficiency Bandwidth Product. A guide to determine whether a loudspeaker is more suitable for a sealed or ported enclosure. An EBP of...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Effects Loop
A signal path that allows an audio processor to be switched in and out of the signal path, such as an equalizer (reverb, time delayed, echo, etc.).
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Efficiency
The ratio of energy output to total energy input, expressed as a percentage. With speakers, this refers to the ratio of total acoustic watts radiated...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Efficiency Rating
The loud speaker parameter that shows the level of sound output when measured at a prescribed distance with a standard level of power fed into the...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
EL-Backlight
Electro-luminescent illumination for the lighted portion of a liquid crystal display. Considered to be a step-up featured display.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electrolyte
The name for the mixture of diluted sulfuric acid found in standard lead-acid vehicle batteries.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electrolytic Capacitor
A capacitor with a negative and a positive terminal that only passes alternating current.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electromagnetic Field
A field of magnetic energy in the woofer's voice coil created by the audio signal passing through the wire.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electromagnetic Interference (EMI)
The interference caused by an electromagnetic field created by the flow of current.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electronic Crossover
A type of frequency filter that uses active circuitry along with passive components to filter out the desired frequencies. More efficient than...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Electrostatic Loudspeaker
A speaker that radiates sound from a large diaphragm that is suspended between high-voltage grids.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Enclosure
A box housing a speaker to separate the front sound waves from the rear sound waves.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Enhanced Protection Circuitry
A feature designed to help prevent a device from voltage, current, and temperature faults.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
EQ File
A Custom File feature that allows a user to assign an equalization curve preset to a particular disc, so that when the disc is loaded, that EQ preset...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Equalization
The process of changing the frequency balance of a signal so acoustical energy is proportional to the electrical input (or any type of relative...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Equalizer
A component designed to alter the frequency balance of an audio signal; an electronic set of filters used to boost or attenuate certain frequencies....
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Equalizer Presets
Preset EQ curves are stored tone setting. Boosting and cutting different frequencies can make big changes in the way your music sounds. Preset EQ...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
ESN
A cellular phone's Electronic Serial Number.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
ESP
Acronym for Electronic Shock Protection. An electronic circuit that stores the audio data stream from a CD or MD in a memory buffer. If the laser...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Euphonic
Pleasing. As a descriptive audio term, usually refers to a coloration or inaccuracy that non-the-less may be sonically pleasing.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
European Tuning
The European tuning interval of .05 MHz is different from the U.S. tuning interval of .2 MHz. If a CD receiver also has European tuning, it is...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Exa (E)
A prefix meaning 1018 or 1,000,000,000,000,000,000.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Extension
How extended a range of frequencies a device can reproduce accurately. Bass extension refers to how low a frequency tone will the system reproduce,...
[Read more]
03-28-2012
09:35 PM
by
You
are allowed
to add new entries.
You
are allowed
to upload new attachments.
You
are not allowed
to edit your entries.
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
12v Glossary
Powered by
ForumFactory
10:33 PM
-- DIY Mobile Audio
-- Mobile Skin
Contact Us
DIYMA.com - Car Audio Forum & 12 volt Community Board
Archive
Search Engine Optimization by
vBSEO
3.6.0
Ad Management by
RedTyger
Meet Our Team
Forum
Privacy and Rules
Advertise
Archive
Search
Contact Us
Home
User CP
Members List
New Posts
ITrader
Faq
Post Spy
