# A B C D E F [G] H I J K L M N O P Q R S T U V W X Y Z
Create new entry
Show 12 results
The search took 0.01 seconds.
  Added on Entry Added by Last Edit Reverse Sort Order
03-28-2012 09:35 PM
1) The amount of amplification used in an electrical amplifier circuit. 2) To increase in level. 3) The function of a volume control.
03-28-2012 09:35 PM
by DIYMA Go to entry
03-28-2012 09:35 PM
The diameter of a wire. The higher the number, the thinner the wire.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Two quantities are in the golden ratio if the ratio of the sum of the quantities to the larger quantity is equal to the ratio of the larger quantity... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A googol is the number 10100, that is, 1 followed by one hundred zeroes.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Listening term. A sonic analog of the grain seen in photos. A sort of "grittiness" added to the sound.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Refers to a type of equalizer with sliding controls that create a pattern representing a graph of frequency response changes.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
1) An electrical line with the same electrical potential as the chassis of the vehicle, most commonly -12 volts DC. 2) Refers to a point of (usually)... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The condition created when two or more return paths for electricity are created in a ground line, or when one or more grounding paths are created in... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
In an automobile this is the electrical potential of the vehicles chassis, specifically the chassis of the alternator when the vehicle is running. A... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
It is a measurement of the average delay of the filter as a function of frequency. It is the negative derivative of the filters phase response.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
GWA
Acronym for Ground While Armed or Ground While Active.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
GWR
Acronym for Ground While Running.
03-28-2012 09:35 PM
Create new entry
You are allowed to add new entries.
You are allowed to upload new attachments.
You are not allowed to edit your entries.
