Car Audio Forum
Car Audio Classifieds
12v Glossary
AmpGuts.com
Buy Car Audio
Advertise
Register
Upgrade Your Account
My Threads
Search
Today's Posts
Car Audio | DIYMA.com
Glossar
12v Glossary
Username:
Remember Me?
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Search entries
Advanced Search
Table of content
Add new entry
Show
22
results
The search took
0.03
seconds.
Search entries
Added on
Entry
Added by
Last Edit
03-28-2012
09:35 PM
Haas Effect
In 1951, Dr. Helmut Haas examined how the perception of speech is affected in the presence of a single, coherent sound reflection. In sound systems,...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Harmonic
A weaker overtone or undertone of the original note responsible for the character of the note.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Harmonic Distortion
Harmonics artificially added by an electrical circuit or speaker. They are generally undesirable. It is expressed as a percentage of the original...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Harmonics
The multiple frequencies of a given sound, created by the interaction of signal waveforms. Also called overtones, these are vibrations at frequencies...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Harness
The universal name for a bundle or loom of wires that compose the wiring for a system.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
HDCD
Acronym for High-Definition Compact Disc. A proprietary system by Pacific Microsonics that requires special encoding during the recording process....
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Headroom
The ability of an amp to go beyond its rated power for short durations in order to reproduce musical peaks without distortion. This capability is...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Head Unit (HU)
The in dash control center of a car audio system. This may be any pre amp or amplified control unit such as an AM/FM/CD player.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Hearing Sensitivity
The human ear is less sensitive at low frequencies than in the midrange. Reducing volume will cause the listener to notice how the bass seems to...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Heat Dissipation
The ability to transfer heat away from a component into the air to prevent damage.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Heat Sink
A device for dissipating heat from a transistor or amplifier.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Henry/Henries (Hy)
The measurement for inductance. Coils (low pass filters) are measured in milli henries as in 6.4 mHy (6.4 millihenries).
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Hertz (Hz)
The unit of measurement for frequency. 1 Hz is equal to 1 cycle per second.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
HID
Acronym for High Intensity Discharge.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
High Frequency Driver
A loudspeaker specifically designed to reproduce short, high-frequency wave lengths. The driver typically has a small, lightweight diaphragm.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
High Level Input
An input configured to accept speaker level signals.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
High Pass Filter (HPF)
A network of elements used to attenuate all frequencies below a predetermined frequency. Frequencies above the cutoff point pass without any effect.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Highs
Term that refers to a set of speaker components used to reproduce frequencies above 500 Hz as in a set of separates. May also refer to tweeters which...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Hiss
Background audio noise often associated with tape audio formats. Most noticeable at low signal levels and high gain amplification. Audio noise that...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Home Theater
An audio system designed to reproduce the theater sound experience while viewing film at home. Minimally consisting of a Dolby Pro Logic® surround...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Horn(s)
A speaker designed using its own funnel shaped conduit to amplify, disperse of modify the sounds generated by the internal diaphragm of the speaker.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Hum
An audio noise that has a steady low frequency pitch. Often associated with ground loop issues or poor filtering capacitors in preamp or amplifier...
[Read more]
03-28-2012
09:35 PM
by
You
are allowed
to add new entries.
You
are allowed
to upload new attachments.
You
are not allowed
to edit your entries.
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
12v Glossary
Powered by
ForumFactory
06:36 AM
-- DIY Mobile Audio
-- Mobile Skin
Contact Us
DIYMA.com - Car Audio Forum & 12 volt Community Board
Archive
Search Engine Optimization by
vBSEO
3.6.0
Ad Management by
RedTyger
Meet Our Team
Forum
Privacy and Rules
Advertise
Archive
Search
Contact Us
Home
User CP
Members List
New Posts
ITrader
Faq
Post Spy
