# A B C D E F G H [I] J K L M N O P Q R S T U V W X Y Z
Create new entry
Show 24 results
The search took 0.01 seconds.
  Added on Entry Added by Reverse Sort Order Last Edit
03-28-2012 09:35 PM
Acronym for International Auto Sound Challenge Association.
03-28-2012 09:35 PM
by DIYMA Go to entry
03-28-2012 09:35 PM
ICE
Acronym for In Car Entertainment.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Refers to a source of power in the vehicle (controlled by the ignition switch) that has +12VDC on it when the ignition key is both in the run and... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Acronym for Infinite Impulse Response Filter. A digital filter employing a single stage, through which the signal is passed repeatedly to achieve the... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The rejection of the same signals that can be received at two or more points on the dial of a tuner by a single radio station (ghost, images). Image... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The reproduction of sound accurately so that the listener can imagine the original environment and placement of the original sound sources accurately... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Expressed in ohms, impedance represents the resistance to the flow of current in the signal. Impedance includes resistance from any source, including... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The ability to induce an electrical current. Measured in Henrys. The capability of a coil to store energy in a magnetic field surrounding it. It... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Radiated noise that is transmitted through a magnetic field to surrounding lines.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
An electrical component in which impedance increases as the frequency of the AC decreases. Also known as coils that are used in passive crossovers.... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A loudspeaker baffle of infinite space that has no openings for the passage of sound from the front to the back of the speaker. Also, a sealed... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A filter designed to remove extremely low frequencies inaudible by the human ear, usually between 0 to 25Hz.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Two or more signals that have the same waveform and identical amplitude in synchronization.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Connection from signal source (a guitar or microphone) to a preamp and amplifier.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Adjusts the amount of input signal being fed to the amplifier stage to reduce distortion.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A material that electrically isolates a conductor or thermally isolates an object from its surroundings.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
An audio component that combines pre-amplifier elements (multiple inputs, built in tuners, equalization, source switching) and amplifiers in a single... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Cables that are used to connect components at a low signal level. Examples include CD player to receiver, pre-amplifier to amplifier, etc. Most... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The distortion generated in single cone speakers when the cone is reproducing a high and low frequency simultaneously. The high frequency peaks will... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Lets you hear the first few seconds of each track on a CD. Hit the button again when you hear the song you're looking for. The scanning feature will... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Takes the input signal and applies a 180º phase shift.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Enclosure in which one woofer is buried in the enclosure and the other is mounted up against the first and wired in reverse polarity. There are many... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Refers to a mounting system in which the head unit is mounted behind the dash panel with side brackets, employing factory installed trim panels.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Electrical or acoustical separation to prevent the spread of noise and the effect on the signal of unwanted elements produced by internal or external... [Read more]
03-28-2012 09:35 PM
Create new entry
You are allowed to add new entries.
You are allowed to upload new attachments.
You are not allowed to edit your entries.
