# A B C D E F G H I J K L M [N] O P Q R S T U V W X Y Z
Create new entry
Show 11 results
The search took 0.01 seconds.
  Added on Reverse Sort Order Entry Added by Last Edit
03-28-2012 09:35 PM
n0
The reference efficiency of the system (eta sub 0) dimensionless, usually expressed as percent.
03-28-2012 09:35 PM
by DIYMA Go to entry
03-28-2012 09:35 PM
A prefix meaning 10-9 or 0.000 000 001.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A liquid crystal display employing a dark backfield with lit elements. This results in a primarily dark display, which improves cosmetic integration... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The lead or line connected to the negative terminal of a current, voltage, or power source.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A magnet material offering 7.5 times the magnetic strength of standard magnetic materials.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Unwanted sound of no specific frequency or amplitude. Random sound of many frequencies not harmonically related (buzzing, hiss, pops, static, whine,... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The minimum impedance a loudspeaker presents to an amplifier, directly related to the power the speaker can extract from the amplifier.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
What goes into a system comes out changed by its passage through that system-in other words, distorted. The ideal of an audio component and an audio... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Refers to the electrical state in which a switch may rest. Its contacts are held together or closed so that current is allowed to flow through its... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Refers to the electrical state in which a switch may rest. Its contacts are held apart or open so that no current flows through its contacts.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Acronym for National Television System Committee. Refers to the standards used for video broadcast and playback signal parameters.
03-28-2012 09:35 PM
Create new entry
You are allowed to add new entries.
You are allowed to upload new attachments.
You are not allowed to edit your entries.
