# A B C D E F G H I J K L M N [O] P Q R S T U V W X Y Z
Create new entry
Show 9 results
The search took 0.01 seconds.
  Added on Entry Added by Reverse Sort Order Last Edit
03-28-2012 09:35 PM
The United States governmental agency that establishes and enforces safety standards in the workplace.
03-28-2012 09:35 PM
by DIYMA Go to entry
03-28-2012 09:35 PM
1) The interval of eight diatonic degrees between two musical tones. 2) The doubling or halving of frequencies.1000Hz is an octave higher than 500Hz.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Ohm
The unit of electric resistance and impedance. One ohm is the resistance value through which one volt will maintain a current of one ampere.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Current in a circuit is directly proportional to the voltage, and inversely proportional to resistance. It also includes the relationships of watts... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Doubling or quadrupling (or by even a higher factor of 2 squared) the sampling frequency during the digital to analog process to obtain a high... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Because of the phase difference created in the reproduced sound waves. When speakers are mounted in reverse polarity, i.e., one speaker is wired +/+... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The high level (speaker) or line level (RCA) signals sent from one system component to another or the high level signal from an amplifier to the... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
A condition in which a system is given too high of an input level. A common cause of distortion or product failure.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
See harmonics.
03-28-2012 09:35 PM
Create new entry
You are allowed to add new entries.
You are allowed to upload new attachments.
You are not allowed to edit your entries.
