# A B C D E F G H I J K L M N O P [Q] R S T U V W X Y Z
Create new entry
Show 12 results
The search took 0.01 seconds.
  Added on Reverse Sort Order Entry Added by Last Edit
03-28-2012 09:35 PM
A measure of damping. Modern home speaker systems have Q values ranging from < .5 to approximately 2.0. Q values < .7 have no peak in the response. Q... [Read more]
03-28-2012 09:35 PM
by DIYMA Go to entry
03-28-2012 09:35 PM
Qms, Qes, and Qts are measurements related to the control of a transducer's suspension when it reaches the resonant frequency (Fs). The suspension... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qa
The system's Q at Fb, due to absorption losses; dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qec
The system's Q at resonance (Fc), due to electrical losses; dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qes
The driver's Q at resonance (Fs), due to electrical losses; dimensionless. A measurement of the control coming from the speaker's electrical... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Ql
The system's Q at Fb, due to leakage losses; dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qmc
The system's Q at resonance (Fc), due to mechanical losses; dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qms
The driver's Q at resonance (Fs), due to mechanical losses; dimensionless. A measurement of the control coming from the speaker's mechanical... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qp
The system's Q at Fb, due to port losses (turbulence, viscousity, etc.); dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qtc
The measurement of a speaker and enclosure working together as one. The system's Q at resonance (Fc), due to all losses; dimensionless.
03-28-2012 09:35 PM
03-28-2012 09:35 PM
Qts
The measurement of the speaker as a motor taking into consideration all mechanical and electrical losses. The driver's Q at resonance (Fs), due to... [Read more]
03-28-2012 09:35 PM
03-28-2012 09:35 PM
The assigning of values to discrete samples of a continuous signal in the analog to digital conversion process.
03-28-2012 09:35 PM
Create new entry
You are allowed to add new entries.
You are allowed to upload new attachments.
You are not allowed to edit your entries.
