Car Audio Forum
Car Audio Classifieds
12v Glossary
AmpGuts.com
Buy Car Audio
Advertise
Register
Upgrade Your Account
My Threads
Search
Today's Posts
Car Audio | DIYMA.com
Glossar
12v Glossary
Username:
Remember Me?
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Page 1 of 2
Search entries
Advanced Search
Table of content
Add new entry
Show
32
results
The search took
0.01
seconds.
Search entries
Added on
Entry
Added by
Last Edit
03-28-2012
09:35 PM
Tera (T)
A prefix meaning 1012 or 1,000,000,000,000 (one trillion in the US).
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
TFT (Thin Film Transistor)
An Active Matrix Display, a specific type of LCD display in which one to four transistors control each pixel. This technique offers the best...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Thiele/Small Parameters
The numbers that specify the behavior of drivers, as defined and analyzed by two engineers, Neville Thiele and Richard Small.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Three-Way
A type of speaker composed of three ranges of speakers, usually a mid-bass/woofer, mid-range and a tweeter.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Threshold of Pain (in dB SPL)
The minimum value of sound pressure of a given frequency that will cause pain to a listener 50% of the time. Discomfort begins at 105 dB SPL. Actual...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
THX
Acronym for Tomlinson Holman Experiment. Refers to a series of specifications for surround sound systems. Professional THX is used in commercial...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
THX Certification
THX-certified speakers meet the quality-control criteria defined by Lucasfilm, the company formed by George Lucas-creator of the Star Wars and...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Timbral
Refers to the overall frequency balance of a system. In a perfect world, all systems would have complete tonal neutrality. With current technology,...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Timbre
The quality of a sound that distinguishes it from other sounds of the same pitch and volume. The distinctive tone of an instrument or a singing voice.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Time Correction
A processing circuit found in some receivers that compensates for the uneven distances between left and right car speakers and listeners' ears. Time...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
TOC/Table of Contents
The subcode information which contains track numbers and times.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Toroidal Coil
An inductor or transformer whose core consists of a concentrically wound ribbon of magnetic material. Also used to filter noise on a DC supply line.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Total Harmonic Distortion (THD)
The noise referenced to signal in decibels (dB) as a percentage. Refers to a device adding harmonics that were not in the original signal. For example
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Track Repeat
Plays the same track over and over until you turn the feature off.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Tracking Servo
The control circuit used to keep the pick-up over the desired track.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transceiver
A combination radio transmitter/receiver usually installed in a single housing and sharing some components.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transducer
A device used to convert energy from one form to another. Acoustical to electrical (microphone), electrical to acoustical (speaker), and electrical...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transformer
An electrical device that can be used to provide circuitry isolation, signal coupling, impedance matching, or voltage step-up.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transient Response
The ability of a speaker to respond to any sudden change in the signal without blurring the sound. A speaker that can react quickly to rapid change...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transients
Bursts of high energy or spikes of gain in an audio signal. Frequently in the low frequency range.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transistor
A three terminal device used for amplification and switching.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transmission Line
Also referred to as a T-line. A type of bass cabinet in which the back wave follows a relatively long, usually damped path before being ported to the...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transmission Line Enclosure
An enclosure design in which the driver is at one end of the enclosure, with an internal path which consists of a series of bends or curves that lead...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Transparency
Listening term. An analog that can be best "pictured" in photography. The more "transparent" the sound, the clearer the auditory...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Travel Presets or Best Tuning Memory
Engage this feature and the CD receiver automatically loads a bank of your presets with the strongest available signals. It makes finding stations...
[Read more]
03-28-2012
09:35 PM
by
Page 1 of 2
You
are allowed
to add new entries.
You
are allowed
to upload new attachments.
You
are not allowed
to edit your entries.
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
12v Glossary
Powered by
ForumFactory
09:16 PM
-- DIY Mobile Audio
-- Mobile Skin
Contact Us
DIYMA.com - Car Audio Forum & 12 volt Community Board
Archive
Search Engine Optimization by
vBSEO
3.6.0
Ad Management by
RedTyger
Meet Our Team
Forum
Privacy and Rules
Advertise
Archive
Search
Contact Us
Home
User CP
Members List
New Posts
ITrader
Faq
Post Spy
