Car Audio Forum
Car Audio Classifieds
12v Glossary
AmpGuts.com
Buy Car Audio
Advertise
Register
Upgrade Your Account
My Threads
Search
Today's Posts
DIYMA Car Audio Forum
Glossar
12v Glossary
Username:
Remember Me?
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Page 11 of 26
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Last
Search entries
Advanced Search
Table of content
Add new entry
Show
630
results
The search took
0.02
seconds.
Search entries
Added on
Entry
Added by
Last Edit
03-28-2012
09:35 PM
Filter
1) An active or passive circuit or device designed to block a certain frequency or range of frequencies. 2) An electrical circuit or mechanical...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Fixed DIN Mount
A DIN head unit mounting system whereby no part or component is removeable for security purposes.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
FL Backlight
Fluorescent illumination for the lighted portion of a liquid crystal display. Considered to be a step-up feature from EL backlight.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Flashing Lights
A term used to describe the interfacing of the vehicle's parking lights, dome light, emergency lights, etc., with a security system so that the...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Flat Frequency Response
1) Term for a circuit or audio system that will pass audio signals that will vary by no more than ± 1 dB usually between 20 Hz and 20 kHz, unless...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Fletcher Munson Curves
The set of curves showing the human's ear's frequency sensitivity versus loudness, created by researchers Fletcher and Munson. The curves show the...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Floating Ground
Non-common grounding point. Often used in car audio systems where speakers are grounded to the HU independently of the vehicle grounding system.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Flux
The flow of magnetic energy in a circuit.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
FM
Acronym for Frequency Modulation. The shorter range transmission system (88 megahertz to 108 megahertz) utilized for audio and video. Less...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
FM Mono Sensitivity
This figure tells you how well a CD receiver can pick up FM radio signals. The smaller the number, the greater the ability to pick up weaker...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
FM Stereo Separation
A measure of the ability of an FM tuner to re-create a vivid stereo effect. Measured in dB (decibels). The higher the figure the better.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Foam Surround
A speaker surround design employing a foam material for improved durability and performance.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Focus Lens
The lens in the optical block of a compact disc player that focuses the laser light onto the surface of the disc.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Focus Servo
The circuit that keeps the laser light correctly focused on the pit area of the disc.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Fold Down Face
A DIN head unit with a faceplate that hinges at the bottom to reveal a media loading slot. Provides a larger area on the face for the display and...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Foley Artist
Virtually all audio effects in a movie are created on a special soundstage (referred to as a Foley Stage), and not during actual filming of the...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Former
The cylinder portion of a speaker's voice coil; the wire is wound around this cylinder to form a coil.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Free Air Response
The frequency at which a speaker will naturally resonate.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Frequency
The number of wavelengths that pass a specific point in a specific time period, measured in Hertz (Hz). Cycles per second. The range of human...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Frequency Dividing Network
See crossover network.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Frequency Modulation (FM)
The encoding of a carrier wave by variation of its frequency in accordance with an input signal.
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Frequency Response
Expressed in hertz (hz) this is the measurement of the specific frequency bandwidth that a transducer is capable of recreating. Frequency response...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Fs
Driver free air resonance, in Hz. This is the point at which driver impedance is maximum. This parameter is the free-air resonant frequency of a...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Full Bandwidth
Bandwidth is the range of electronic signal frequencies a particular component can reproduce. For audio components like receivers, full bandwidth is...
[Read more]
03-28-2012
09:35 PM
by
03-28-2012
09:35 PM
Full Logic Deck
A cassette mechanism where the tape operations are carried out by logic circuits rather than mechanical methods.
03-28-2012
09:35 PM
by
Page 11 of 26
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Last
You
are allowed
to add new entries.
You
are allowed
to upload new attachments.
You
are not allowed
to edit your entries.
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
12v Glossary
Powered by
ForumFactory
05:01 AM
-- DIY Mobile Audio
-- Mobile Skin
Contact Us
DIYMA.com - Car Audio Forum & 12 volt Community Board
Archive
Search Engine Optimization by
vBSEO
3.6.0
Ad Management by
RedTyger
Meet Our Team
Forum
Privacy and Rules
Advertise
Archive
Search
Contact Us
Home
User CP
Members List
New Posts
ITrader
Faq
Post Spy
