Category: 12v Glossary
Show entry
Entry tools
Report entry
Fs Fs
Fs
Added by DIYMA, 03-28-2012 09:35 PM
Driver free air resonance, in Hz. This is the point at which driver impedance is maximum. This parameter is the free-air resonant frequency of a speaker. Simply stated, it is the point at which the weight of the moving parts of the speaker becomes balanced with the force of the speaker suspension when in motion. If you've ever seen a piece of string start humming uncontrollably in the wind, you have seen the effect of reaching a resonant frequency. It is important to know this information so that you can prevent your enclosure from 'ringing'. With a loudspeaker, the mass of the moving parts, and the stiffness of the suspension (surround and spider) are the key elements that affect the resonant frequency. As a general rule of thumb, a lower Fs indicates a woofer that would be better for low-frequency reproduction than a woofer with a higher Fs. This is not always the case, though, because other parameters affect the ultimate performance as well.
Create discussions topic
