Why 10's or 12's for midbass?? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-29-2015   #1
Rep Power: 0 sqguy will become famous soon enoughsqguy will become famous soon enoughsqguy will become famous soon enoughsqguy will become famous soon enoughsqguy will become famous soon enoughsqguy will become famous soon enough
Send a message via AIM to sqguy
Default Why 10's or 12's for midbass??
Can someone clear something up for me?,I notice in the old horn install the would used either a 10 or 12 sub for Midas's,I thought the 6 or 8 incher played that role??
sqguy is offline   Reply With Quote Quick reply to this message
Old 12-29-2015   #2
SkizeR's Avatar
DIYMAddict
Rep Power: 199 SkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of light
Default Re: Why 10's or 12's for midbass??
because why not?
but really.. more output
1990 300zx Build Log
Old 12-29-2015   #3
Rep Power: 0 XSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enoughXSIV SPL will become famous soon enough
10s and 12s can certainly handle this role better than smaller drivers. The answer you may be looking for is whether the door or floor can accommodate this particular type of setup.
XSIV SPL is offline   Reply With Quote Quick reply to this message
Old 12-29-2015   #4
claydo's Avatar
Rep Power: 90 claydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of lightclaydo is a glorious beacon of light
Who says in horn installs only? I have 10s mated to a 5" midrange and a tweet!
Like skizer said above tho.......it's all about output. Air displacement is where output comes from, and a 10 or 12 simply moves more air than a 6 or 8....
claydo is offline   Reply With Quote Quick reply to this message
Old 12-30-2015   #5
subwoofery's Avatar
Rep Power: 278 subwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond repute
Erin is doing something better... A 12" to a 2.5" mid
Kelvin
Lycan
Old 12-30-2015   #6
Oh ok wasn't trying to ruffle any feathers was just curious as to why folks were going this route with horns
Old 12-30-2015   #7
SkizeR's Avatar
DIYMAddict
well you kinda need the extra output with horns considering most horns have a sensitivity around 108+ db
Old 12-30-2015   #8
subwoofery's Avatar
To put it simply, in order to keep a good coherence and a dynamic system horns are known for, it simply is better to use a high efficiency driver to pair with horns.
High efficiency and low frequencies don't mix very well. You either have a 6" driver that plays low well but has a sensitivity of 84dB 1w/1m or you use a 6" driver with a sensitivity of 100dB to pair with a 110dB+ horn that will only play 125Hz-160Hz and up coz it won't let it cross below that. Then you need a driver to keep up with that - a high efficiency midbass (10" and up).
A few decades ago, this was even worse, small driver just couldn't play low, so you had to use big drivers 8" and up in order to keep up with the rest of the system.
Kelvin
Lycan
Old 12-30-2015   #9
I drive a 96 Accord sedan,if I went with horns where would be a good place to install some 10's or 12's since I don't have that rear side space like some other cars do
Old 12-30-2015   #10
SkizeR's Avatar
DIYMAddict
kick panels are almost always the best option
Old 12-30-2015   #11
I800C0LLECT's Avatar
Rep Power: 129 I800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of light
rear deck midbass?
My '13 Jetta build...not finished
I800C0LLECT is online now   Reply With Quote Quick reply to this message
Old 12-30-2015   #12
SkizeR's Avatar
DIYMAddict
Originally Posted by I800C0LLECT View Post
rear deck midbass?
well considering this is the HLCD section and hlcd's are usually a 2 way system crossed around 1.5k~.. thats not such a good idea lol
Old 12-30-2015   #13
I keep thinking 3-way. Guess it all depends on how the mid-range is covered.
hrmm.
The bigger the horn the lower you can cross Start at the bumper?
Old 12-30-2015   #14
Bikinpunk
Rep Power: 25976 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
Kelvin
this.
HE drivers generally trade off the efficiency for low frequency extension/excursion. so to make up for it, folks use a larger driver in HE systems than they would typically use vs a mid-efficiency system.
Follow my blog:
http://medleysmusings.com/
Time Delay Calculator:
Old 12-30-2015   #15
Rep Power: 90 niko084 will become famous soon enoughniko084 will become famous soon enoughniko084 will become famous soon enoughniko084 will become famous soon enoughniko084 will become famous soon enoughniko084 will become famous soon enough
In PA systems it's common to see a 10-15" driver used for midbass, how much output do you want and how much room do you have are the questions.
Obviously the 15 used as a midbass is not the same woofer or the same enclosure you'd use for 30hz.
niko084 is offline   Reply With Quote Quick reply to this message
Old 12-30-2015   #16
Bikinpunk
right. I use a 15" HE (98dB @ 1w/1m) woofer in my HT and still cross it at about 80hz. It mates to the CD/horn at about 550hz or so.
Follow my blog:
Old 12-30-2015   #17
Rep Power: 148 sqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to behold
if the woofer is 15" how big are the subs?
Old 12-30-2015   #18
Victor_inox's Avatar
UNPLUGGED
Victory Sonics
Owner/ Engineer/Sales/Support
Rep Power: 144 Victor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the rough
because why not?
less movement of VC out of magnetic gap= less distortion.
Victor_inox is online now   Reply With Quote Quick reply to this message
Old 12-30-2015   #19
Bikinpunk
I use standard sensitivity subs. SI HT18, to be exact.
Again, HE woofers are a different breed. In my case, to get the low end for HT purposes out of a HE driver, you'd be talking at least an 18" woofer and a very large ported enclosure. When I was considering going with an HE subwoofer - one that would play flat in to the low 20's - I was spec'ing out 21" B&C woofers in 5-6ft^3 enclosures. I decided that was ludicrous and I went with the HT18's. It's good enough. Ideally I'd add a few more subs but I'm happy with the output of the current setup.
Follow my blog:
Old 12-31-2015   #20
Well this would be my setup USD BC300 wave guides Beyma 8g40 miss JBL 15" subs now if I wanted to add Midbass where would be the best place to place them front door or rear door in my 96 Accord sedan??
Old 12-31-2015   #21
subwoofery's Avatar
In front of you for sure
Kelvin
Lycan
Old 12-31-2015   #22
Well thats where the confusion lies for me,every old school horn set had the midbass installed behind them in the rear side panel,can anyone explain why??
Old 12-31-2015   #23
oabeieo's Avatar
SPEAKER ADDICT
Stereo shop in denver
Install Manager/ Goofball
Rep Power: 55 oabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enough
Your 8g40 Will work just fine down to 125hz 12tbfor octave, so that roll off will get you into the 80s no problem I would just do your waveguides the g40 and the 15 and that's it
https://youtu.be/VgU6LXY-AjI
oabeieo is online now   Reply With Quote Quick reply to this message
Old 12-31-2015   #24
subwoofery's Avatar
You won't be using a dedicated midrange, those with rear midbasses do.
Kelvin
Lycan
Old 12-31-2015   #25
Diyma Ninja
Rep Power: 248 thehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud of
Mainly the USD cars had midbasses behind the driver.
