Sonic Electronix March Markdown Madness - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 03-01-2017   #1
rton20s's Avatar
Rep Power: 314 rton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond repute
Default Sonic Electronix March Markdown Madness
Looks like Sonic has some pretty nice deals for this month.
Of particular interest might be the deals on NVX gear right now with the coupon code "NVXELEC".
For additional discounts, you can also use my code "hutsell". (Better discounts to new customers, but still a little savings for repeat customers.)
The supply on the XP6ACT and XQW122 are getting pretty low, so act quickly if you want a set.
Those subs and the D4 version XQW124 look to be an absolute steal for under $200/pair! SB Acoustic designed and built, 20mm Xmax, shorting ring, 3" voicecoil, etc.
Pioneer DEH-80PRS | Mosconi 6to8 V8 | Arc KS900.6 | Arc KS600.2 | Illusion TL 25 BN | Illusion C5 | Arc Black 12
2015 MECA SQL Street California State Champion
The Following User Says Thank You to rton20s For This Useful Post:
bbfoto (03-03-2017)
Old 03-01-2017   #2
beak81champ's Avatar
Rep Power: 25 beak81champ will become famous soon enoughbeak81champ will become famous soon enoughbeak81champ will become famous soon enoughbeak81champ will become famous soon enoughbeak81champ will become famous soon enoughbeak81champ will become famous soon enough
Default Re: Sonic Electronix March Markdown Madness
Thanks man!
2013 Camaro SS/RS - Kenwood DDX9903S - Arc Audio PS-8/PSC - Arc Audio 1200.6 - Helix SPXL1000 -Audiofrog GB12D4(2) IB, GB60, GB25, GB10
beak81champ is offline   Reply With Quote Quick reply to this message
Old 03-01-2017   #3
Rep Power: 130 USS Enterprise will become famous soon enoughUSS Enterprise will become famous soon enoughUSS Enterprise will become famous soon enoughUSS Enterprise will become famous soon enoughUSS Enterprise will become famous soon enoughUSS Enterprise will become famous soon enough
Wonder how those subs would do IB.
185 after coupon code. Seems good.
USS Enterprise is offline   Reply With Quote Quick reply to this message
Old 03-01-2017   #4
rton20s's Avatar
I wouldn't count too much on the published specs. I emailed NVX about them months ago and the specs they sent me were completely different on those subwoofers, and I never could confirm which VC configuration the specs I was sent applied to. Having said that, with the supplied specs IB would probably my preferred installation method. If I had the spare cash right now, I would have already ordered a pair.
The specs I was supplied...
QMS12.88
QES 0.74
QTS 0.70
CMS 0.12 mm/n
MMS 203.0 gr
RMS 3.2 kg/s
BL 12.7
VAS 51.4
SD 551.5cm
FS 32.2hz
SPL @1w /1m= 91dB
I followed up that email asking about the VC configuration, Re, Le, Xmax confirmation, etc. and never did hear back.
Old 03-01-2017   #5
Rep Power: 20 LostnEye will become famous soon enoughLostnEye will become famous soon enoughLostnEye will become famous soon enoughLostnEye will become famous soon enoughLostnEye will become famous soon enoughLostnEye will become famous soon enough
I picked up a set of X series tweeters before they went out of stock. See how they do paired with HAT L6s
LostnEye is offline   Reply With Quote Quick reply to this message
Old 03-02-2017   #6
foreman's Avatar
Rep Power: 133 foreman will become famous soon enoughforeman will become famous soon enoughforeman will become famous soon enoughforeman will become famous soon enoughforeman will become famous soon enoughforeman will become famous soon enough
How much power IB do you think those XQW 12's will be too much? I have 300 per channel at 2 ohms. Advertised power in an enclosure is only 4. Trying to judge if i should go with d2 or d4. At 4 ohms i have 150 per channel....Thoughts?
Deck-DEX-P99Rs, Amp-Arc xdi v2 1200.6
Dash-Xtant XIS 2.4
Doors-Scan Rev's, sub SI Mag 4....
foreman is offline   Reply With Quote Quick reply to this message
Old 03-02-2017   #7
rton20s's Avatar
In WinISD modeling a pair with 600W in 16 cf doesn't even get you to the claimed 20mm Xmax with no infrasonic filter in place. You'll push them to just shy of 18mm of one way excursion. Throw on a 15 Hz BW2 infrasonic filter and your talking about less than 16mm of one way excursion. I would definitely opt for the configuration that gives you 300W for each driver.
Old 03-03-2017   #8
foreman's Avatar
Thanks for that! I was wondering which to model because of the advertised specs versus the .7 qts you mentioned...
Dash-Xtant XIS 2.4
Old 03-03-2017   #9
Rep Power: 31 V 2the C is on a distinguished roadV 2the C is on a distinguished roadV 2the C is on a distinguished roadV 2the C is on a distinguished roadV 2the C is on a distinguished road
These subs may be different but the other sb acoustic subs have 28 mm voice coils and 7 to 8 mm gaps. So that cuts the xmax down to 10 mm for WinISD? I'm not sure. I've already ordered a set and would like to have some sealed and ported box sizes for just one sub.
V 2the C is offline   Reply With Quote Quick reply to this message
Old 03-03-2017   #10
rton20s's Avatar
This is one of the reasons I was hoping to get confirmation from NVX. And keep in mind that there are several different ways manufacturers can measure Xmax. With raw drivers we are used to seeing the overhand method VC height - Gap Height / 2. But many times manufacturers or brands will use 70% of BL. Other still just use whatever number they want, or even Xmech.
While there is the 12'' SB34SWNRX-S75-6 :: SB Acoustics which has been out for a while and available from Madisound, Solen, etc., I do not think this is the same subwoofer at all. It may be more closely related to the yet to be released SB Acoustics :: 12" SB34SWPL76-4. Note the larger motor, larger surround longer voicecoil, higher Xmax (15mm by overhang method) etc. All things more in line with the NVX design.
I do not think they are the same though. I believe the NVX design is unique to them and probably developed by SB Acoustic specifically for NVX.
Old 03-07-2017   #11
Rep Power: 106 SPAZ will become famous soon enoughSPAZ will become famous soon enoughSPAZ will become famous soon enoughSPAZ will become famous soon enoughSPAZ will become famous soon enoughSPAZ will become famous soon enough
Did anyone try out the NVX subs yet?
Morel Supremo Piccolo/Dynaudio Esotar 650/Helix DSP Pro/JL Audio HD600.4/JL Audio HD1200.1/JL Audio 13w7
SPAZ is offline   Reply With Quote Quick reply to this message
Old 03-11-2017   #12
https://www.sonicelectronix.com/item...V12G-Gray.html
I picked up one of ^ these $45 boxes to try it in. The cut out is 11" so I had to cut it to 12". If anyone goes this route pay attention because the outside diameter of the sub was basically the same as the box. I had to shift the hole to 7 o'clock away from the port. YMMV. Use the cardboard cut out that the sub ships with.
At roughly $95 each, this may be the best money you will ever spend on a sub. It makes lots of output effortlessly in 1.8 ported with @350-400 watts.
Old 03-11-2017   #13
Rep Power: 32 GEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enoughGEM592 will become famous soon enough
Looks like a good price on the GTis ... I wish they would sell the 6.5s only
GEM592 is offline   Reply With Quote Quick reply to this message
Old 03-11-2017   #14
Good sound quality?
Old 03-17-2017   #15
foreman's Avatar
I picked up a set of the NVX 12's....nice build quality. Not sure i'll ever test them out....sounded good at the time lol
Dash-Xtant XIS 2.4
Old 03-17-2017   #16
Rep Power: 9 Aslmx will become famous soon enoughAslmx will become famous soon enoughAslmx will become famous soon enoughAslmx will become famous soon enoughAslmx will become famous soon enoughAslmx will become famous soon enough
Will it let you use both codes?
Aslmx is offline   Reply With Quote Quick reply to this message
Old 03-17-2017   #17
foreman's Avatar
no, i tried lol
Dash-Xtant XIS 2.4
Old 03-18-2017   #18
Rep Power: 0 trenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enough
I agree that these are indeed good deals and I hope It's still available. I'm pretty sure that many people will race towards buying these deals. We have to be hurry for the March Markdown madness of NVX gear and XP6ACT with discounts.
trenion is offline   Reply With Quote Quick reply to this message
Old 03-18-2017   #19
Rep Power: 18 HOIRiIZON will become famous soon enoughHOIRiIZON will become famous soon enoughHOIRiIZON will become famous soon enoughHOIRiIZON will become famous soon enoughHOIRiIZON will become famous soon enoughHOIRiIZON will become famous soon enough
Oh you work for them, I'm going to have to unsubscribe now.
HOIRiIZON is offline   Reply With Quote Quick reply to this message
Old 03-18-2017   #20
Rep Power: 9 Lexingtonian will become famous soon enoughLexingtonian will become famous soon enoughLexingtonian will become famous soon enoughLexingtonian will become famous soon enoughLexingtonian will become famous soon enoughLexingtonian will become famous soon enough
Just wanted to thank you for adding so much to the conversation. Ground breaking stuff there... really!
Lexingtonian is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Lexingtonian For This Useful Post:
street.terror (03-18-2017)
Old 03-20-2017   #21
rton20s's Avatar
no, i tried lol
Thanks for trying. Any time you have an order without another discount code, my code "hutsell" should work. Not a huge discount if you aren't a first time customer, but a little off the top is always nice.
No. I do not. I just had the opportunity to give people a discount code for better pricing. I would have shared the March Madness sale, regardless. If you don't want a discount using my code, so be it. It is available for anyone who wants to save a few bucks.
street.terror (03-20-2017)
Old 03-20-2017   #22
schmiddr2's Avatar
do it yourself
Rep Power: 40118 schmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond repute
Figuring out the plot to a story that doesn't exist. Then running away.
Bravo
schmiddr2 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to schmiddr2 For This Useful Post:
rton20s (03-20-2017)
Old 03-20-2017   #23
The code you gave is almost the same as the march madness discount that I'm getting. Thanks for giving the opportunity. I really appreciate it.
The Following User Says Thank You to Aslmx For This Useful Post:
rton20s (03-21-2017)
