First-timers guide to measuring your system - Page 14 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 02-19-2017   #326
Rep Power: 33 My98RT10 will become famous soon enoughMy98RT10 will become famous soon enoughMy98RT10 will become famous soon enoughMy98RT10 will become famous soon enoughMy98RT10 will become famous soon enoughMy98RT10 will become famous soon enough
Default Re: First-timers guide to measuring your system
Originally Posted by Babs View Post
What you are asking for is on the topic of "target" or "house" curve.. That's where your personal taste for tonality will come into play a bit. There are some somewhat established norms, but in the end, it's what sounds balanced, smooth and coherent to you. I've been told all kinds of stuff like "flat from 200hz up" and 20db total delta between 20hz and 20khz. I think after enough tuning, you'll establish a tonality that's balanced for your car. I don't believe there's any single curve that's right for all cars or systems. Crossover settings are relevant in that crossover regions you want to keep an eye out for any destructive FR stuff that may happen due to phase or timing being out etc. Other than that, the overall tonality should be smooth without spikes or peaks (narrow unavoidable dips can be forgiven). And possibly even more important, left=right.
Thanks for the feedback. I was looking at some measurements I made recently and came across one strange thing where maybe some one can give me a helping Hand on....
I had measured my drivers individually without any crossover set. As it turns out, my sub shows a huge dip in FR at 90 Hz. Has anyone an explanation for this? It is a sealed footwell sub, 8" driver in a small enclosure (approx. 10 Liters). Before any measurements I had set the crossover to 99Hz because it sounded best to my ears. Now, seeing this dip, I have my doubts if 99Hz is really recommended. I should probably cross it at 78Hz to avoid that dip!? What do you guys think?
My98RT10 is offline   Reply With Quote Quick reply to this message
Old 02-20-2017   #327
I will do a nearfield measurement next. Maybe this dip is caused by room/cabin effects? We'll see....
Old 02-24-2017   #328
Rep Power: 0 trenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enoughtrenion will become famous soon enough
Thank you for this complete guide. It will be very useful for me since I'm relatively new with making mobile audio. Got to share this information with my friends too.
trenion is offline   Reply With Quote Quick reply to this message
Old 02-24-2017   #329
So I did a nearfield measurement of my footwell sub the other day and this is the result:
Is it fair to assume that the dip at 90Hz in the previous measurement from the listening position (drivers seat) is caused by the cabin acoustics!? However, I am wondering about the dip at 160Hz now...?
Old 02-24-2017   #330
Rep Power: 65 Elgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enough
How did you measure this one? Near-field should be plenty full here thatís strange (like 1" from the cone).
I (as many) have the same effect with my sub, but placed behind me almost in the middle of the car.
My dip is around 170hz so not really an issue, in fact it helps. But the near-field measurements are full up to 2k.
This dip moves if I move the sub of course, wavelengths interaction between both windshields that causes cancellation I guess (could calculate the distance etc)
You could try different points of measurements, like 8 around your driver seat to see how it's affected, see if it's really an issue.
Or you could also leverage this dip, and cross right on it with a shallower slope, one that would give you the wanted acoustic slope (so could be anything between 80 to 120hz or even anything else)
Horny Froggy...
Old 02-25-2017   #331
I put the microphone right in front of the cone, actually less than 1"! The sub was still in the car (footwell) but I assumed that cabin effects should have been eliminated by this type of measurement. Maybe I need to do another measurement with the sub outside the car in a reflection free environment!?
Old 02-25-2017   #332
Oh I forgot, my car is a convertible and I did this the top down, seats down and everything open. very close to a clean near-field I guess. When in your case even everything open itís still trapped in a tunnel.
But anyway you won't learn a lot outside, I think multi points at driver side will give you more.
Horny Froggy...
Old 05-01-2017   #333
ARCuhTEK's Avatar
Rep Power: 117 ARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enoughARCuhTEK will become famous soon enough
Old thread but I need this information, so thank you to the OP.
ARCuhTEK is offline   Reply With Quote Quick reply to this message
Old 05-07-2017   #334
Rep Power: 0 cesarius will become famous soon enoughcesarius will become famous soon enoughcesarius will become famous soon enoughcesarius will become famous soon enoughcesarius will become famous soon enoughcesarius will become famous soon enough
Thanks for the this RTA Guide.
cesarius is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #335
Rep Power: 138 Rivers will become famous soon enoughRivers will become famous soon enoughRivers will become famous soon enoughRivers will become famous soon enoughRivers will become famous soon enoughRivers will become famous soon enough
Can someone tell me which channels I should be plugging into my Audison Bit one DSP if I don't have an Aux input on my head unit?
Rivers is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #336
Hoptologist's Avatar
Edgewater
Rep Power: 69 Hoptologist will become famous soon enoughHoptologist will become famous soon enoughHoptologist will become famous soon enoughHoptologist will become famous soon enoughHoptologist will become famous soon enoughHoptologist will become famous soon enoughHoptologist will become famous soon enough
AFAIK, Aux 1 or Aux 2. But you'll need a 3.5mm male to 2RCA male stereo cable. Something like this https://www.amazon.com/Cable-iXCC-Sh...rds=aux+to+rca
Audison BitOne - Arc XDI V2 600.4, KS 2500.1 - Arc Black 6.2 - JBL W15GTi MkII
07 Accord Build Log
Hoptologist is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Hoptologist For This Useful Post:
Rivers (9 Hours Ago)
Old 9 Hours Ago   #337
Does any one know if I can export the Auto EQ recommended filter settings to the Helix DSP 2? I do not see as part of the Equaliser options.
Thanks!
Old 9 Hours Ago   #338
bnae38's Avatar
Rep Power: 32 bnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enough
Thanks!
Export? Not that I know of. But use the usm810 filters or 360.3 (q is limited though). The filter definitions for those two are closer to the helix's than the generic filter set.
2012 Subaru Impreza Sedan. Pioneer P880prs, Helix Dsp.2, JL 12w6v2 x2 sealed, Arc KS600.2, Arc KS900.6, SI TM65v1, Illusion Audio C3cx. Ipod Classic - apple lossless. Just keep tryin' to get a little better.
bnae38 is offline   Reply With Quote Quick reply to this message
