How to build speaker grills - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-14-2007   #1
doitor's Avatar
Rep Power: 138 doitor will become famous soon enoughdoitor will become famous soon enoughdoitor will become famous soon enoughdoitor will become famous soon enoughdoitor will become famous soon enoughdoitor will become famous soon enough
Send a message via MSN to doitor
Default How to build speaker grills
This is a way to make your own Speaker grills with metal grill that's easy, fast and a great way to protect your investment.
Well let's get started.
First cut a ring out of wood that the exact outter diameter of your speaker. Or if you are like Dave, that has tons of "experiments went wrong" speakers on your hand that should work to. Cut it with what ever you have on hand, jigsaw, router, etc.
Something like this for the HAT Legatia L3.
Then take a Speaker grill from any bigger speaker, in this case a 6 1/2 inch driver.
Put the ring under the grill and cut it to shape with some heavy duty scissors. Leave enough material around because that's going to determine the height of the grill.
Depending on the height you need you should leave a bigger or smaller piece of material around the original ring.
Once you are satisfied with the cut, roll it against the ground or any hard surface to get the size and form of the ring.
You can trim the excess around with the scissors.
And this is the final result
To finish it of, you can cover it with grill cloth or paint it.
To attach it to the speaker you can use small magnets or any other way you can imagine.
Well that's all for now.
Hope it can be usefull to you.
MKV GTI - Sound system in progress....
doitor is offline   Reply With Quote Quick reply to this message
Old 12-14-2007   #2
///Audience's Avatar
Rep Power: 134 ///Audience is on a distinguished road///Audience is on a distinguished road///Audience is on a distinguished road///Audience is on a distinguished road///Audience is on a distinguished road
Default Re: How to build speaker grills
nice one man! Thanks
2013 VW GTI
iPad, Mosconi 6to8, Illusion C6 / C4CX / C12XL, JL HD600/4, HD1200/1
///Audience is offline   Reply With Quote Quick reply to this message
Old 12-15-2007   #3
Rep Power: 125 WrenchGuy will become famous soon enoughWrenchGuy will become famous soon enoughWrenchGuy will become famous soon enoughWrenchGuy will become famous soon enoughWrenchGuy will become famous soon enoughWrenchGuy will become famous soon enough
Nice I have a whole stack of grills too.
WrenchGuy is offline   Reply With Quote Quick reply to this message
Old 12-15-2007   #4
AzGrower's Avatar
Rep Power: 170 AzGrower will become famous soon enoughAzGrower will become famous soon enoughAzGrower will become famous soon enoughAzGrower will become famous soon enoughAzGrower will become famous soon enoughAzGrower will become famous soon enough
you can also use the Speaker grilles available from PE, they sell them in small sheets
**FOR NOW**
Stock 2008 Chevrolet Suburban Z71 (Sad to say with Bose system <--the wifey's choice)
AzGrower is offline   Reply With Quote Quick reply to this message
Old 12-17-2007   #5
Rep Power: 167 Whiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enough
also, if your metal material is too thick to bend by hand, you can start with a .75 inch MDF blank, add the roundover you want via router or sandpaper, then hammer the grille over the edges. Trim and paint as per above procedure.
Whiterabbit is offline   Reply With Quote Quick reply to this message
Old 03-02-2008   #6
Rep Power: 0 dmwarner will become famous soon enoughdmwarner will become famous soon enoughdmwarner will become famous soon enoughdmwarner will become famous soon enoughdmwarner will become famous soon enoughdmwarner will become famous soon enough
Thanks for the tuto...this is just the idea I needed!
dmwarner is offline   Reply With Quote Quick reply to this message
Old 11-10-2009   #7
less's Avatar
Rep Power: 137 less will become famous soon enoughless will become famous soon enoughless will become famous soon enoughless will become famous soon enoughless will become famous soon enoughless will become famous soon enough
Hi all,
Does anyone know a good source of raw grill material? I've bought the parts express raw grill stock and I'd really like something that is: 1. thinner and more pliable and 2. mmuch more acoustically transparent - higher ratio of hole to metal =)
I've also googled and seen most of the common places. I know there is material out there that is in excess of 70% open... just can't find it!
Thanks
LEss
Still lovin' my '06 Civic
SOURCES: 2 Ipods & Pure I20 - Sarotech Media player - Pioneer DVD, DRIVERS: Peerless XLS -Scan 12m - Airborne RT4001 - JBL GTi 12, AMPS: McIntosh 440m - Zapco Ref 750.2, PROCESSING: Bit One & SRC, POWER: Diehard/Stinger CUSTOM: Amp Shroud & Enclosures - ViaBlue/Canare RCAs - Relay block
less is offline   Reply With Quote Quick reply to this message
Old 11-22-2009   #8
Rep Power: 0 Lguedin will become famous soon enoughLguedin will become famous soon enoughLguedin will become famous soon enoughLguedin will become famous soon enoughLguedin will become famous soon enoughLguedin will become famous soon enough
thanks
Lguedin is offline   Reply With Quote Quick reply to this message
Old 11-23-2009   #9
jbholsters's Avatar
Rep Power: 99 jbholsters will become famous soon enoughjbholsters will become famous soon enoughjbholsters will become famous soon enoughjbholsters will become famous soon enoughjbholsters will become famous soon enoughjbholsters will become famous soon enough
McMaster-Carr
Here is the part with the highest percentage opening (63%)
http://www.mcmaster.com/#9255t741/=4mlfv7
jbholsters is offline   Reply With Quote Quick reply to this message
Old 12-09-2009   #10
BADMOPAR's Avatar
Rep Power: 0 BADMOPAR will become famous soon enoughBADMOPAR will become famous soon enoughBADMOPAR will become famous soon enoughBADMOPAR will become famous soon enoughBADMOPAR will become famous soon enoughBADMOPAR will become famous soon enough
And tried anybody laser cutting stainless steel?
BADMOPAR is offline   Reply With Quote Quick reply to this message
Old 12-09-2009   #11
Rep Power: 98 jimp will become famous soon enoughjimp will become famous soon enoughjimp will become famous soon enoughjimp will become famous soon enoughjimp will become famous soon enoughjimp will become famous soon enough
found a place on the web, google reliable hardware, they had some grill stock IIRC.
jimp is offline   Reply With Quote Quick reply to this message
Old 02-11-2010   #12
Garage Manager
Rep Power: 141 JayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enough
Originally Posted by less View Post
Hi all,
Thanks
LEss
Less, I was just looking and found this stuff:
Perforated aluminum
And the hex shaped stuff is 79% open.
Jay
Old 04-06-2010   #13
Rep Power: 0 bucsfan will become famous soon enoughbucsfan will become famous soon enoughbucsfan will become famous soon enoughbucsfan will become famous soon enoughbucsfan will become famous soon enoughbucsfan will become famous soon enough
Hey,I know this is a little dated but mobile-solutions has a good selection of grill material to choose from as well as other installer-friendly tools and materials. Just my .02
bucsfan is offline   Reply With Quote Quick reply to this message
Old 05-16-2010   #14
Rep Power: 97 jasondplacetobe will become famous soon enoughjasondplacetobe will become famous soon enoughjasondplacetobe will become famous soon enoughjasondplacetobe will become famous soon enoughjasondplacetobe will become famous soon enoughjasondplacetobe will become famous soon enough
sweet i need to Build one for a tweeter, and was wondering how to do it
jasondplacetobe is offline   Reply With Quote Quick reply to this message
stock speaker grills for fullsize gm URGENT Hillbilly SQ Off Topic 10 09-07-2007 04:43 PM
Need 4" speaker grills tRidiot Technical & Advanced Car Audio Discussion 10 06-30-2007 02:57 AM
rs 180 speaker grills remps44 Technical & Advanced Car Audio Discussion 0 06-04-2007 10:39 PM
WTB 6.75" Mesh Speaker Grills thehardknoxlife Car Audio Classifieds 4 03-15-2007 06:50 PM
WTB: 3" or 3.5" Metal Speaker Grills? durwood Car Audio Classifieds 0 03-09-2007 07:11 AM
