Old 04-16-2012   #126
Bigaudiofanatic's Audio Install Service
Rep Power: 59 bigaudiofanatic will become famous soon enoughbigaudiofanatic will become famous soon enoughbigaudiofanatic will become famous soon enoughbigaudiofanatic will become famous soon enoughbigaudiofanatic will become famous soon enoughbigaudiofanatic will become famous soon enough
Send a message via AIM to bigaudiofanatic Send a message via Yahoo to bigaudiofanatic
Default Re: Need Help? Let Me Know
LOL thanks buddy
bigaudiofanatic is online now   Reply With Quote
Old 04-23-2012   #127
This past weekend, I worked on a good friends jimmy. He completely blew his stock speakers. So I felt like I had to replace them.
Installed
Kenwood head unit
Focal polyglass speakers
metra axxess
Future:
infinity amp
rear speakers
Sub
Lets get started
Before
During
Wiring
Old 04-23-2012   #128
I actually switched the tweeter mounting brackets. The left went to the right and right went to the left. This allowed the tweeters to be aimed just a tad of axis.
Old 04-23-2012   #129
Coppertone's Avatar
Rep Power: 44 Coppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the roughCoppertone is a jewel in the rough
Very clean and right to the point, just the way that I like my installs.
Alpine IVE-W530/. Pioneer Stage4 speakers/CDT QES1220 subwoofer/ Mosconi AS100.4/ Mosconi Zero3/ Zapco DSP Z8 processor.
Coppertone is offline   Reply With Quote
Old 05-06-2012   #130
Today was a simple sub and amp integration into the factory system of a VW R32.
Battery
Fuse block ran and insulated.
Used the 12 volt plug to wake up the LOC
Powered the LOC from the fuse block
Everything ran
Set up
Old 06-08-2012   #131
Rep Power: 0 Jamal_Watkins will become famous soon enoughJamal_Watkins will become famous soon enoughJamal_Watkins will become famous soon enoughJamal_Watkins will become famous soon enoughJamal_Watkins will become famous soon enoughJamal_Watkins will become famous soon enough
hello, I'm new to the site...i have a ? in my 02 impala i have 3 mtx comp 10"'s in a custom sealed box with an alpine 750w mono d amp...ive had it hooked up for about 4 years now and only untill recently have i had a problem...never overheats or anything like that but this winter my car had problems starting...i think i blew the fuse then and just yesterday did i get around to replacing the in line fuse on the power line...replaced it yesterday with a 25a fuse cause thats all i had at the moment and it ran for about 1 min before blowing the fuse my father in law had a 30a fuse which is what i had in it for all this time anyway...it played fine on the ride home last night and on the way to work this morning...stopped at the gas station for an energy drink and when i got back in my car the subs had stopped playing again and alas the 30a fuse had blown...do u think i have a short in my line or maybe a bad ground or something?...any and all tips welcome
thanks and peace!
jamal watkins the real white chocolate!
Jamal_Watkins is offline   Reply With Quote
Old 06-08-2012   #132
thanks and peace!
I would check to make sure your power wire has not grounded out anywhere. You can use a volt meter to check for any continuity between your power wire and ground. Also you should have at least a 100 amp fuse, also are you running 4 gauge wire or larger? And the amp has the same size ground wire?
Old 06-08-2012   #133
6spdcoupe's Avatar
Tends to get irritable
Unexpected Creations/ eXquisite Marketing
Owner/Installer/Rep/Lead Janitor
Rep Power: 5000 6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute6spdcoupe has a reputation beyond repute
Send a message via AIM to 6spdcoupe
WHY should he " have at least 100 amp fuse ". Simple and quick math puts his 750w amp @ 12.5V drawing 60amp. IF there is a problem with the amp itself throwing in a 100amp fuse would surely make the problem further than the amp.
Helix C-DSP
Dual Brax MX4s
Dyn Esotar 650s~430s~110s~1200s
6spdcoupe is offline   Reply With Quote
Old 06-08-2012   #134
Very true, standard fuses that come with 4 gauge are 100 "or lower" however I would not be surprised if he is blowing 25 and 30 amp fuses because they simply are not made for that dray and are failing. He could also take a look at his fuses on the amp add those up and run a fuse that is equal to that as well.
Old 06-17-2012   #135
Did a 2007 trailblazer over the weekend. Installed
Kicker 6.5 components
Kicker 6.5 coaxial's
alpine head unit
alpine 4 channel amp.
Tear down
Tweeters installed "owner installed them"
Ran new speaker wire
Speakers installed
Power wire ran
Old 06-17-2012   #136
Amp installed
Head unit installed
All done
Old 06-17-2012   #137
Worked on a 2005 G55 AMG, did a full paint correction and fixed a audio install as well.
The bad install
They installed a 5.25 in place of a 6.5 opening, not even using a spacer ring.
Soldered the wires
New speakers installed
The same for the other side
Clayed fallowed by swirl and haze remover, fine machine polish, and wax
Old 06-17-2012   #138
Horsemanwill's Avatar
Rep Power: 177 Horsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond repute
Send a message via AIM to Horsemanwill Send a message via MSN to Horsemanwill Send a message via Yahoo to Horsemanwill
thanks and peace!
which amp is it exactly? it's not wise to just put fuses in. also what size fuse was in the holder originally?
HU P01
Tru SB6 running ES ultra full body and (2) jbl w12gti
Tru S25 runing Mids 4 Silver Flute W17RC38-08
Horsemanwill is online now   Reply With Quote
Old 06-20-2012   #139
Rep Power: 46 ocblaze will become famous soon enoughocblaze will become famous soon enoughocblaze will become famous soon enoughocblaze will become famous soon enoughocblaze will become famous soon enoughocblaze will become famous soon enough
Hey I have a question for you. I am about to install a 9887 into my S-10 Blazer and I was wondering how the speakers sounded after you did that install on the S-10. I can't decide if I should aim the tweeters towards the dash or towards the listeners, this is why I am asking you for your experience. Thanks for offering the help!
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
ocblaze is offline   Reply With Quote
Old 07-06-2012   #140
Never did a s10?
Old 07-24-2012   #141
Just a quick head unit install for a friend.
Upgrade your account if you want to promote your website
Old 08-05-2012   #142
Bump for the new week
Old 08-16-2012   #143
Rep Power: 0 bluntz617 will become famous soon enoughbluntz617 will become famous soon enoughbluntz617 will become famous soon enoughbluntz617 will become famous soon enoughbluntz617 will become famous soon enoughbluntz617 will become famous soon enough
Question Re: Need Help? Let Me Know
Need Help with MyG37 coupe project right now I'm in the planning stages and have more questions than answers.
My Current setup is stock Head, Stock speaker amp, Sundown Audio SA-10 (Just recently purchased after my Polk SR-10 shit the bed). Powered by a Polk Audio PA1200.1
My next step is to improve front stage. My Question is can I just start with replacing the stock Bose amp with a 4 channel amp. If so what would you recommend, please keep in mind I plan on buying a set of JBL 660GTi for the Front door replacements. Not sure on replacing rears at the moment but prob a coax setup down the line.
I have SQ with good hard hitting base in mind for my ideal setup and would like to shoot some thoughts and ideas to you for my ultimate goal, Let me know if you can help
bluntz617 is offline   Reply With Quote
Old 08-28-2012   #144
Past weekend was a busy one.
Started off with a 2006 Mercedes ML 350.
Goodies
JBL MS8
Pioneer AVIC-Z140BH
Factory head unit
Seat out
Head unit removed
Head unit harness, Red/Black wire will be tapped for +
Factory amp location under driver seat.
Outputs wired to the MS8 harness. All soldered and heat shrunk.
Old 08-28-2012   #145
New MS8 installed
Switched 12 volt source was used from the power outlet
Wired up
Installed
MS8 display in the glove box
Mic in factory location
Old 08-28-2012   #146
Next up 2009 370Z
Goodies
Pioneer App2 radio
JL250/1 AMP
Sub bass knob was installed looking like factory
New head unit installed
New amp
Quote from the customer.
"Well after my major score at BestBuy, I contacted Bigaudio and he just happens to be in my area this weekend so I decided to take him up on his offer and have him over to install my new head unit and sub amp. Super excited to have him do it, nice to have someone familiar with the car and cares. Pictures will be up on Sunday night.
So where do I start. Let’s start with Matt the person, what a gentleman! Showed up at my house and right away I felt like we had known each other for years. So we sat down for some breakfast and the conversation flowed right away. Sitting with a fellow audiophile that is 28 years my junior and yet likes the same music, well that was a welcome surprise.
Now on to the install, the guy knows this car like the back of his hand. The car was dismantled with CARE in just minutes. All of the wiring was soldered and heat shrink covered and all the runs neatly replaced. Of course as faith would have it, just as he’s getting ready for the final touches, one channel's not working. So out comes everything and the hunt begins. Well like I said, he knows his stuff and after a little trouble shooting, he traced the problem back to the previous installer’s work, short in the "lamp cord" they used to feed the crossovers from the amp. He was kind enough to replace the wires for me with something a little more suitable. Once that was done everything went back in without a hitch.
I really can't say enough about this guy, we laughed all day long, even though it was 80 and the sun was on us all day, we still had a blast! I'm having him back in a few weeks to trouble shoot the system in my FX35.
So if you’re in the market for an installer, don't hesitate to give him a call, the price is right, the work is GREAT and the conversation is fun, you won't be sorry. Oh one other thing, he's done like 40 370's, I don't know many installers that can say that.
Thanks again Matt!"
Old 08-29-2012   #147
Rep Power: 42 Mako312 will become famous soon enoughMako312 will become famous soon enoughMako312 will become famous soon enoughMako312 will become famous soon enoughMako312 will become famous soon enoughMako312 will become famous soon enough
Have you ever done an install on a 05 Nissan Altima with the Bose? I'm looking for any tips/tricks, and pics.
I'm also thinking about doing an IB setup with 2 IDMAXs.
Fuck the dash, I am driving.
Mako312 is offline   Reply With Quote
Old 08-30-2012   #148
Rep Power: 51 Yankeesound will become famous soon enoughYankeesound will become famous soon enoughYankeesound will become famous soon enoughYankeesound will become famous soon enoughYankeesound will become famous soon enoughYankeesound will become famous soon enough
Request sent through your website.
Yankeesound is offline   Reply With Quote
Old 08-30-2012   #149
Replied
Old 08-30-2012   #150
MaXaZoR's Avatar
Rep Power: 83 MaXaZoR will become famous soon enoughMaXaZoR will become famous soon enoughMaXaZoR will become famous soon enoughMaXaZoR will become famous soon enoughMaXaZoR will become famous soon enoughMaXaZoR will become famous soon enough
Send a message via AIM to MaXaZoR
Not trying to be a hater, but if your going to try and become a professional installer and have your own website. You need to run spell check on that shit.
There's vs Mine (sorry but messing up theirs vs there's is killing my OCD.)
I mean I could go through your about page and find at least 20 grammar and spelling mistakes. That doesn't scream professionalism to me. If your website is trying to say you take the time to solder and save screws, but you can't take the time to proofread your own website I would be looking up the next guy in town with a decent website to work on my ride..
MaXaZoR is offline   Reply With Quote
