Another fiberglass box tutorial.. - Page 5 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-13-2012   #101
Rep Power: 59 SuMb0dY will become famous soon enoughSuMb0dY will become famous soon enoughSuMb0dY will become famous soon enoughSuMb0dY will become famous soon enoughSuMb0dY will become famous soon enoughSuMb0dY will become famous soon enough
Default Re: Another fiberglass box tutorial..
The tutorial was great thanks for the tips. I started making my own fiberglass box this week. Made the mold shape in the car Tuesday night. Let it cure, and pulled it out last night =D It's a very fun process and I can't wait to finish it and hear my creation in action.
In the tutorial you hosed it off and found a leak - Isn't it a bad idea to get those MDF mounts wet? I would think that would soften them up and make them too weak for a sub. I can see trying to vacuum out any loose pieces inside the box to clean it up but I would try to keep water away from the ring if I could.
I was thinking that I should coat the inside of mine with bondo to ensure it's air seal as well. How much effort should I put into make the seal really air-tight? Should I go nuts trying to make the box air tight around the speaker terminals and using rubber gaskets around the speaker?
Is it feasible to make it the 'perfect enclosure' or do 'sealed' boxes rely a bit on a tiny air leak to control the woofer cones movement?
I was planning to try and make this completely air tight but then read a thread on here about how no one really has the perfect enclosure so I got confused. My old (10+ year old) subwoofer's foam surround tore all the way around. Sure it lived its life awhile but I thought maybe because it had air leaks (it had no rubber gasket around the speaker mount/box) that promoted the cone surround to break so I thought to treat my new woofer better I should really go crazy with the air sealing process.
Sorry for the long winded post, any thoughts on this guys?
SuMb0dY is offline   Reply With Quote Quick reply to this message
Old 12-14-2012   #102
Rep Power: 0 theoldguy will become famous soon enoughtheoldguy will become famous soon enoughtheoldguy will become famous soon enoughtheoldguy will become famous soon enoughtheoldguy will become famous soon enoughtheoldguy will become famous soon enoughtheoldguy will become famous soon enough
a lot of work to build a box when you could jsut use MDF (a box is an object with 6 flat sides.
theoldguy is offline   Reply With Quote Quick reply to this message
Old 12-14-2012   #103
Haha yes very difficult to get all the corners and angles perfect 90 degrees
Old 12-24-2012   #104
Project_dog's Avatar
Rep Power: 113 Project_dog will become famous soon enoughProject_dog will become famous soon enoughProject_dog will become famous soon enoughProject_dog will become famous soon enoughProject_dog will become famous soon enoughProject_dog will become famous soon enough
Thank u
2007 Mazda CX 7. Kenwood KVT-696 (GPS, NAV, BLUE, IPOD) Memphis 1000, Memphis 4.50 and Memphis 500, Memphis Two 10 inch C3's
Project_dog is offline   Reply With Quote Quick reply to this message
Old 12-24-2012   #105
Rep Power: 95 x97chevy will become famous soon enoughx97chevy will become famous soon enoughx97chevy will become famous soon enoughx97chevy will become famous soon enoughx97chevy will become famous soon enoughx97chevy will become famous soon enough
That is an awesome write up!!!
x97chevy is offline   Reply With Quote Quick reply to this message
Old 12-24-2012   #106
Rep Power: 0 shoot summ will become famous soon enoughshoot summ will become famous soon enoughshoot summ will become famous soon enoughshoot summ will become famous soon enoughshoot summ will become famous soon enoughshoot summ will become famous soon enough
Thanks for your effort putting the guide together, yours is actually one of the resources I used in making mine. It is still in progress but will have it finished this week. For those that state it is a lot more effort than building an MDF box you are right, but it is also way cooler, and more space efficient than a plain old MDF box.
shoot summ is offline   Reply With Quote Quick reply to this message
Old 12-25-2012   #107
Rep Power: 0 eddie298 will become famous soon enougheddie298 will become famous soon enougheddie298 will become famous soon enougheddie298 will become famous soon enougheddie298 will become famous soon enougheddie298 will become famous soon enough
this is awesome, when i eventually buy a subwoofer, im definitly going to try this.
eddie298 is offline   Reply With Quote Quick reply to this message
Old 01-15-2013   #108
bobwires's Avatar
Perfectionist Auto Sound
Fab guy
Rep Power: 115 bobwires will become famous soon enoughbobwires will become famous soon enoughbobwires will become famous soon enoughbobwires will become famous soon enoughbobwires will become famous soon enoughbobwires will become famous soon enough
I don't mean to be a giant turd in the punchbowl here, but this thread needs help. The basic process of the OP is just fine, but the glass work itself is very poor. There is way too much air in your layups. Proper wetout, consistent thickness, and proper resin:glass ratio are all easily reachable goals with just a little practice.
I don't want to come down to hard, because we've all been here, but the standard for a 'reference thread' should be much higher.
Here's a couple nice layups. If you want to see my ugly years getting started, check out the comatose fiberglassforums.
I have been using dye in my resin for the last couple of years. Looks cleaner.
Kick panels
Use wax or silicone spray to make your tape release 100%.
tape off the inside of your rings so you don't have to sand them. Also, leave yourself an edge to sand to by always rabetting the edge of the ring, if it's wood.
Also notice I used foam on these instead of fleece. Get the shape you want before you fill it. Don't try to use a gallon of bondo to correct imperfections in the shape. If you want the fleece look, make ribs/strips of wood to hold it there.
Nice and clean - skim filler and sand before you pull the tape of the middle.
Always glass the outside of the enclosure to ensure a good layup, uniform thickness, etc. Way faster, easier, stronger, better. period.
Some of these things don't need filler, if they're carpeted.
I primered this box with no sanding at all just to show how flat it should be. I knocked it with a d/a real quick, and wrapped it in carpet.
Nelson Hays
Anchorage, AK
bobwires is offline   Reply With Quote Quick reply to this message
Old 01-16-2013   #109
quietfly's Avatar
Rep Power: 92 quietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enough
can you explain/show this in pics?
Old 01-16-2013   #110
bobwires's Avatar
Fab guy
pour foam kick panels
Kick Panels Bobwires' style
my old method using fleece and foam in combination. This takes a lot of time, and I don't think I'll be doing it again.
JL in a Tahoe semi-stealth box
floral foam used for trim
Subaru with Hertz, Rockford, and a fiberglass enclosure
Nelson Hays
Anchorage, AK
Old 01-16-2013   #111
quietfly's Avatar
thanks for the links... I think i might try foaming up some stuff....
Old 03-07-2013   #112
Rep Power: 0 Earful will become famous soon enoughEarful will become famous soon enoughEarful will become famous soon enoughEarful will become famous soon enoughEarful will become famous soon enoughEarful will become famous soon enough
This thread is fantastic! Many chime-in's to assist those, like myself, who dont have any experience with glass. Custom enclosure nirvana....
Earful is offline   Reply With Quote Quick reply to this message
Old 03-16-2013   #113
KAOTIK KUSTUMZ
OWNER
Rep Power: 0 KaotikKustumz will become famous soon enoughKaotikKustumz will become famous soon enoughKaotikKustumz will become famous soon enoughKaotikKustumz will become famous soon enoughKaotikKustumz will become famous soon enoughKaotikKustumz will become famous soon enough
LOVE THE TUTORIAL!!!!!
KaotikKustumz is offline   Reply With Quote Quick reply to this message
Old 04-01-2013   #114
SuperGokuSon's Avatar
Rep Power: 0 SuperGokuSon will become famous soon enoughSuperGokuSon will become famous soon enoughSuperGokuSon will become famous soon enoughSuperGokuSon will become famous soon enoughSuperGokuSon will become famous soon enoughSuperGokuSon will become famous soon enough
WoW im a total nood when it comes to this and now i feal like i could give it a shot and see what haponds i loved how you calculated the cubs of the box so simple. and i do not feel like such a dummy now lol :-)
▀▄▀▄▀▄█▓▒░We are but rifts in the sands of time ░▒▓█▀▄▀▄▀▄.
SuperGokuSon is offline   Reply With Quote Quick reply to this message
Old 04-04-2013   #115
Rep Power: 55 loudnproud808 will become famous soon enoughloudnproud808 will become famous soon enoughloudnproud808 will become famous soon enoughloudnproud808 will become famous soon enoughloudnproud808 will become famous soon enoughloudnproud808 will become famous soon enough
been checking out these forums for years , and now finally made an account , nice thread this whole forum is awesome ! i have recently been thinking about trying this fiber glass enclosure builds myself !
loudnproud808 is offline   Reply With Quote Quick reply to this message
Old 04-23-2013   #116
Rep Power: 54 ndramountanis will become famous soon enoughndramountanis will become famous soon enoughndramountanis will become famous soon enoughndramountanis will become famous soon enoughndramountanis will become famous soon enoughndramountanis will become famous soon enough
Fantastic Tutorial! Thanks for doing all that posting work.
ndramountanis is offline   Reply With Quote Quick reply to this message
Old 01-21-2014   #117
Rep Power: 69 liljohn30 is on a distinguished roadliljohn30 is on a distinguished roadliljohn30 is on a distinguished roadliljohn30 is on a distinguished roadliljohn30 is on a distinguished road
Who in Atlanta can do this work
liljohn30 is offline   Reply With Quote Quick reply to this message
Old 01-22-2014   #118
kia service consultant
Rep Power: 64 The Performer will become famous soon enoughThe Performer will become famous soon enoughThe Performer will become famous soon enoughThe Performer will become famous soon enoughThe Performer will become famous soon enoughThe Performer will become famous soon enough
Kick panels
It is so good to see a glass veteran stepping in.
Dude maybe you know wth is the deal with fgforums? All the good fab guys are far and few to keep up with anymore.
Sent from my SCH-I545 using Tapatalk
The Performer is offline   Reply With Quote Quick reply to this message
Old 01-22-2014   #119
What the hellz up with that forum,fiberglass forum..I joined but it never went through..I was gonna try this ,but kinda gave up,n an looking for someone to do some work in my dodge ram.i wanna do a center console with wood n glass,and then do a mold of the storage bins to try n put in some subs n retain the fold floors
Old 01-22-2014   #120
Rep Power: 86 Ordie will become famous soon enoughOrdie will become famous soon enoughOrdie will become famous soon enoughOrdie will become famous soon enoughOrdie will become famous soon enoughOrdie will become famous soon enough
Its been down for a while...
Sent from my mind to the forum through a Galaxy SIII and Tapatalk 2.
Ordie is offline   Reply With Quote Quick reply to this message
Old 01-22-2014   #121
http://pascackvalleyhome.com/wp-cont...1/07/WHAT1.jpg
Old 07-09-2014   #122
Rep Power: 116 mikelycka will become famous soon enoughmikelycka will become famous soon enoughmikelycka will become famous soon enoughmikelycka will become famous soon enoughmikelycka will become famous soon enoughmikelycka will become famous soon enough
this is a great post now I feel better about wanting to try this my car is leased and I don't want to damage anything but I also need to use my trunk
mikelycka is offline   Reply With Quote Quick reply to this message
Fiberglass box for 12" sub ocuriel Build Logs & Project Install Gallery 34 04-11-2007 07:51 PM
Among Other Things, a Fiberglass vs Sheet Metal Question Beau Technical & Advanced Car Audio Discussion 6 08-15-2006 04:19 PM
Subwoofer Boxes (box vs fiberglass) MrLister Technical & Advanced Car Audio Discussion 9 07-10-2006 11:14 AM
What box size? - TC Sounds TC2+ 12" DVC mvw2 Technical & Advanced Car Audio Discussion 7 12-27-2005 12:44 PM
