A Basic Guide to Crossovers - Page 3 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-21-2008   #51
MiniVanMan's Avatar
Rep Power: 171 MiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura about
Default Re: A Basic Guide to Crossovers
Bump for this one as well. It's fallen to the wayside, and is hardly being read anymore.
MiniVanMan is offline   Reply With Quote Quick reply to this message
Old 09-03-2008   #52
Audio Creations
Sales
Rep Power: 124 borgs will become famous soon enoughborgs will become famous soon enoughborgs will become famous soon enoughborgs will become famous soon enoughborgs will become famous soon enoughborgs will become famous soon enough
Send a message via Yahoo to borgs
Minivan,
Do you think is necessary to Build a zobel network for the mids?
borgs is offline   Reply With Quote Quick reply to this message
Old 09-03-2008   #53
MiniVanMan's Avatar
Originally Posted by borgs View Post
Minivan,
I don't generally do Zobels in my networks. Zobels allow you to increase the top end acoustic response of a driver. However, in the case of a 7" mid, using it above 2khz, starts to degrade the off-axis response of the mid, and therefore the overall polar response will suffer for the system as a whole.
So, I like to use the natural roll off of a driver to achieve my acoustical response at a point where I'll get the best polar response, and off-axis response possible.
Old 09-03-2008   #54
Rep Power: 0 cacin will become famous soon enoughcacin will become famous soon enoughcacin will become famous soon enoughcacin will become famous soon enoughcacin will become famous soon enoughcacin will become famous soon enough
Originally Posted by ///MJay View Post
There is a ton of great info in this thread. What if anything happens when you cascade crossovers? Example, you use the crossover in the head unit, then the crossover in the amp in the same capacity as the one in the head unit. If you are using hpf on the deck and hpf on the amp. Does this change the slope or the crossover point? I am mostly just curious I don't plan on using this set up.
Jason
Based on what I read from the Car Stereo Cookbook, you'll have change in slope. The slope will be steep than the one set in the HU and amp. I don't remember how to calculate it.
I'm not sure about the crossover point though.
cacin is offline   Reply With Quote Quick reply to this message
Old 09-09-2008   #55
Rep Power: 0 exonn will become famous soon enoughexonn will become famous soon enoughexonn will become famous soon enoughexonn will become famous soon enoughexonn will become famous soon enoughexonn will become famous soon enough
hi, very helpful thread....
but now i have some quastions (am realy sorry for my english).
i have morel mt 23 tweeters and want ot Build and x-over for them. So, Fs is 950 Hz, it meens it can be saftly crossed at 1900 hz with 2nd order hi pass. Am i right? So, i have formulas to calculate the values for cap and inductord, but cant finde anywer data sheet for my tweeters with impendance at cross frequency. morel provides manual only with "sensitivity Mag" in 0, 30 and 45 dgree. Do anyone knows whats is impendance value for mt 23 at 1900 hz? or maybe anyone knows where to finde info or a link with info how to mesure impendance?
exonn is offline   Reply With Quote Quick reply to this message
Old 09-10-2008   #56
MiniVanMan's Avatar
The only way to know what your impedance measurement for a driver is, is to measure it yourself. The manufacturer can give a good idea, but it's always better to do it your self.
As for crossing at double the Fs, that's a loose rule. Even if the driver can handle that low of a crossover point, doesn't mean you should. Other factors like distortion and Power handling come into play as well.
The Morel MT23 will probably be fine in the 2k range, but there are tweeters, and I think Morel has them as well, that have an Fs of around 500. I'd be VERY cautious about crossing any tweeter over at 1khz. In fact, I probably wouldn't even do it.
Old 09-11-2008   #57
on other forums, i get sugestions to go 1st order and cross my tweets on 5600 hz. And all i need is just one cap of 4.7uf (for one tweeter). Do you think this is good idea?
This is gona be 2 way system. mid bass is from focal 165 access system.
Old 09-12-2008   #58
Rep Power: 111 lyttleviet will become famous soon enoughlyttleviet will become famous soon enoughlyttleviet will become famous soon enoughlyttleviet will become famous soon enoughlyttleviet will become famous soon enoughlyttleviet will become famous soon enough
very informative guys...
lyttleviet is offline   Reply With Quote Quick reply to this message
Old 09-12-2008   #59
MiniVanMan's Avatar
There aren't many tweeters I would suggest using a 6 db network on unless you're crossing over VERY high. And then, for a 2-way, you're going to have serious problems.
5.6khz is too low. That can be dangerous for a tweeter is you push it hard.
Because Dynaudio does it, doesn't mean that everybody can do it. The Dynaudio tweeter is a very good tweeter.
Old 09-16-2008   #60
MiniVanMan,
Thanks for your ansvers...
Old 09-16-2008   #61
Rep Power: 0 hngu7721 will become famous soon enoughhngu7721 will become famous soon enoughhngu7721 will become famous soon enoughhngu7721 will become famous soon enoughhngu7721 will become famous soon enoughhngu7721 will become famous soon enough
excellent and informative write-up. will save for reference!
hngu7721 is offline   Reply With Quote Quick reply to this message
Old 09-28-2008   #62
txbonds's Avatar
Rep Power: 128 txbonds will become famous soon enoughtxbonds will become famous soon enoughtxbonds will become famous soon enoughtxbonds will become famous soon enoughtxbonds will become famous soon enoughtxbonds will become famous soon enough
Thanks for posting this thread. Tagging for easy reference.
txbonds is offline   Reply With Quote Quick reply to this message
Old 11-16-2008   #63
Rep Power: 108 Jhemi80 will become famous soon enoughJhemi80 will become famous soon enoughJhemi80 will become famous soon enoughJhemi80 will become famous soon enoughJhemi80 will become famous soon enoughJhemi80 will become famous soon enough
Bump for an awesome thread!
Jhemi80 is offline   Reply With Quote Quick reply to this message
Old 11-17-2008   #64
stoeszilla's Avatar
Rep Power: 121 stoeszilla will become famous soon enoughstoeszilla will become famous soon enoughstoeszilla will become famous soon enoughstoeszilla will become famous soon enoughstoeszilla will become famous soon enoughstoeszilla will become famous soon enough
What's your opinion of the TBI Sound tweeter that comes with a "6.8 UF FILM CAPACITOR (3.5KHZ @4 ohms - 6db/oct)" (from the website: http://www.tbisound.com/dsp_products_auto_tweet1.asp)?
If you consider 5.6 khz too low, then 3.5 khz seems extremely dangerous, no? Would that not allow alot of "low" (i.e., tweeter-destroying frequencies) in? Or is this a robust tweeter as well...seems sketchy...
But it would be a nice and simple tweeter to add to a driver with natural roll-off (mach5 mli-6 or the seas model???). Is there something I'm missing?
Thanks again for a very informative thread...but it leaves me with more questions. Such as lobing (something Zaph talks about when selecting drivers and optimum crossover points) and how driver spacing plays a part in all of this...
chris
1999 gmc 1/2 ton: .flac music collection on Ipod for SQ (stock tape deck with adapter)...TS-D720C/VA2200 waiting...
1967 plymouth belvedere 2dr (project): floors done, disk brake conversion soon...
stoeszilla is offline   Reply With Quote Quick reply to this message
Old 11-29-2008   #65
MiniVanMan's Avatar
I have gone into lobing and combing in many other threads to some detail. You'll have to search around. I didn't compile them, and I have no intention of doing another thread like this one. Sorry.
I didn't say you couldn't run a tweeter with a 6db at a lowish crossover point, I just said, it's not a very good idea.
The 6 db crossover is excellent for producing the best Power response at the crossover point of any other filter order. However, with that comes the fact that your driver had better be able to handle that power.
I haven't had the luxury of playing with the TBI tweeter, but I'm pretty sure, they don't want you running 100 watts to that tweeter with only a 6 db filter at 3.5khz. Also, a 6.8 uF capacitor yields a crossover point 5850 hz "electrical", NOT 3.5khz. Acoustically, I don't know. However, I don't know where they came up with 3.5 khz. Even "acoustically" that would be quite a stretch. Most likely, they're compensating for the rising response of the tweeter from Fs, and saying that the 6.8 uF cap "flattens" out the response from 3.5 - 6khz. Still acoustically, the slope would be much higher below 3.5 khz.
They played with some some numbers, which is fine. In the end though, they know better than to give people actual tweeter with inline caps for a 3.5khz, 6 db slope. That's just asking for trouble.
Old 11-30-2008   #66
handy's Avatar
Creatiive Sound Technology
Founder
Rep Power: 125 handy will become famous soon enoughhandy will become famous soon enoughhandy will become famous soon enoughhandy will become famous soon enoughhandy will become famous soon enoughhandy will become famous soon enough
Send a message via MSN to handy Send a message via Yahoo to handy
i had my experiment on zobel network. i agree that zobel is lowering the impedance of speaker.
and this one with zobel
the green and black is just different value of C.
and this is the response of use zobel (black) and no use (green)
use of zobel beside lowering the impedance to Re its also decrease the top end acoustic response of a driver.
handy is offline   Reply With Quote Quick reply to this message
Old 11-30-2008   #67
Chief of Information
Audiofrog Inc.
President
Rep Power: 551 Andy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond repute
Careful, the Zobel doesn't change the impedance of the speaker, it changes the impedance of the amplifier. If the Zobel is calculated precisely, the response of the Speaker shuldn't change, but the impedance the amplifier "sees" will change. The Zobel makes it easier to calculate the required crossover components and that's its main purpose. Simply designing the filter to use the rising impedanace as one part of the passive network will result in a simpler circuit that costs less.
The important response is the measured acoustic response from the combination of drivers connected to the crossover and not the electrical network itself.
Old 11-30-2008   #68
MiniVanMan's Avatar
Exactly!
If you are resistant to doing complicated calculations yourself, and decide to use a modeling program for your filters, then the Zobel is almost an antiquated network.
When I say "modeling program", I'm not talking about a simple crossover designer where you input a frequency and an impedance then it shoots out some values for capacitors and inductors. I'm talking your Speaker Workshops, SoundEasy, LEAP, etc.
All those programs use the impedance curve, coupled with driver response, to predict the response shape after applying various capacitor and inductor values into your circuit. At that point, it becomes pointless to add a Zobel, as the program will be taking into account the variations in impedance anyway.
Another benefit to going without a Zobel is that it's an easier load on the amplifier. The higher impedance of your mid (in a 2-way generally), will increase the impedance of the system overall at the crossover point, making your amplifier sweat a little less.
However, if you really want extended response from a driver, adding a Zobel is a way to do it. I haven't played with an extended range driver and a Zobel yet, but I would venture to guess that that type of driver could benefit. I could also be totally mistaken.
Old 11-30-2008   #69
handy's Avatar
Founder
Exactly!
thanks Andi and mini
but if don't have any simulation software maybe zobel can give an instant solution, just count the le and re and u are done.
the same driver and the target response 12 db at 2700 hz
just 12db butterworth passive xo without zobel
with zobel
zobel, with and without passive xo the higher frequency is always decrease. so i don't think zobel can extend the response.
Old 12-01-2008   #70
stoeszilla's Avatar
Thanks Mini (and others), I'll have to go over the other thread you posted for crossovers (as well as search for lobing, etc.). I just want to say that these threads help to really dispel some of the myths of crossovers and have helped me to understand that simple passive crossovers are anything but "simple"! Thanks again,
Chris
Old 01-03-2009   #71
Rep Power: 0 jeff13m will become famous soon enoughjeff13m will become famous soon enoughjeff13m will become famous soon enoughjeff13m will become famous soon enoughjeff13m will become famous soon enoughjeff13m will become famous soon enough
thanks for the informative write up.
jeff13m is offline   Reply With Quote Quick reply to this message
Old 01-04-2009   #72
Rep Power: 103 diebenkorn will become famous soon enoughdiebenkorn will become famous soon enoughdiebenkorn will become famous soon enoughdiebenkorn will become famous soon enoughdiebenkorn will become famous soon enoughdiebenkorn will become famous soon enough
Thank you for posting this.
diebenkorn is offline   Reply With Quote Quick reply to this message
Old 03-27-2009   #73
C3 Customs's Avatar
C3 Customs
Rep Power: 108 C3 Customs will become famous soon enoughC3 Customs will become famous soon enoughC3 Customs will become famous soon enoughC3 Customs will become famous soon enoughC3 Customs will become famous soon enoughC3 Customs will become famous soon enough
Send a message via AIM to C3 Customs Send a message via Yahoo to C3 Customs
Great Read, nice discussion
Audio Clarity that moment when you are one with your music, we make that moment last forever! #clarity
C3 Customs is offline   Reply With Quote Quick reply to this message
Old 03-28-2009   #74
Rep Power: 0 tim eh? will become famous soon enoughtim eh? will become famous soon enoughtim eh? will become famous soon enoughtim eh? will become famous soon enoughtim eh? will become famous soon enoughtim eh? will become famous soon enough
Hello everyone. This is a real help for me, what a great forum! I'm just starting out in Car audio but I have a good background in sound, mostly in music related stuff (live p.a. and recording studios).
I hope this is an appropriate post for this thread...
I'm thieving the crossovers from the factory amp in my '89 bmw 525i to use with a 4x40w head unit. (this is just the beginning...)
So with the original setup the Speaker negatives are shared (ie FL and BL run together - you can see on the backside of the board)... does this affect things? I'm not sure if I should run separate negatives to the head or tie them together first - does it matter?
I'd be happy to get any other advice too - nice to be here!
tim eh? is offline   Reply With Quote Quick reply to this message
Old 03-28-2009   #75
MiniVanMan's Avatar
I'm not quite following you. Can you be more specific? What is FL, BL, and the other labeling you're using?
DLS Iridium Tweeters and 2-Way Crossovers nelsondog Car Audio Classifieds 0 07-16-2006 11:06 PM
Can I go active with only the amp's crossovers?? carter Technical & Advanced Car Audio Discussion 7 12-31-2005 01:01 PM
CDT Satnet 560 Crossovers & EF-61 Midrange woofers dBassHz Car Audio Classifieds 4 11-28-2005 11:18 AM
crossovers and components griz145389 Technical & Advanced Car Audio Discussion 4 11-06-2005 12:36 PM
Did I fry my passive crossovers? Ludemandan Technical & Advanced Car Audio Discussion 0 07-26-2005 12:56 AM
