Old 05-30-2012   #201
Rep Power: 39 Spyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enough
Default Re: Precision time alignment using only noise tracks and your ears
Originally Posted by supermaxx123 View Post
I'm using a rockford fosgate 3sixty.2 and cannot for the life of me get this to work. I've read it about 10x now, spent over 5hrs + total time sitting in the car(thank you power supply) only to listen to music and start over. Any tips? The delay on each speaker is in inches and can only adjust +/- 2" at a time. The sub is right behind me, reg cab truck, and the sub has no t/a adjusment. Should i just get a tape measure out and try setting it that way?
Probably what I'll do next seeing as nothing has really worked for me.
Since you have delay in distance you need to start with all the channels at the max setting= no delay. You don't start with zero inches. Also since the sub is not the farthest away you need to start with the pass side midbass(which prob is the farthest) Oh...If the sub doesn't have delay then this won't work for you. You could just do the measurement thing and it should help. Then just swap phase on the sub til it sounds best.
Spyke is offline   Reply With Quote
Old 05-31-2012   #202
Rep Power: 97 Greg200SE-R will become famous soon enoughGreg200SE-R will become famous soon enoughGreg200SE-R will become famous soon enoughGreg200SE-R will become famous soon enoughGreg200SE-R will become famous soon enoughGreg200SE-R will become famous soon enough
I love that this thread is becoming self-sustaining. Thanks everyone for trying the procedure and for leaving your comments.
TO ALL NEWCOMERS TO THIS THREAD:
If you have trouble with this procedure, or have specific questions - chances are, others have had the same setback and help has already been provided within this thread. I know the thread's beginning to grow in length, but time invested in reading through it will answer your questions.
It's not about buying the best equipment, it's about getting the most out of it.
Greg200SE-R is offline   Reply With Quote
Old 06-03-2012   #203
Rep Power: 0 bgcontract will become famous soon enoughbgcontract will become famous soon enoughbgcontract will become famous soon enoughbgcontract will become famous soon enoughbgcontract will become famous soon enoughbgcontract will become famous soon enough
Hi,
I can't seem to locate or identify the doppler or sound as I increase delay. I know how to tune a guitar so I am familiar with the doppler effect but I just can't seem to find it within the pink noise. Does anybody have any advise or tricks... or ANYTHING that will help me identify the point at which the both speakers are time aligned!! Thanks for any help. I must have listened for an hour trying to "spot" a pattern and I focused in on the lows and highs within the pink noise.
bgcontract is offline   Reply With Quote
Old 06-04-2012   #204
Rep Power: 55 leogun will become famous soon enoughleogun will become famous soon enoughleogun will become famous soon enoughleogun will become famous soon enoughleogun will become famous soon enoughleogun will become famous soon enough
Hi BG
The answer is on the post above you ��
Based on my method:
I always isolate the freq between two driver within the same freq
I.e. MB 250 - 500 and MR 250 - 500
I found it easier to hear the noise change
Happy trying ��
leogun is offline   Reply With Quote
Old 06-06-2012   #205
Rep Power: 16 dylan199 will become famous soon enoughdylan199 will become famous soon enoughdylan199 will become famous soon enoughdylan199 will become famous soon enoughdylan199 will become famous soon enoughdylan199 will become famous soon enough
So in reading all 9 pages I come to the conclusion that I need to set my sub to max distance (300cm) and go down from there. It goes from 30cm all the way to 300cm. Does that make sense?
dylan199 is offline   Reply With Quote
Old 06-06-2012   #206
If your sub is the furthest speaker from your listening position, then yes. Setting it to 300cm would be the zero delay setting. Remember to set all of your speakers to 300cm and work "backwards" while not touching the sub delay.
Old 06-06-2012   #207
Thanks for the reply! I'll work on it tonight.
Old 06-10-2012   #208
Has anyone with ta that measures in distance instead of time had better luck by setting everything to halfway(range from 0-132/setting to 66) before starting. I kept having the problem where the doppler effect would continue to decrease though the entire range of ta adjustment. For example, when I would be adjusting my tweeter I would start to increase delay and the pitch would start to fall. The problem is that it would continue to fall until I got to full delay(there would be no peak or trough). I concluded that the peaks were at the ends of the adjustment extremes. By starting with everything in the middle I was able to hear definite peaks or troughs. I hope i'm not the only one with this problem.
Old 06-10-2012   #209
Originally Posted by TAMUmpower View Post
I found it easier to just put on something with a good kick drum and bass hits. I used Alicia Keys. And I just started delaying the front mid basses until I couldn't hear the sub anymore. Basically the kick location will focus to the front an it's really easy to hear the improvement.
I wasn't really able to use this threads method for the mid to sub delay either. That's why I just use music.
After countless hours of trying pink/white noise I decided to use music instead. 1/2 an hour later i'm . The method itself is really good though.
Old 06-13-2012   #210
did you use the pink noise from page 1?
i found that not all pink noises can be used
Old 06-13-2012   #211
The link to the noise files comes back as "forbidden"; therefore can not be accessed....???
Old 06-13-2012   #212
Hmm, interesting. I was always under the impression that pink noise was pink noise, almost sure of it. I'll do some research though.
Old 06-13-2012   #213
... Squirrel!!!...
Rep Power: 418 bikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond repute
Correlated vs uncorrelated.
Sent from my iPhone. Pardon the grammar.
Follow my blog:
http://medleysmusings.com/
Cool site with subwoofer testing:
Data-bass.com
Old 06-13-2012   #214
Learn something new everyday. So which should be used for this method?
Old 06-14-2012   #215
Wesayso's Avatar
When the music's over
Rep Power: 48 Wesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enough
pink noise, correlated vs uncorrelated
Wesayso is offline   Reply With Quote
Old 07-16-2012   #216
Driven Audio Tony's Avatar
Service Provider
Driven Audio
Rep Power: 31 Driven Audio Tony will become famous soon enoughDriven Audio Tony will become famous soon enoughDriven Audio Tony will become famous soon enoughDriven Audio Tony will become famous soon enoughDriven Audio Tony will become famous soon enoughDriven Audio Tony will become famous soon enough
Does anyone have a link to the pink noise files from the first page, I would like to check them out.
Driven Audio - Abbotsford, BC, Canada
www.drivenaudio.ca Facebook Page
Ph: 604-746-3110
Driven Audio Tony is offline   Reply With Quote
Old 07-19-2012   #217
... Squirrel!!!...
been meaning to post an idea for a long time now but never did. Finally put it to the test tonight. You can see my results here:
http://medleysmusings.com/subwoofers...nt-in-the-car/
I hope this helps.
- Erin
Follow my blog:
Data-bass.com
Old 07-19-2012   #218
Melodic Acoustic
Rep Power: 115 Melodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura aboutMelodic Acoustic has a spectacular aura about
Subwoofers and Time Alignment in the Car | Medley's Musings
I hope this helps.
- Erin
Nice Erin, I like your findings/method.
Mark Brooks
Melodic Acoustic is offline   Reply With Quote
Old 07-19-2012   #219
Thanks for the tips Erin
I'll try it tonight
Old 07-21-2012   #220
Wesayso's Avatar
I hope this helps.
- Erin
Did you use one mic position or average several positions?
Old 07-21-2012   #221
... Squirrel!!!...
One location.
Follow my blog:
Data-bass.com
Old 08-14-2012   #222
Rep Power: 86 ///MJay will become famous soon enough///MJay will become famous soon enough///MJay will become famous soon enough///MJay will become famous soon enough///MJay will become famous soon enough///MJay will become famous soon enough
WOW!!!!! I really don't know what else to say...
Spent a little time setting the delay on my mid construction install. The results were so amazing I spent the entire night playing all my favorite tracks just to see what I have been missing all these years. Already this is the best sounding system I have built to date. I wish I had taken the time to learn more about the time alignment years ago when I picked up the Alpine in the first place.
Thank you OP and all others for the helpful information.
2000 BMW X5
Alpine 9835, Zapco 360.4, JL 450/4, JL 500/1
Peerless sls 8, peerless fullrange, vifa xt25, 2 JL 10w6v2
///MJay is online now   Reply With Quote
Old 08-14-2012   #223
Good job. Everybody knows a vehicle interior is a bad environment for a sound system, but few realize just how bad it is. All you've done is remove some of those negative effects.
Old 08-14-2012   #224
I hope this helps.
- Erin
I've learned a lot from you on DIYMA, Erin, and take it as a compliment that you would post this in my thread. However, the very point of my method is to eliminate the microphone from time delay tuning, and to use your ears instead.
Old 08-14-2012   #225
... Squirrel!!!...
My bad...
Follow my blog:
Data-bass.com
Tags
9255, alignment, bass, calibrate, delay, focus, image, midbass or range, phase, stage, t/a, time, time alignment, tweeter
