Update on new JL Audio Processors - Page 28 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-03-2017   #676
Rep Power: 148 vactor will become famous soon enoughvactor will become famous soon enoughvactor will become famous soon enoughvactor will become famous soon enoughvactor will become famous soon enoughvactor will become famous soon enough
Default Re: Update on new JL Audio Processors
after reading this whole thread, playing with the demo software, i think i will be getting a twk and a jl xd800 for a simple but very workable high end install. seems like a perfect solution for a 3 way front system with a single sub.
vactor is offline   Reply With Quote Quick reply to this message
Old 04-05-2017   #677
Rep Power: 26 bilbo6209 will become famous soon enoughbilbo6209 will become famous soon enoughbilbo6209 will become famous soon enoughbilbo6209 will become famous soon enoughbilbo6209 will become famous soon enoughbilbo6209 will become famous soon enough
Just to verify... I think I am seeing this in the software but wanted to make sure I wasnt missing something
I am going to be using a FIX 82 and a TWK 88 for my build... I know the TWK 88 had both a coax digital input and an optical digital input... can you use both of them, or are you limited to just using one or the other?
Also is there any difference in bit rate accepted etc between the optical and coax digital inputs? I know on some systems typically the coax input has better bit rate support.
bilbo6209 is offline   Reply With Quote Quick reply to this message
Old 04-05-2017   #678
robhaynes's Avatar
Product Training Specialist
Rep Power: 27 robhaynes will become famous soon enoughrobhaynes will become famous soon enoughrobhaynes will become famous soon enoughrobhaynes will become famous soon enoughrobhaynes will become famous soon enoughrobhaynes will become famous soon enough
You can use both the Optical and Analog inputs on the TwK 88. However only one of the two (Analog or Optical) can be assigned to inputs 1/2.
If using a FiX 82 I would recommend inputs 1/2 being Optical and then in other presets you can use analog inputs 3-8 as needed and disable the Toslink input.
robhaynes is offline   Reply With Quote Quick reply to this message
Old 04-05-2017   #679
I am also hooking up a Raspberry pi via digital (HiFiBerry Digi+ card) so I was really hoping to be able to use digital coming from the FIX and digital coming form the Raspberry Pi.
Old 04-05-2017   #680
VP Marketing
Rep Power: 133 msmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nicemsmith is just really nice
You can only use one for the whole project (all presets). In the Input Setup menu (click the little icon next to the word "INPUTS"), you will see a selector for Inputs 1/2: Analog, Optical or Coaxial.
You can run additional analog inputs on inputs 3-8, but you can't switch between the coaxial, optical or analog inputs on inputs 1/2. You have to pick only one.
No, in the TwK 88, both are capable of 24 bit/96 kHz max.
Best regards,
Manville Smith
JL Audio, Inc.
msmith is offline   Reply With Quote Quick reply to this message
Old 04-05-2017   #681
VP Marketing
You would need an external digital input switcher to select between the sources... or a D/A on one of them so you can go into one of the analog inputs. Then you can mix them, and switch them on/off via TwK presets.
Old 04-05-2017   #682
Darn it, that's what I thought in the software but I was hoping there was a super secret method for enabling both
Ok I'll go analog from the fix to the tweak and digital from the R-pi to the twk being that I will be using it the most.
Is there any difference between the 2 digital inputs? I seem to remember some other DSPs accepting higher bit rates on one digital input over the other (I think it is normally higher on the coax vs optical)
Old 04-19-2017   #683
VP Marketing
Both digital inputs are the same. Up to 24/96
Old 04-26-2017   #684
Rep Power: 0 scotsman will become famous soon enoughscotsman will become famous soon enoughscotsman will become famous soon enoughscotsman will become famous soon enoughscotsman will become famous soon enoughscotsman will become famous soon enough
i changed out the speakers in my 4runner and while the sound is better it still wasn't what I was looking for. After googling I've found that the 4runner factory headunit has some factory eq to protect the speakers. I have a Jl 900/5 amp on the way and think I need to get a fix-86 to flatten the eq, or would I be able to get by with a fix-82? I will use the amp on the component fronts and the co-ax rears, with a sub going in hopefully once the bm mkv is available.
scotsman is offline   Reply With Quote Quick reply to this message
Old 04-26-2017   #685
pocket5s's Avatar
Rep Power: 264 pocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond reputepocket5s has a reputation beyond repute
the fix 82 has 2 outputs while the fix 86 has 6 outputs. They do the same thing with regards to correction, so it just depends on how many outputs you want. Many will use a fix82 in conjunction with say the TwK (or other dsp), so they only need the 2 outputs for example. If you aren't going to use a dsp, then you may want the 6 outputs
Team MSE/JL Audio
2014 INAC Amateur runner up
2014/2015 MECA Modex OK state champion
Online Time Alignment Calculator
pocket5s is offline   Reply With Quote Quick reply to this message
Old 05-09-2017   #686
Rep Power: 0 ryansi will become famous soon enoughryansi will become famous soon enoughryansi will become famous soon enoughryansi will become famous soon enoughryansi will become famous soon enoughryansi will become famous soon enough
need help with my twk 88.. had it installed and did the tuning through the laptop.. when the twk is plugged into the laptop everything is fine.. when i unplug the laptop it will try to cycle through the presets on its on and eventually the the led indicator on the drc 200 will turn off completely.... called tech support they had me hard reset by unplugging the usb cable and holding the preset button on the twk itself for 25 seconds then starting a new project from scratch because they said the project may be corrupted... but it is still doing the same thing... if anyone has any clue as to what is going on and can help me that would be awesome.. thank you
ryansi is offline   Reply With Quote Quick reply to this message
Old 05-10-2017   #687
claydo's Avatar
Rep Power: 257 claydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond reputeclaydo has a reputation beyond repute
When you hook to the laptop via usb and open the software the drc is disabled......when you disconnect or close the software the drc is active.....sounds to me the problem lies with the drc controller. Did you damage the wiring or connector during installation? If not maybe you just have a faulty drc.....
claydo is online now   Reply With Quote Quick reply to this message
Old 05-10-2017   #688
Thanks for the reply I do not believe the wiring is damaged.. I was just playing with it before when I first started my car I had nothing at all same when I plugged it into the laptop it wouldn't pick up the twk... after turning the car on and off a few times it started to work so I played with the settings took the button on the drc apart put it back together then drove for 5 minutes so far no problems... I'm about to go on a longer drive to test it out more see if the problem has been corrected
Old 05-11-2017   #689
Ok so it's definitely not the drc 200... my twk started switching presets on it's own again so I tried to unplug the drc and it was still doing it... I'm almost thinko8ng it could be the preset button on the hardware itself is jammed, or faulty firmware on twk possibly, does anyone know if there is a way to update the firmware on the twk 88? The last possible thing I'm thinking it could be is because it does not run through a fix 82 or fix 86 first... because it is running off a factory head unit but I was told it will work anyways without it.... like I said when the laptop is plugged in it works perfectly so I was thinking faulty hardware... probably have to send it in for warranty service
Old 05-14-2017   #690
Rep Power: 0 Unsecured_WiFi will become famous soon enoughUnsecured_WiFi will become famous soon enoughUnsecured_WiFi will become famous soon enoughUnsecured_WiFi will become famous soon enoughUnsecured_WiFi will become famous soon enoughUnsecured_WiFi will become famous soon enough
I have a question for anyone using a twk88. I have had mine not turn on a couple of times and it seemed like it was just passing audio with no filtering. After that it turns on now but the lights stay amber and i have more hiss coming from the speakers. if i unplug the rca's i dont have the hiss anymore so it came from the twk after its goof up. Does anyone have any other troubleshooting tips or should i try for a rma?
Unsecured_WiFi is offline   Reply With Quote Quick reply to this message
Old 05-18-2017   #691
I just installed my Fix86 and the inputs flash red every 5 seconds or so, which I believe means input clipping? Is that ok, or is there something I should change?
Old 4 Weeks Ago   #692
VP Marketing
If you need technical assistance, give the JL AUDIO Tech Dept a shout.
888-JLAUDIO or technical@jlaudio.com
Old 4 Weeks Ago   #693
MSmith,
Is there a place we can post suggested changes/improvements to the JL Processors?
I am in the process of upgrading my car, and will be getting a newer car with a MOST audio network... I will be using some form of MOBridge to convert the MOST signal to either 1. Digital (most likely toslink, but could be coax) OR 2. Analog... I am also running a Digital Audio player that outputs digital via either Coax or Toslink... It seems a waste to have to pay extra for a MoBridge that takes Digital, converts it to Analog, feed that to a DSP that will in turn convert it back to digital, tweak it, and then convert it back to analog.... It would make a ton more sense to be able to have the different Presets in the TWK be able to point to either Digital Coax OR Digital Toslink, not all or none like it currently is
I know I could have a separate switch to switch between 2 digital inputs and feed 1 output to the TWK, but I am trying to keep things simple and not have to have a 2nd device I have to touch anytime I want to switch input devices.
I know in the TUN software you can choose what digital input you want, but then ALL presets are locked to that digital input and you cant have a mix of Coax and Toslink.
I already have a current gen Fix 82 and Twk88 but if this would require an update to hardware I would be willing to re-buy a newer version of the TWK to get this functionality.
Old 4 Weeks Ago   #694
Rep Power: 13 Mahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enough
Mine seemed to do that randomly and the knob didn't work at that point either. I think it was the rj45 connection pulling tight and losing connection. Gave it some slack and havnt had that issue for more than 2 months. Hope this helps.
Mahapederdon is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #695
VP Marketing
MSmith,
I am afraid that this is a limitation of the hardware, not the software. In a future product, we will look into offering multiple, switchable, digital input buses.
Best regards,
Manville Smith
JL AUDIO, Inc.
Old 1 Week Ago   #696
TxHouse's Avatar
Rep Power: 84 TxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enough
I've been messing with the tune 2.0 software using the fix 86 demo and I don't see it but thought I would ask. Is the Fix 86 active capable or would I have to get the twk to do that?
2010 Ram Crew Cab Laramie
Front Stage: Focal 165krx2, Mosconi AS100.2, Audiocontrol LC8i
Sub Stage: 2 x 12w6v2, JL 1000/1v2
TxHouse is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #697
pocket5s's Avatar
The FiX is only mean to correct an OEM signal. The new updates allow you some eq options on top of that. That is all it is meant to do. So yes, you'd need the TwK for further processing.
Team MSE/JL Audio
Old 1 Week Ago   #698
Rep Power: 79 josby will become famous soon enoughjosby will become famous soon enoughjosby will become famous soon enoughjosby will become famous soon enoughjosby will become famous soon enoughjosby will become famous soon enough
Is there any plan to add the ability to handle a center channel input to the FiX?
2016 Civic Touring build log - current build status
josby is online now   Reply With Quote Quick reply to this message
