#1 (permalink)
Disclaimer: This review is completely subjective, and will have no real data supporting any outlandish claims that may or may not be contained herewithin. These are just my initial impressions after connecting and listening to the drivers. Your results may vary. That being said, on with the review!
This review is for the H Audio TRINITY 3" mid/full range driver. The Trinity is a 3" mid/fullrange driver from H-Audio that has a nice titanium/magnesium cone material. It also has a compact motor and basket, shallow mounting depth (under 2") and excellent build quality. It is visually very similar to the Fountek FR88 as they share the same basket and magnet, however the Trinity has a higher grade copper in the motor, and more of it. It also has a different cone material and color. The drivers are 4ohm impedance and rated for 15w/30w peak RMS power handling. Testing Environment: The drivers were installed into PVC test enclosures (appx 0.75 liter volume)which were sealed and placed on the dash of my 2003 Lancer aimed on axis to my drivers seat position, slightly lower than ear level. They were placed as close to the edges of the dash (A-Pillars) as possible to simulate the prospective mounting locations. Testing Equipment: The Trinity's were powered by an Xtant 404m amplifier, bridged down to 2 channels, providing appx 200 watts @ 4ohms per driver. A second Xtant 404m amplifier was bridged to 2 channels providing 100 watts @ 8ohms per driver to a pair of M&K SLS 8" midbasses which were installed in the doors. Gains were adjusted for L/R to provide audibly equal output from the drivers position. Signal and processing duties are handled by a Clarion DRZ-9255 source unit. The DRZ output gains for the TRINITY and SLS drivers were adjusted by ear to match levels appropriately. Time alignment was used as well. Further tuning could be done in addition to really dial in this setup, however, since these are test enclosures (not permanently mounted) I wanted to just get a feel for how the drivers would be able to perform. Testing Material: Various discs and tracks were used including the Focal "Spirit of the Sound" Demo cd and my Master Demo disc. (Search for "Focal Demo Discs" on the site...) -------------------------------------------------------------------------- Photos: ![]() ![]() ![]() ![]() ![]() ![]()
#2 (permalink) |
![]() ![]() ![]() ![]() You can see above the visual comparison to the FR88 as well as the Tang Band W3-1364SA. Listening Impressions: I listened to a number of tracks that I use for testing all of these drivers, to keep things pretty consistent. Im not going to go into great detail as to what I heard on each track etc in this review, but I will give you my overall descriptions and impressions of these drivers. I tried them in the 0.75 sealed enclosures as well as wrapped in cloth on the dash to see the difference the enclosure would make. The TRINITY is a very smooth driver indeed. When I tested the Fountek FR88, I noted that they had a bit of the usual "metal cone sound" due to the bright nature of the aluminum cones. The Trinity does not exhibit any of this. It actually surprised me by its more laid back and smooth nature. Mark was right about the titanium/magnesium combination making for a smoother overall sound. On axis, I felt that these drivers didnt quite have the high end extension that the Tangband W3-1364SA or the FR88 had. It was not lacking much, but a little. I believe these were designed to be used in tandem with a small tweeter and I would recommend the use of a tweeter OR using a touch of EQ to add just a little top end. They may actually be just fine for some as they are, but I prefer a more detailed upper frequency range and by addding just a little bit of EQ from 10K up, these sounded pretty damn good. Male and female vocals have very nice detail and are not harsh or in your face by any means. The spots where I noticed a lack of top end detail were in cymbal strikes mainly. A little EQ fixed that up quite well. (+2db @16K, +1db@ 12.5K, +0.5db@10K) They are clear and accurate and played quite well crossed at HPF 315Hz -18db on up. Tonality was quite good and imaging after my usual tuning was tight and locked dead center. Off axis response yields a noticeable drop off in upper frequency extension, so a tweeter is a must in those mounting configurations. I also noticed that they have really good sensitivity as well. It doesnt take much power to get these drivers up to a spirited volume. Overall, I think these are very, very good. If you're looking for a full range driver to run to 15K I think they will serve you quite well (EQ-ability allows even more potential). If you mate them with a small silk tweeter like the H-Audio Enigma, I think they are a definite winner - A well built, compact, and great sounding widebander. |
#3 (permalink) |
Nice review....I'd like to try a pair but will probably start w/something budget first like the TB 3"....
Jeremy |
#4 (permalink) |
Thanks for the review! I have been waiting for these but as it always seems to happen....things come up now that the drivers are available.
#6 (permalink) |
H-Audio Inc USA Position:
National Product Director iTrader: (38) |
Thanks for the great and honest review sir.
You would be correct, the Enigma High-Res tweeter was brought about if some one want to add that last little bit of top end detail to the Trinity do to its smooth and natural, but detailed sound or any to other wide-band driver for that matter. IHMO (not that it matters ) the ET 2-way (Enigma and Trinity) crossed at 10-12khz is a combo for 315hz-up to is hard to beat at any price range. I can also tell you this; as the Trinity breaks in even more, it gets better. I recommend 20-30 hours before any critical listening is done as you did. The total break time is around 80-100 hours via the designer/builder of the drivers. I would have to say that is very close to being correct as the more I listen to them the better things got. The high-end extend a little better as did the low-end. I would have to say it is do to the strong motor over the FR88-ex and the higher quality of parts used in the motor. |
#7 (permalink) |
Hey Mark, how well would the Trinity do crossed around 250Hz with either an 18db/oct or 24db/oct slope?
#8 (permalink) |
They still sounded decent to my ears Zach. I tried them as low as 200hz, in enclosures, and out of the enclosures but wrapped in cloth and they seemed to do pretty well there in both instances. Im not sure what distortion graphs would show at that point, but to the ear they played pretty well. I would probably stick to a higher cross point though if your midbasses are capable enough to extend into that range. |
#9 (permalink) | |
I'll experiment with the Trinity when I get my turn. But I'd like to stay between 250-300Hz if at all possible. This is with the mid in a .9L sealed pod.
#10 (permalink) | |
If your mid/bass can play to 1khz without a problem 300-400 would be a better point as captainobvious stated; as the resolution and detail would improve a bit from the small driver not having to extend low and use so much of its excursion. Not that is will sound bad or anything like that is just what I have notice from testing so many drivers. The less work the driver has to do the better the detail. |
#11 (permalink) |
Thanks for another well thought out review, i've just ordered a pair.
My active HU doesn't have the most flexible cross overs unfortunately, i wanted to cross the Trinitys at 250-300hz with some thing like a 18db slope. The lowest it can be set is about 600hz iirc, if i use this with a 6db slope will that be OK do you think ? They are going to be paired up to some SLS 8" which i just got today. |
#12 (permalink) |
Creatiive Sound Technology Position:
Founder iTrader: (0) |
I use H-audio speaker setup in my car.
my systems consist of alpine dvd, PXA. ppi power amps and old lanzar Sub i use Ebony midbass , FR88ex/X3/AP3FR and Enigma Tweeter. ![]() in this photo i use FR88EX ![]() in AP3FR and Enigma Tweeter i also tested FR88ex with Soul midbass ![]() tested X3/AP3 in TL Box ![]() My RTA response in car Green left speakers yellow right speakers ![]() Black Box Pro |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) | |
I'm with you, I try not to run any driver to its limits. It just insures clear and dynamic sound reproduction. |
#16 (permalink) |
The only real downside I see to these drivers is their high price in comparison to say the Fountek or Tang Band.
Overall great review. I really like your standardized format; it makes it very easy to read and compare to your other reviews. |
I create high quality system diagrams for both the competitor and enthusiast alike. Contact me if you want one done!
#17 (permalink) |
Or cheap when compared to the Scan 12m and other similar drivers.
#18 (permalink) | |
#19 (permalink) | ||
It seems as if these Trinity drivers are right in the middle in terms of price but have some pretty good potential in terms of sound....just a matter of choice....the more the better. IMO, I would rather spend the $180 on these now then go all out at the $500-$600 range for something like a FOCAL Be driver. Others, will go for the $50 Fountek or the $100 Tang Band set and not spend a dime more. All nice sets! I WILL REPEAT, it is all about choices....the more the better....no need to compare prices....Stay within your budget....there are NICE 3"-4" drivers in every price range right now, today, October 1, 2009! |
#20 (permalink) |
^^ Very true. However, I will say this much...Higher price does NOT mean substantially better quality or better sound.
The $50/pair Fountek FR88 and $60/pair Tang Band W3 bamboo's are easily as good in both quality and sound departments as the big dollar drivers. The thing is, each of these drivers has a different overall sound, so I would recommend starting with the material that suits you best. Paper/ aluminum / mixed alloy metals / poly, etc all have some different sonic qualities because of the mass and stiffness of the cones. I prefer paper and paper hybrid cones myself and because of that I ws naturally drawn more to the warmer sound of the Tang Band W3 bamboo's, the HAT L4's and surprisingly, even these Trinity's with the softer metal alloy. |
#21 (permalink) |
Thanks for another great review. On a side note, did you notice a difference between the M&K SLS8 and the 830667?
#22 (permalink) | |
I think the extra low end is probably noticed due to the higher qts, with both drivers being mounted in doors of a guestimated 40liters or so. My preference is defintely the cleaner Peerless 830667. I'm also very interested in trying the Usher 8955A 8" driver as that should have excellent HD performance in the range Im using them at, and they would allow me more flexibility with a higher crossover point (say 400-500hz) to ease up on the Trinity mids. Anyone have experience with the Ushers in doors or IB? Shame Mark doesnt have an 8"er to try out with these yet ![]() Oh, and I DO now have the Enigma's in my posession so I will be testing out the Trinity's along with the Enigma tweeters most likely next week. Stay tuned.
#23 (permalink) |
Thanks for that. I've got the 830667 in my doors playing the same range as you are, but I couldn't help but wonder about the M&K's. I wonder no more.
#24 (permalink) |
How are you finding the Trinitys now you've had them a while ?
Which out of all the WB drivers you've tested are you going to use long term ? Thanks |
#25 (permalink) | |
I have the Enigma tweets in my posession and I am trying to find some time here to get them tested. Im moving to a new house soon here so there is alot going on right now. But I WILL get up a review with the Trinity/Enigma combo as promised. |
LinkBacks (?)
LinkBack to this Thread: http://www.diymobileaudio.com/forum/member-product-reviews/66584-h-audio-trinity-review.html
| Fountek FR88-EX enclosure - diyAudio | This thread | Refback | 2 Weeks Ago 06:58 AM | |
| Point source - Page 2 - Talk Audio Forums | This thread | Refback | 01-30-2010 07:49 PM | |
| Mixing CDT speakers - Realm of Excursion | This thread | Refback | 01-19-2010 01:09 AM | |
| H-Audio Inc. USA | Post #0 | Refback | 01-13-2010 11:47 AM | |
| Point source - Page 2 - Talk Audio Forums | This thread | Refback | 12-25-2009 06:07 AM | |
| Point source - Page 2 - Talk Audio Forums | This thread | Refback | 12-24-2009 11:08 PM | |
| H-Audio Inc. USA | This thread | Refback | 12-13-2009 08:25 AM | |
| H-Audio Inc. USA | Post #0 | Refback | 11-10-2009 07:34 PM | |
| Mixing CDT speakers - Realm of Excursion | This thread | Refback | 10-21-2009 03:29 PM | |
| H-Audio Inc. USA | This thread | Refback | 10-14-2009 07:26 AM | |
| H-Audio Inc. USA | This thread | Refback | 10-01-2009 08:57 PM | |
