DEX-P99RS Ongoing Review and Discoveries - Page 35 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-30-2015   #851
Rep Power: 0 beehiveramesh will become famous soon enoughbeehiveramesh will become famous soon enoughbeehiveramesh will become famous soon enoughbeehiveramesh will become famous soon enoughbeehiveramesh will become famous soon enoughbeehiveramesh will become famous soon enough
Default Re: DEX-P99RS Ongoing Review and Discoveries
Originally Posted by Elektra View Post
Thanks for the tip.. Must I strip the radio? Or can this be done in the car with no stripping?
Did the cleaning help in restoring the functionality of the vol control knob ?
beehiveramesh is offline   Reply With Quote Quick reply to this message
Old 08-30-2015   #852
Rep Power: 296 Hanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond repute
Originally Posted by CoLd_FuSiOn View Post
Can anyone tell me their experiences with particular hard drives that work perfectly with the p99 and ordered from amazon with the links?
The more the merrier and preferable something durable,but the most important factor being that it is tried and tested since I don't intend to order a hard drive and then find out that it's not working with the head unit.
I've tried three hard drives, one 120GB SSD and two different 500GB drives - all of them worked. However, I wouldn't recommend it. Sorting music properly is near impossible and access is slow. I think all drives will work more or less as long as you format them with FAT32 filesystem and have an external power source.
iPod/iPhone storage is sooo much better. If you store in high quality mp3s you can fit 5000-6000 songs on a 64GB unit.
Edit: You might need to partition the disk if its' above 250GB (or so) for some reason, I remember I had to do this, otherwise you might get some fault code "no audio...".
Old 09-07-2015   #853
CoLd_FuSiOn's Avatar
Rep Power: 62 CoLd_FuSiOn will become famous soon enoughCoLd_FuSiOn will become famous soon enoughCoLd_FuSiOn will become famous soon enoughCoLd_FuSiOn will become famous soon enoughCoLd_FuSiOn will become famous soon enoughCoLd_FuSiOn will become famous soon enough
Thanks, do you remember which brand and model they were?
Sent from my One Plus One using Tapatalk
CoLd_FuSiOn is online now   Reply With Quote Quick reply to this message
Old 09-07-2015   #854
WD Green in an external case, I have no idea the type of usb/sata chip it is in those...
Skickat från min SM-G900F via Tapatalk
Old 09-09-2015   #855
Rep Power: 66 Elektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished road
Guys I am having a problem with Pioneer HUs in general - I have a BNIB P90RS, P99RS, RS-D7Xii
When using the AUX function on all of these radios - the right channel is about 75% lower in output compared to the left.. Using IPBUS to RCA cable - CD-RB20 - has anyone experienced this?
I suspect a design fault on the board - how can all 3 HU measure exactly the same on both channels?
Has anyone got the service manuals for these radios?
Elektra is offline   Reply With Quote Quick reply to this message
Old 09-09-2015   #856
I'm using an adaptor myself and it works fine , there's probably an issue with your adaptor cable or your auxiliary cable.
Old 09-09-2015   #857
Ok... So I used a scope to measure the left and right signal coming into to HU and what is coming out - IPBUS in and IPBUS out to DSP both the signal coming in and out the IPBUS measure the same on the board.
But.... If you measure on the RCA plugs (both HU and DSP) the right channel is significantly less than the left.. So somewhere on the board going to the RCA plugs the signal is lost..
So it's not the cable as it measures equal both sides, it's not anything to do with the IPBUS coming in and out the radio (ODR and P90 to RS-P70x) it's not the DSP as its doing the same on the P99 and P90 HU RCA outputs it's not the DSP as I tested the DEQ P90 as well..
Considering one HU (P90) is brand new and the P99 is about 2 years old and the ODR is about 7 years old - they all measure EXACTLY the same...
Before with the P90 combo the stage would shift when selecting CD and AUX - using the CD-RB20 (original part - also new) the cable is King Cobra RCA cables tried and tested multiple times before..
Old 09-29-2015   #858
avanti1960's Avatar
Rep Power: 78 avanti1960 will become famous soon enoughavanti1960 will become famous soon enoughavanti1960 will become famous soon enoughavanti1960 will become famous soon enoughavanti1960 will become famous soon enoughavanti1960 will become famous soon enough
posting a quick update- the DEX P99 is still rocking on and sounding better than ever!
System was sounding a little flat so I did a quick RTA using my laptop and True RTA software.
Whoa! The lower treble region was down in the mix some 15 db! Apparantly the result of lots of on-the-fly daily EQ adjusting.
I lowered the midbass driver levels and adjusted the EQ so that I was running an "Andy Curve" basically +10 db 20 to 60hz, taper down to flat at 160Hz, then flat until 2Khz with a slight taper (~ 1-db per octave) down from 2K.
MUCH BETTER! Rule of thumb- not a bad idea to check your sound with RTA every once in a while.
Another tweak- the image was shifted slightly "left" and would not center with balance or level adjustments.
So I adjusted the time alignment by adding distance to all of the right channels by equal amounts- basically five up clicks on each driver until the sound was centered. It only took one adjustment and everything was fine.
Since the front right drivers were all phase / time aligned to each other, adjusting all of them together shifted the center image and maintained their relative phase to each other.
Sounds AWESOME!
Old 09-30-2015   #859
Dangerous to have a "on-the-fly" EQ available sometimes...
Old 10-01-2015   #860
Rep Power: 137 benny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nicebenny z is just really nice
Picked one of these up to finally replace my OEM source unit (after 5.5 years running it and swearing I'd not replace it). I use Zapco DC reference amps and am using this to further fine tune with the graphic EQ. Holy crap, I thought my center image was focused before - now it's pin-point accurate across the spectrum.
ben zimmerman
co-founder - SQOLOGY
team hybrids : team brax-helix usa : team mobile audio plus : team strictly sound quality
benny z is online now   Reply With Quote Quick reply to this message
Old 10-02-2015   #861
Coppertone's Avatar
DRKNESS
Rep Power: 127 Coppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of light
Darn that looks right at home installed in there.
(2.5GT) Limited Legacy / Alpine INA-W910 /Audison APK-165....
JL Audio 12TW3-D4 FOR Sale with grill.
^^^ FOR SALE
Old 10-18-2015   #862
Rep Power: 73 Socalstangman will become famous soon enoughSocalstangman will become famous soon enoughSocalstangman will become famous soon enoughSocalstangman will become famous soon enoughSocalstangman will become famous soon enoughSocalstangman will become famous soon enough
Does anyone use this deck with the Ford SYNC set up?
Socalstangman is offline   Reply With Quote Quick reply to this message
Old 10-27-2015   #863
Architect7's Avatar
SQ Crazy
Rep Power: 113 Architect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enoughArchitect7 will become famous soon enough
I had a really strange thing happen with my P99 last week. I'm sitting at a stoplight on my way home from work and the P99 screen goes dark but music keeps playing. It wouldn't respond to any buttons and jiggling the faceplate didn't do anything. When I got home I shut off my truck, removed the key, then put the key back to ACC and the P99 came back on with no issues as if the screen shutdown/lockout never happened. Anyone seen this happen before? It hasn't happened since, super weird...
Architect7 is offline   Reply With Quote Quick reply to this message
Old 10-27-2015   #864
Vaani Acoustics
Founder/Engineer
Rep Power: 100 piyush7243 will become famous soon enoughpiyush7243 will become famous soon enoughpiyush7243 will become famous soon enoughpiyush7243 will become famous soon enoughpiyush7243 will become famous soon enoughpiyush7243 will become famous soon enough
This happens when the connector of the faceplate or the hu gets carbon deposit. Clean connectors on both the faceplate n hu with a mild solvent. This should fix it
Sent from my X9076 using Tapatalk
piyush7243 is offline   Reply With Quote Quick reply to this message
Old 10-27-2015   #865
Architect7's Avatar
SQ Crazy
Piyush, THANK YOU!!! I was scared my beloved HU was slowly dying. Hope you've been well!
Old 10-27-2015   #866
Vaani Acoustics
Founder/Engineer
Things off-late have not been rosy but getting into the groove slowly. Hope there are better times ahead. Also few more days and i will be in touch for something that i have to give to you.
Old 10-27-2015   #867
Architect7's Avatar
SQ Crazy
I like the sound of that! Good to hear things are picking up for you, I am sure it is because you are doing something you love
Old 11-05-2015   #868
bertholomey's Avatar
Rep Power: 157 bertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the roughbertholomey is a jewel in the rough
I have a quick question that someone might be willing to give me a quick answer if not....I guess you can just tell me to read the entire thread
I just bought a very, very cool FiiO X5ii and I want to hook it up to the P99. Not as a main source, just every once in a while.....for fun.
I thought I could turn on Aux1 in the menu, hook a stereo plug (not sure of the mm) from the headphone out to the aux jack on the edge of the faceplate when it is open......Fail. My stereo plug is too big (I can hear a, 'that's what she said!' right there).
What size is this plug in on the faceplate.....is there an easy adaptor to step from the stereo plug down to this size. OR........the Aux 2 on the back of the 99......I believe there is an adaptor for that that might take stereo RCA? My X5ii can send coax out.....is there any options for that?
I know I just need to research this, but my curiosity is higher than my available time at the moment. If someone has already crunched this problem - that would be awesome to get a shortcut
bertholomey is offline   Reply With Quote Quick reply to this message
Old 11-05-2015   #869
Vaani Acoustics
Founder/Engineer
You can easily get a 3.5mm to 2.5mm converter. As p99 has a odd 2.5mm size
Something like this
http://www.amazon.com/gp/aw/d/B00U11...nYL&ref=plSrch
Sadly no coax for p99
Old 11-05-2015   #870
Something like this
Awesome! Thank you very much for the link Extremely helpful!
Old 11-19-2015   #871
derickveliz's Avatar
Rep Power: 109 derickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enough
Sounds AWESOME!
I agree 100%
D.
My system may not blow your ears, but it will sweeten your senses.
Mercedes Benz CLA 250, Pioneer P-99, IDQ12d4v3 Subwoofer, ... ID min Horns, 6.5" Midbass!
derickveliz is offline   Reply With Quote Quick reply to this message
Old 12-02-2015   #872
Ok, so I've been tuning for a while and I was just about to hit the sweet spot, when I thought about turning the Auto EQ "on" ... BAN! the Sweet spot came alive!
I've done this before and most of the time doesn't sounds right, either boomy and/or harsh, wonder why when my tuning was getting really good the Auto EQ gave me that extra step and made the stage rich that sweet spot.
Anybody has an idea if the Auto EQ is a default setting in the P99 or it's really driven by the mic and the Auto Tune?
Cheers! to all P99 owners and how fortunate we are.
D.
Old 12-02-2015   #873
Huckleberry Sound's Avatar
Rep Power: 113 Huckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enough
Thump!
Huckleberry Sound
Huckleberry Sound is offline   Reply With Quote Quick reply to this message
Old 12-02-2015   #874
Architect7's Avatar
SQ Crazy
D.
Yes, Auto EQ is performed via test tones and the mic to flatten the frequency response in the installed vehicle. No default EQ settings used, it requires actual measurements to make the final adjustments that make it sound so good
Old 12-02-2015   #875
Babs's Avatar
Scott
Rep Power: 177 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
D.
It's driven by mic reading into Pioneer's algorithm. Once you run auto-EQ on the 99RS, I'll bet you can't see the "auto-EQ" trims, like the 80PRS, which is a shame.
Build Log
Babs is online now   Reply With Quote Quick reply to this message
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
