Acoustic Elegance SBP15-4 review - Page 3 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-10-2013   #51
BuickGN's Avatar
Rep Power: 162 BuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to behold
Default Re: Acoustic Elegance SBP15-4 review
Originally Posted by strakele View Post
The thing is, leaving the trunk wide open doesn't make a difference in my Car at all.
How many subs are you runnning?
'84 GN 10.60@ 127mph.
'07 Epic Expert
'06 TL.
Old 06-10-2013   #52
Diyma Ninja
Rep Power: 249 thehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud of
No where near enough suspension to support 18mm one way.
Originally Posted by IBcivic View Post
The AE's IB12Au has 18mm of excursion.
Old 06-10-2013   #53
Diyma Ninja
Acoustic Elegance iB12-8
Klippel verified to not be near 18mm one way excursion.
Old 06-10-2013   #54
BuickGN's Avatar
I think the IB12 (AU12) klippeled around 10mm one way travel suspension limited. I believe it was said this type of distortion is less offensive than BL or inductance.
As far as suspension, it is the limiting factor, these are IB subs afterall. I don't know about the IB12 but the IB15 which I believe shares the motor and spider with the 12 will most definitely do 18mm one way and more. I don't know if it's linear but it will mechanically exceed 18mm. Unless the surround is what limits the 12, I don't see why it shouldn't have the same travel as the 15. I've hit them with 18hz test tones when I first installed them while watching them to get an idea of where to limit volume. I pushed them farther than I was comfortable and they had some serious excurion. The thing about these subs is the sound doesn't seem to change as you turn the volume up. They sound exactly the same at high output as low output. Maybe it's the inductance treatment.
I believe going by BL, xmax was 18.5mm.
I was never aware the SBP subs had less travel. They have more motor strength, slightly lower distortion, same cone and spider and surround as far as I know, only the motor is different. I thought xmax and xmech were the same. Maybe it's time to get John in here to clarify.
'07 Epic Expert
'06 TL.
Old 06-10-2013   #55
decibelle's Avatar
Fire Hazard
Rep Power: 88 decibelle will become famous soon enoughdecibelle will become famous soon enoughdecibelle will become famous soon enoughdecibelle will become famous soon enoughdecibelle will become famous soon enoughdecibelle will become famous soon enoughdecibelle will become famous soon enough
And it does in mine...
decibelle is offline   Reply With Quote Quick reply to this message
Old 06-10-2013   #56
BuickGN's Avatar
What's the chance of you two or even just one of you throwing some pillows in there like I did? I just want to see if anyone else notices the same change. I believe one person experienced the same thing but I know you guys have everything already tuned very well.
'07 Epic Expert
'06 TL.
Old 06-10-2013   #57
decibelle's Avatar
Fire Hazard
I did just for funsies. Minor difference in closed trunk with no pillows and closed trunk with pillows. Not as drastic as open trunk though.
Old 06-10-2013   #58
Rep Power: 82 Schizm will become famous soon enoughSchizm will become famous soon enoughSchizm will become famous soon enoughSchizm will become famous soon enoughSchizm will become famous soon enoughSchizm will become famous soon enough
Pillow fight strakele when he gets home!
Originally Posted by AWC View Post
[he has the] personality of a syphalytic hedgehog trying to facef#ck its way into infected sinuses
Schizm is offline   Reply With Quote Quick reply to this message
Old 06-10-2013   #59
strakele's Avatar
Rep Power: 123 strakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura about
2. Will try some pillows and other stuff when I go out to do some experimenting later.
Living Room System Build Log
Old 06-10-2013   #60
Rep Power: 95 addmd will become famous soon enoughaddmd will become famous soon enoughaddmd will become famous soon enoughaddmd will become famous soon enoughaddmd will become famous soon enoughaddmd will become famous soon enough
Those aren't pillows! ........... How about them bears?!?
addmd is offline   Reply With Quote Quick reply to this message
Old 06-10-2013   #61
IBcivic's Avatar
Back Yard Installer
Rep Power: 151 IBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really nice
Silly me for believing AE's advertised claims.
IBcivic is offline   Reply With Quote Quick reply to this message
Old 06-10-2013   #62
S.A.-K.I.D.'s Avatar
Rep Power: 0 S.A.-K.I.D. will become famous soon enoughS.A.-K.I.D. will become famous soon enoughS.A.-K.I.D. will become famous soon enoughS.A.-K.I.D. will become famous soon enoughS.A.-K.I.D. will become famous soon enoughS.A.-K.I.D. will become famous soon enough
Thanks for sharing this thread, it was very enlightening & cleared most of my trivial concerns. For me, it's all for enjoying the journey to enjoying the music. Be well, be safe, & take care of ones ears.
If one is giving a chance to only have one, cake or icing, which would you chose? Give me the cake(substance), to hell w/the icing(superficial). Silent Assassin - Killing Ignorance Daily aka Smart Ass - Keep It Down.......
S.A.-K.I.D. is offline   Reply With Quote Quick reply to this message
Old 06-10-2013   #63
BuickGN's Avatar
I haven't seen that movie in 10 years. Now I want to see it again.
'07 Epic Expert
'06 TL.
Old 06-10-2013   #64
That hotel scene was filmed near my childhood home. Big news for a small town. Steve Martin and John Candy......classic!
Old 06-11-2013   #65
Diyma Ninja
I had a 12 and 15...and even at first glance I had really serious doubts about the small spider and surround being able to support the advertised claims about excursion. And then I started thinking about the suspension on the ID Maxes I had and Audiomobile Mass 2012 I had back in the day...both of which had roughly the same throw these are claimed to have, and both had much more robust suspensions. The suspension on the 15 was smaller than the IDQ-15 I had setting next to it, and the IDQ was advertised with much less throw.
I am not saying they aren't great speakers...just the excursion claims are a bit off. Which, you will see time to time like I saw in the SDX-7s I used to have
Old 06-11-2013   #66
strakele's Avatar
Seems like xmax is generally rated by a mechanical property like voice coil overhang, rather than how long it is truly linear.
Not a single Speaker Erin has tested on the Klippel has met the claimed xmax, that I've seen anyway.
Old 06-11-2013   #67
BuickGN's Avatar
What I get out of it is if xmax were based off of BL the claimed xmax would be spot on. The suspension limits it no doubt but it kind of has to in an IB specific sub unless it uses technology like JBL uses.
What I want to clarify is even if it isn't linear, these subs will most definitely travel more than 18mm. I've had them to roughly 2" peak to peak travel back when I had them on 1,000w and they sounded fine. Don't most people think that distortion from suspension compliance is the least offensive? Meaning that BL and LE distortion are still very, very low still when it hits the 10.8mm xmax based on suspension? Or said another way, the sub is not going to just give up after 10mm of throw, it's still going to sound very nice way past that excursion level.
Not totally irrelevant is the higher than average cone area for a 15" sub so it does not have to move as far for the same SPL. Even when I'm not caring that much for SQ and I just want the subs to drown everything out, excursion is always surprisingly low when I take a peek at the subs. That's the nice thing about a pair of 15s with lots of cone area, they don't have to move much to generate decent output. Even at 10mm they're seriously loud. Usually with mild to moderate listening volumes these subs rarely move more than a couple mm. Most of the time I can't see them move.
I agree that the spider is probably holding it back. I would guess it's the spider and not the surround anyway in which case it might possibly change xmax between the 12 and 15. Looking at my 12W6 it has a spider that's at least as large as the cone. Same with the 13W7. I wish there was a way to use a really great suspension on these subs. I'll still probably end up with a pair of 13W7s eventually. The have almost as much cone area as a low cone area 15 and with over 4" of peak to peak mechanical throw they will have more output.
'07 Epic Expert
'06 TL.
Old 06-11-2013   #68
subwoofery's Avatar
Rep Power: 279 subwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond reputesubwoofery has a reputation beyond repute
Other than PA drivers, I've only seen 3 drivers meet or exceed their rated Xmax:
JBL Gti660 mid (Erin) - rated as 5.36mm and tested to have 7.4mm
Scan 18WU mid (Erin) - rated as 9.00mm and tested to have 9.1mm
Dayton Ultimax (VC Mag) - rated as 19.00mm and tested to have 21.9mm
Kelvin
Lycan
Old 06-11-2013   #69
BuickGN's Avatar
Add the Dynaudio 430 to that list. 3.5mm klippel verified. 2.45mm manufacturers claim.
'07 Epic Expert
'06 TL.
Old 06-11-2013   #70
subwoofery's Avatar
More like 2.6mm (BL limited) Klippel tested but yeah, it's now on the list
Kelvin
Lycan
Old 06-11-2013   #71
BuickGN's Avatar
Kelvin
Two different 430s were tested at separate times. The first one was mine shipped brand new from Dyn to Erin. He saw my speakers before I did. They had zero play time and that was the one with 2.6mm xmax.
Later Erin used one of Jerry's well broken in 430s and that is the one with 3.5mm xmax. Some people debate the importance of break-in but I put more weight on the broken in one especially knowing how consistent Dyn is in their specs and build.
'07 Epic Expert
'06 TL.
Old 06-11-2013   #72
subwoofery's Avatar
Totally correct.
Kelvin
Lycan
Old 06-12-2013   #73
Diyma Ninja
I thought the v3 IDQ-10 met it's advertised claims...and it has a suspension much larger and roubst than the AE for the same amount of throw.
The Dayton Reference 12 tested here met it's claims of 14mm. I have the 15, and it too has a much larger suspension than the AE 15 I used to have had.
Old 06-12-2013   #74
strakele's Avatar
To bring this slightly more back on topic.. ignore what I said about the pair of IB15s sounding totally different in my Car than the single SBP15 in Ally's. I had the freaking subsonic filter on the amp up which is why I thought mine were lacking in the low lows. It's all good now.
SBP15 is an outstanding sounding sub regardless.
Old 06-12-2013   #75
Diyma Ninja
I bet it is...was my first choice, just didn't have the funds for it.
