Old 04-24-2012   #1
captainobvious's Avatar
Rep Power: 108 captainobvious will become famous soon enoughcaptainobvious will become famous soon enoughcaptainobvious will become famous soon enoughcaptainobvious will become famous soon enoughcaptainobvious will become famous soon enoughcaptainobvious will become famous soon enough
Send a message via AIM to captainobvious
Arrow From a DRZ to a DEH-80PRS...will I be dissappointed?
In my last install, I ran a DRZ-9255 and absolutely loved the clean sound from that unit. (I've also previously used a Denford 8250m and an old Sony ES CDX-C780)
I am currently planning a new install in a different vehicle, and I'm looking hard at the new Pioneer deh-80PRS. I know it doesn't have quite as much flexibility in the tuning department (3-way active vs 4-way, etc), but what I'm concerned omst about is the sound. How will this compare sound wise to the other top units out there (p99rs, DRZ, etc) ?
My only other hang up is the crossover settings...why oh why can't they have more HPF settings on the MID section of these? If you want to run a 3-way active system up front, the highest you can cross your mids at is 250hz. Would love a few more optoins up there as it makes running a 3" driver (which is much easier to install) much harder.
captainobvious is offline   Reply With Quote
Old 04-24-2012   #2
Rep Power: 48 Lars Ulriched will become famous soon enoughLars Ulriched will become famous soon enoughLars Ulriched will become famous soon enoughLars Ulriched will become famous soon enoughLars Ulriched will become famous soon enoughLars Ulriched will become famous soon enough
Default Re: From a DRZ to a DEH-90PRS...will I be dissappointed?
Just made a move from DRZ to P90RS....Not regretting at all....but will still be keeping my DRZ....each have their own strength...but P90 is better...
Lars Ulriched is offline   Reply With Quote
Old 04-24-2012   #3
my7707797's Avatar
Rep Power: 20 my7707797 will become famous soon enoughmy7707797 will become famous soon enoughmy7707797 will become famous soon enoughmy7707797 will become famous soon enoughmy7707797 will become famous soon enoughmy7707797 will become famous soon enough
Dude,
Are you asking about DEH-80PRS or DEX-P90RS.
New DEH-P80PRS plastic is selling for 300-350 BNIB, while DRZ9255 is about 3 times at cost.
What about P90 it's very good item. I heard both. It depends from which amps and s[eakers consist system. In example, I heard fully 3-way brax monobrand system running from P90. It was great sound without "soul". Many people and me too keeping thier DRZ9255(HX-D2) because it has amazing incomparable its own sound. So, If you're asked about 80PRS it's another level (I'm sure that you meant this HU). Don't compare it with greatest HU IMHO.
my7707797 is offline   Reply With Quote
Old 04-24-2012   #4
Yes, i was referring to the deh-80PRS, NOT the dex-p90rs.
The new $350 one...
Old 04-24-2012   #5
Rep Power: 22 nigeDLS will become famous soon enoughnigeDLS will become famous soon enoughnigeDLS will become famous soon enoughnigeDLS will become famous soon enoughnigeDLS will become famous soon enoughnigeDLS will become famous soon enough
Bit confused with your first post regarding running a 3" mid @ 250hz?
nigeDLS is offline   Reply With Quote
Old 04-24-2012   #6
WLDock's Avatar
Rep Power: 118 WLDock will become famous soon enoughWLDock will become famous soon enoughWLDock will become famous soon enoughWLDock will become famous soon enoughWLDock will become famous soon enoughWLDock will become famous soon enough
Well, the only way to run a 3-way front off the deck is to have another crossover in the mix.
Example A
Add a 2-way crossover to devide the signal between the midrange and midbass.
Low LPF: 80Hz - Down
Mid HPF: 80Hz
(2-Way Crossover): 400Hz
Mid LPF: 4KHz
High HPF: 4KHz - Up
WLDock is online now   Reply With Quote
Old 04-25-2012   #7
Im referring to the high pass filter setting for the midrange/wideband driver. Running it from 250hz on up...
Old 04-25-2012   #8
Example A
Mid HPF: 80Hz
Mid LPF: 4KHz
High HPF: 4KHz - Up
But the deck handles a 3-way active front already...with no need to add an additional crossover network UNLESS you don't tlike the crossover settings available on the deck. I just wish the MID HPF could extend higher than 250hz, is all.
EDIT: I think you were assuming a subwoofer was in the mix- not the case. This would be for a Midbass + Midrange + Tweeter, OR Midbass + wideband
If I wanted to run a sub, I would simply use the crossover on the sub amp. But it's very likely I wont need to run one...time will tell.
Old 04-25-2012   #9
... Squirrel!!!...
Rep Power: 418 bikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond repute
Default Re: From a DRZ to a DEH-80PRS...will I be dissappointed?
I edited the title.
- Erin
Follow my blog:
http://medleysmusings.com/
Cool site with subwoofer testing:
Data-bass.com
Old 04-25-2012   #10
SkodaTeam's Avatar
Rep Power: 55 SkodaTeam will become famous soon enoughSkodaTeam will become famous soon enoughSkodaTeam will become famous soon enoughSkodaTeam will become famous soon enoughSkodaTeam will become famous soon enoughSkodaTeam will become famous soon enough
Yes, you will be dissappointed.
Pioneer DEXP9/Hiquphon OW4/ Hertz ML1600/ Peerless XXLS 10/ PPI Art Ax606.2
SkodaTeam is offline   Reply With Quote
Old 04-25-2012   #11
Have you used the 80PRS in your system?
Old 04-25-2012   #12
Rep Power: 26 duro78 will become famous soon enoughduro78 will become famous soon enoughduro78 will become famous soon enoughduro78 will become famous soon enoughduro78 will become famous soon enoughduro78 will become famous soon enough
There have been no bad reviews as far as sq goes with the 80. Although its in a lower price range it offers great features in the sq department. Try it out, if you don't like it sell it for a very small loss. Even if the sound isn't up to par the updated features might compensate for it.
Sent from my DROIDX using Tapatalk
Head unit- Pioneer DEH 80prs Dsp- JBL Ms8 Amps -2 ppi p900.4
. Tweeters - Lpg26na Midrange - Tang band W3
. Mid Bass - Rs180 sub - 2 jl 10w6v2
duro78 is offline   Reply With Quote
Old 04-25-2012   #13
WLDock's Avatar
I guess myself and Pioneer did assume a sub was in the mix. 250 Hz on a 3" might be ugly...you may have to use the amps HP crossover if it has one. As far as sound...have yet to hear this deck but the previous PRS decks are good sounding products....but the Clarion and the P99 have the high price for a reason. If you keep that in mind you will not be disappointed...the Pioneer might even suprise you...given its low price.
Sent from my HTC Sensation 4G using Tapatalk 2
Old 04-25-2012   #14
Yup, makes sense. I wouldnt be as worried about the 250hz crossover point if I was running the FR88/FR89 3"ers as they have plenty of xmax to handle that range without worries of over-excursion death. The W3-1364SA is another story though...Oh well, if I burn them up it will give me an excuse to need an upgrade
Old 04-25-2012   #15
Yup, not like I'd be out much. I just ordered the 80PRS and I'll see what it can do shortly
Old 04-28-2012   #16
SkodaTeam's Avatar
yes, they are just diferent classes, night and day diference for me The DRZ is truly one of the best HU.
Old 04-30-2012   #17
Got-Four-Eights's Avatar
Turn it up!
Rep Power: 26 Got-Four-Eights will become famous soon enoughGot-Four-Eights will become famous soon enoughGot-Four-Eights will become famous soon enoughGot-Four-Eights will become famous soon enoughGot-Four-Eights will become famous soon enoughGot-Four-Eights will become famous soon enough
It's funny I found this post.... I had almost considered the same change.. I kinda miss the ability to run USB etc even though the SQ loss through MP3 it was easier then swapping CD's all the time. I ended up getting the 6 disk changer with optical cable.. Now I really love this setup.. I got 2 cartridges so that helps also. Another thing would have been having HD Radio.
Sony CDX-C90/XDP-4000x + Mosconi 6to8
ARC Audio 4150 XXK - Scanspeak Illuminator 1", Morel CDM88
ARC Audio 4150 XXK- Hybrid Audio Tech L6SE
ARC Audio 1500 XXK - 12" Morel Ultimo SC
Team Audionutz South
Got-Four-Eights is offline   Reply With Quote
Old 05-07-2012   #18
Since the 80 is at a lower price than the 800 was I wonder if the components are as good. I switched from the 800 go the DRZ & heard a pretty substantial difference, but the 800 still sounded dn good. The only thing that really erks me about the DRZ is the 18db slope crossovers. Why couldn't they used 24db? The 5 band PEQ is a nice tool if you know how to use it properly (I was intimidated by it). I use the P01 now & love it! I have a trusty backup in the DRZ though.
Old 05-07-2012   #19
... Squirrel!!!...
P99/800prs/80prs all measure pretty much the same.
Sent from my iPhone. Pardon the grammar.
Follow my blog:
Data-bass.com
Old 05-09-2012   #20
Rep Power: 0 texasman1973 will become famous soon enoughtexasman1973 will become famous soon enoughtexasman1973 will become famous soon enoughtexasman1973 will become famous soon enoughtexasman1973 will become famous soon enoughtexasman1973 will become famous soon enough
ok captn. any reviews? what is your initial thoughts of the 80prs. are you happy?
texasman1973 is offline   Reply With Quote
Old 05-25-2012   #21
Turn it up!
I just made the swap.. if you have a DRZ already.. don't make the swap. This unti doesn't sound near as warm as the DRZ.
Old 05-25-2012   #22
t3sn4f2's Avatar
In your biased sighted opinion.
t3sn4f2 is online now   Reply With Quote
Old 05-25-2012   #23
Turn it up!
Biased.. Have you heard and compared the two with the same setup? I think its you guys who are biased based on a bunch of graphs that can't tell you how you will hear it. You must understand.. I WANTED this to be a great deck with great sound but it's simple no competition for the DRZ. I am keeping it anyways.. it is badass because of all the extra functions.. SD, dual USB, ipod control, pandora, and honestly I don't see why ppl think its ugly. It's a good looking deck. I think with enough seat time the tune will come but I am saying overall sound flat for flat... DRZ is just better. It's my opinion and I am entitled to it. If you don't like it that is fine but don't sit there and call me biased.. which really makes zero sense because I plan on selling the DRZ anyway and hope a DSP will makeup the difference.
Old 05-25-2012   #24
t3sn4f2's Avatar
Being biased toward something is not always a conscious choice, and it certainly isn't a criticism.
NwAvGuy: What We Hear
(Don't worry, no graphs there. )
Old 05-25-2012   #25
Turn it up!
Thx, no matter how much I read.. it won't change my opinion of what I just heard. I played 5 songs all the way through before installing the 80prs and then played them on the 80prs. All songs from the dynaudio disk. They sound very different from each other. It's not even a subtle difference. I have managed to get it sounding better.. just need more seat time. Overall I love everything else about the deck...
