Comprehensive Review: " APL1 " - Advanced DSP / EQ / Phase Correction Unit - Page 18 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-03-2017   #426
Raimonds's Avatar
http://*****aplaudio*****/
Acoustic Power Lab APL
chairman
Rep Power: 39 Raimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enough
Originally Posted by oliverlim View Post
The Aux input unfortunately runs seperately a the high level inputs. I need the rears of the high level input as that is connected to my rear parking sensors sound. So i I have music playing on the aux, I will not hear my parking sensors sound. Thats why i am checking if it is possible to convert rca back to speaker level and to do so at a good enough quality level.
Can you explain more about the android device? i do not see it on your web site.
I assume I need to purchase the apl workshop as well to measure the car response? Or does it come with the apl1?
And what about Optical SPDIF-Toslink input?
You should use an Android device of your choice - a phone, a mini PC, a head unit - to play your music (it probably will replace your idrive). Than it is possible to run the APL`s equalizer on such device as an app. Workshop software and APL1 unit are products that are creating a set but they are being sold separately. You should have Workshop to create EQ files for app on Android device.
Old 01-03-2017   #427
Rep Power: 99 LumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enoughLumbermanSVO will become famous soon enough
Originally Posted by Raimonds View Post
by use of parameter "EQ zero level" in Workshop software. If you set it to -15 for example, you will have 15 dB attenuation in fir filter
Somehow I didn't see that setting, usefull!
1986 Bronco Build
2010 Miata Build
Old 01-03-2017   #428
I took two measurements with TDA today, this is with the APL1 set to flat:
And with the tune I posted last night:
Some parts look better before, some look better after.
1986 Bronco Build
2010 Miata Build
Old 01-03-2017   #429
Raimonds's Avatar
chairman
Thank you for nice examples!
They are far field pictures when ambient sound field is dominating over direct sound. It is showing the real complexity of a car environment.
It can not be improved by any electronic (correction) means.
This picture is changing dramatically from one to another mic position point.
It is possible to find a point with better direct - ambient sound ratio to use it to set the timing.
We can improve this picture only by right loudspeaker`s placement.
It is possible to get such picture even in a car:
You can see the serious timing error in LF caused by a blind tuning by use of a ruler ...
Old 01-04-2017   #430
Raimonds's Avatar
chairman
And following previous question.
Such TDA image may be in case when a wide band loudspeaker is used for all the way to 20 kHz. Such loudspeaker has very uneven directivity and strong side lobes. That lobes are are creating reflections that are stronger then direct sound.
Old 01-04-2017   #431
It would be interesting to do a tune with Workshop with the top down and compare it with the top up tune. Even more interesting to see the TDA charts between the two. Unfortunately, I just shipped the laptop I do my testing with off to a show, and I leave to go work that show on Sunday. I have three shows in a row and won't be home to do any more tuning and testing until March.
However, in March I'll have all my new speakers ready to install.
1986 Bronco Build
2010 Miata Build
Old 01-04-2017   #432
Rep Power: 133 felix509 will become famous soon enoughfelix509 will become famous soon enoughfelix509 will become famous soon enoughfelix509 will become famous soon enoughfelix509 will become famous soon enoughfelix509 will become famous soon enough
I am awaiting more information on this as well...
So there is a stand alone android app that will accept the APL workshop file??
felix509 is offline   Reply With Quote Quick reply to this message
Old 01-04-2017   #433
Raimonds's Avatar
chairman
Yes, the app emulates APL1 unit or APL EP1 VST plugin.
Old 01-06-2017   #434
Rep Power: 47 Alextaastrup will become famous soon enoughAlextaastrup will become famous soon enoughAlextaastrup will become famous soon enoughAlextaastrup will become famous soon enoughAlextaastrup will become famous soon enoughAlextaastrup will become famous soon enoughAlextaastrup will become famous soon enough
What Raimonds suggests is an app called Viper4android, which comprises an convolver capable to work with the 7files made from measurements carried out by the Workshop.
So you do not need apl1 box in a car, if you have android based head unit or smartphone as a source.
Using smartphone, it is possible to listen music from in-built speaker, ear-phone or another device connected by bluetooth or usb cable. Starting from Lollipop, all android versions support USB audio out. In this case you can just use the latest version of Poweramp or USB recorder Pro from the Google Play.
It is possible to get correction files to every acoustic system you own. Really smart
Sendt fra min GT-I9505 med Tapatalk
Old 01-06-2017   #435
Thanks for the reply...
I have been working on getting BruteFIR to work with my gear, will APL Workshop files work with BruteFIR on a linux system? SO far I have only seen PCM or WAV files used for the Brutefir filters.
I am still reading and learning BruteFIR, it is alot to learn at once...
If I am able to use one less piece of gear(APL1) and use the BruteFIR as convolver instead, that would be amazing..
Old 01-06-2017   #436
Raimonds's Avatar
chairman
Yes, it is possible to convert APL`s fir files to any third party fir filter file format on demand.
Old 01-28-2017   #437
Raimonds's Avatar
chairman
Dear Friends,
Some announcement.
Acoustic Power Lab (APL) has become SynAudCon sponsor! It is well-known training company among audio engineers and sound system professionals. SynAudCon offers practical and relevant education through their in-person seminars, online training, memberís forum, and their online educational library.
Celebrating this event we want to share our joy with our clients and we have fantastic gifts:
SynAudCom membership opens the door to a wealth of audio information and provides unlimited opportunity for connecting and collaborating with thousands of industry professionals. It also includes: memberís forum; over 500 technical articles on audio and acoustics; intensive field studies; RIR exchange; member directory.
And the most valuable present is a chance to attend training course at SynAudCon. All the detailed information will be given individually.
(Simply make an order for any of APL products and get your present! )
Please contact APL to get your free SynAudCom membership or to attend training course at SynAudCon. (Prospective customers will have preference.)
Notice: the present amount is limited!
Also, to support an education and in conjunction with this event, APL is offering APL TDA softwareís individual license for studentís license price for one month.
Old 02-17-2017   #438
Rep Power: 82 oscardillo will become famous soon enoughoscardillo will become famous soon enoughoscardillo will become famous soon enoughoscardillo will become famous soon enoughoscardillo will become famous soon enoughoscardillo will become famous soon enough
Is it possible to mount it in a system with passive filters? In this case the "apl1" will mount before the passive filter ?.
Finally they did not upload any videos
Greetings.
oscardillo is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #439
Rep Power: 65 Elgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enough
Greetings.
Sure you can, itís the typical use with regular speakers.
Although in car itís maybe not the first thing to do, if your passive crossover is already great why not, it will work.
But you might gain more by switching first to full active and EQ.
Horny Froggy...
Old 02-17-2017   #440
I have been using this solution with 3way front in almost two years. It was necessary as apl1 is limited to only two channels. Works great. Will keep this passive setup for a couple of years more.
Sendt fra min T1-A21L med Tapatalk
Old 02-21-2017   #441
Greetings.
I have mine between my iPhone and head unit, works great!
1986 Bronco Build
2010 Miata Build
Old 02-21-2017   #442
Rep Power: 49 Jscoyne2 will become famous soon enoughJscoyne2 will become famous soon enoughJscoyne2 will become famous soon enoughJscoyne2 will become famous soon enoughJscoyne2 will become famous soon enoughJscoyne2 will become famous soon enoughJscoyne2 will become famous soon enough
What app?
Old 02-21-2017   #443
Rep Power: 8 oliverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enough
I am trying out the software without the actual unit. So far I have been converting my songs using the MP1 target. MP1 seems to emphasize bass more rather then strings which is my preference. So I am hoping for another target to shoot for. I believe the 2-3k dip does seem to make vocals feel a little lean and less warm. The lower bass also sometimes seem to sound a little heavy. As such, I was wondering if anyone else has decided on other target levels and why?
Also does going for say 300-400 points per measurement improve on the accuracy instead of the typical 150-200 for each side measurement painting? I am facing a issue where I seem to have a big dip at 1k and 5-7k region on both sides. But if I do a average RTA with pink noise, there is no big dip at that region around my head region. Changing my crossovers and slope which are nowhere near that area does not seem to impact or change that dip which APL workshop is saying exist. At the moment, I am measuring sitting in the driver position and painting starting from the wind screen from up to down and moving slowly back to just before the back of the front seats. No lower then the door windows and carefully avoiding the playing speakers by around 15-20cm.
oliverlim is offline   Reply With Quote Quick reply to this message
Old 02-21-2017   #444
It's really car/setup/driving/loudness dependant, and of course personal taste. Mp1 is perfect for my daily drive which is low speed. When I prefer flatter for listening session engine off, and more bass when driving faster.
I have an mp1 version with the dip "filled", but it can cause a bit of ear fatigue.
Well after multiple targets I usually go back to the regular mp1.
200 is good enough but of course more won't hurt. You should see if it adds anything on the curve. Less can also work fine, it's already kind of long to do.
For the painting method, same here it's car dependent, but I good results trying to catch the maximum volume. So lower than the door glass, from seat base to the roof, windshield to seats and side glass to side glass (real close). Except few problematic areas like the very corner of my windshield (accute angle with my prominent dash).
For your dips, how big are they? And are they pre or post APL?
Horny Froggy...
Old 02-21-2017   #445
Thanks for your reply. I will listen to MP1 a little longer to see how I like it. For Home audio, I do like the 2-3k dip.
My 1k and 5-k dips are in the region of 10-15DB. They are pre APL. As I do not have the hardware, I am unable to measure post APL to see if APL filters did fix the problem. It does seem to indicate that it can bring up the 5-7k dip almost to the target level and half the 1k dip. Its just very strange that my crossovers are no where near there and does not seem to impact the dip even when I am changing the slope or type. It also happens on both sides almost equally.
I be redoing some new measurements with another TA to see if I can get it better which should not be difficult I hope.
Old 02-22-2017   #446
I think I found out why the measurement result looks so poor! I have been doing the paint measurement from the driver seat. I attached 2 files and you will know immediately which was "poor" result was from the driver seat and which was from the passenger seat. Both are from the Left speakers only.
Which brings me to the question, why does it look so different? Please ignore the target curve which I had for the driver seat measurement but did not use for the passenger seat measurement.
Old 02-22-2017   #447
You could upload the FIR filters and measure one more time in order to see how apl worked it out. This re-check is also important for further eq if necessary. You will know what to do and where.
Old 02-22-2017   #448
Raimonds's Avatar
chairman
You have very serious installation/tuning/setup error in first one.
Please take the TDA software and check all ways/bands one by one carefully with very high patience.
Old 02-22-2017   #449
That's the Thing. They are the exact same tune! Just one measured from the passenger seat and the other from the driver seat. Somehow the position of when I am Seating makes such a big difference?
Old 02-22-2017   #450
Rep Power: 154 sqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to beholdsqnut is a splendid one to behold
Are your ears at all those places while you're in the car? Just measure at your ears, that all that counts and done.
