AudioFrog GB40 4" Midrange (Objective Review) - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 02-26-2015   #1
Bikinpunk
Rep Power: 25977 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
Default AudioFrog GB40 4" Midrange (Objective Review)
Review can be found here:
http://medleysmusings.com/audiofrog-gb40-4-midrange/
PS: If you would like to help me keep up funds for testing, there’s a little ‘contribute’ button that goes through Paypal all the way at the bottom of every page. Any little bit helps.
Follow my blog:
Time Delay Calculator:
Old 02-26-2015   #2
Classifieds Access
Huckleberry Sound's Avatar
Rep Power: 112 Huckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enoughHuckleberry Sound will become famous soon enough
Default Re: AudioFrog GB40 4" Midrange (Objective Review)
More reading.
Huckleberry Sound
Huckleberry Sound is offline   Reply With Quote Quick reply to this message
Old 02-26-2015   #3
Rep Power: 60 Elgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enough
And gb40!
Very cool Thx
Really perfect for 30 degree.
I'm even more interested in seeing the gb25 now.
to check THD around 200Hz (I cross it here at 24db).
Old 02-27-2015   #4
Chief of Information
Audiofrog Inc.
President
Rep Power: 550 Andy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond repute
Thanks Erin!
A few notes about these drivers and also about crossover recommendations:
1. All of these things have been designed to work together in systems. The sensitivity of the drivers has been scaled using all sorts of tools so that when they are used with the same amp and a passive network, they all play at about the same level. The tweeter is design with HIGHER SENSITIVITY to provide a wide range of adjustment. The PRIMARY use of the 4" is in a 3-way system with the 6" and either of the tweeters.
2. The secondary use of the 4" is in the doors of a BMW. The depth has been designed to fit that space.
3. These are NOT "widebanders". Rather than compromising sensitivity and Power handling to extend the bass and the high frequencies in the on axis response, we have opted for higher Power handling and higher efficiency that you'll find with "widebanders". These are midrange drivers. The design goal was fllat response and low distortion in the passband. Reducing the resonance requires a looser suspension or a heavier moving mass. That reduces sensitivity. I do recommend crossing above resonance, but remember the crossover frequency is the -3dB point or the -6dB point. -3dB is half power and -6dB is 1/4 power. Run the distortion test signal through a 110Hz 4th order filter and check out the distortion again. I think you'll find that under those circumstances, that crossover is still OK. In a 3-way, there's no reason to cross that low.
4. All of these drivers include a cooper cap on the polepiece to reduce inductance and the distortion that's caused by changing inductance as the coil moves in and out over the polepiece. The GB60 includes an additional shorting ring because that Speaker will always be used close to it's resonance and will often be using much of it's excursion potential.
5. The GB40 and the GB25 also include a bucking magnet on top of the copper ring. That bucking magnet focuses the energy in the gap and provides higher sensitivity.
6. The GB 40 is designed for use in a door or dash (IB). For A-pillars, we have the GB25. It's designed so that it can be used in a box as small as 2" x 2" x 2" and still play pretty flat to about 200Hz. There are no other midrange drivers that I know of designed specifically for this application. Most of the mids I see people putting in A-Pillars are designed for IB and often produce a high-Q response in the A-Pillar application.
Old 02-27-2015   #5
Audiofrog Inc.
President
Oh, one more thing--the Power handling numbers are absolutely real. 100 Watts RMS and 300 Peak. The designs are tested using a shaped noise signal that has an average output of 100 Watts and peaks of 300. We hang the speakers from a chain and drive them with this signal for 100 hours.
They're also tested to withstand heat, humidity, thermal shock, exposure to ultraviolet light and vibration in a routine designed to simulate 50,000 miles of operation in a moving vehicle. That's VERY different than the kind of reliability testing required to make a driver that will withstand the rigors of your living room.
Old 02-27-2015   #6
Rep Power: 104 nstaln will become famous soon enoughnstaln will become famous soon enoughnstaln will become famous soon enoughnstaln will become famous soon enoughnstaln will become famous soon enoughnstaln will become famous soon enough
-Andy-
I recently purchased a set of GB10's, GB25's and GB2510c's...My plans for the GB25's are dash mounted (facing the cabin not the windshield) IB....what crossover point would you recommend for the high-pass. Power will be 100rms.
I could create a cup or enclosure if needed.
nstaln is offline   Reply With Quote Quick reply to this message
Old 02-27-2015   #7
Audiofrog Inc.
President
You don't need an enclosure...the high pass filter will accomplish nearly the same thing. Choose that crossover based on a measured response of that Speaker and whatever you'll use for a midbass. Anywhere between 200Hz and 1kHz is fine.
Old 02-27-2015   #8
Rep Power: 122 kaigoss69 will become famous soon enoughkaigoss69 will become famous soon enoughkaigoss69 will become famous soon enoughkaigoss69 will become famous soon enoughkaigoss69 will become famous soon enoughkaigoss69 will become famous soon enoughkaigoss69 will become famous soon enough
Andy, thanks for clarifying. When using in a 3-way where you get tremendous benefit from the door mid being able to play 110Hz (as in the BMW), are you saying the recommended crossover slope is 4th order, and not 2nd order as it says on your website?
kaigoss69 is offline   Reply With Quote Quick reply to this message
Old 02-27-2015   #9
Bikinpunk
This is a good point. While the suggestions I make and often glean from others' testing is based on the THD of a driver tested 'wide open', it's worth noting a high-pass filter alters the distortion results. I've actually done testing on this ... and for the life of me I can't find where I posted it. Not knowing how people will use a drive unit, I tend to err on the side of caution so my suggestions may seem a bit high to some but in general I think they are pretty reasonable.
Follow my blog:
Old 02-27-2015   #10
rton20s's Avatar
Rep Power: 309 rton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond repute
Thanks for this one was well Erin. I'm hoping to get to hear some of the AF stuff for myself soon.
Pioneer DEH-80PRS | Mosconi 6to8 V8 | Arc KS900.6 | Arc KS600.2 | Illusion TL 25 BN | Illusion C5 | Arc Black 12
2015 MECA SQL Street California State Champion
Old 02-27-2015   #11
Audiofrog Inc.
President
I always recommend 4th order crossovers. The recommendation in the manual and on the box is "greater than or equal to 12dB" so second is a minimum.
Old 02-27-2015   #12
quietfly's Avatar
Rep Power: 89 quietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enoughquietfly will become famous soon enough
these also make me drool....
Old 02-28-2015   #13
Rep Power: 0 JerryK73 will become famous soon enoughJerryK73 will become famous soon enoughJerryK73 will become famous soon enoughJerryK73 will become famous soon enoughJerryK73 will become famous soon enoughJerryK73 will become famous soon enough
What is the mounting depth of the 4"? I know you stated that it was designed to be installed in the doors of a BMW but there are certain model BMW's that require a very shallow mounting depth (such as the E92 or the F25's).
JerryK73 is offline   Reply With Quote Quick reply to this message
Old 02-28-2015   #14
Audiofrog Inc.
President
41mm
Old 02-28-2015   #15
Diyma Ninja
Rep Power: 249 thehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud of
I like the fact you took efficiency over low end extension.
Old 02-28-2015   #16
agreed.
I'd like to know more about a secondary (bucking) magnet increasing efficiency, as in how and where it is placed, and whether or not it is proprietary technology or licensed from somewhere.
Old 02-28-2015   #17
t3sn4f2's Avatar
Rep Power: 221 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
Originally Posted by cajunner View Post
agreed.
A little info.
Scan-Speak
t3sn4f2 is online now   Reply With Quote Quick reply to this message
Old 02-28-2015   #18
Audiofrog Inc.
President
Here's a better explanation of how they work...so I don't have to type. LOL
Request Rejected
Old 03-04-2015   #19
Rep Power: 0 Picaro will become famous soon enoughPicaro will become famous soon enoughPicaro will become famous soon enoughPicaro will become famous soon enoughPicaro will become famous soon enoughPicaro will become famous soon enough
Great job of the data compilation. Really love the Build quality of this speaker, especially the Speaker connectors and also shallow depth design. Gives me some hope again of possibly using a 4" mid that I can cross over low enough for my possible application, and not have depth mounting issues, though I would probably have to trim the overall diameter a bit, ouch, since I have an oval opening for one, not round. I'll definitely be researching these more when the time comes. Looks like a very promising company, who I had not been aware of previously.
Picaro is offline   Reply With Quote Quick reply to this message
Old 04-17-2015   #20
Classifieds Access
<(O0=[][]=0O)>
Rep Power: 51 tjswarbrick will become famous soon enoughtjswarbrick will become famous soon enoughtjswarbrick will become famous soon enoughtjswarbrick will become famous soon enoughtjswarbrick will become famous soon enoughtjswarbrick will become famous soon enough
Looks good.
Thanks for doing that, Erin.
Any experience with Morel's Hybrid MW4 to see how that competes in this space?
E88 CiC mObridge DA3 ARC XDi v2 1200.6 & 600.4 Morel MT-350 a/d/s 344is Gladen HG 201 Illusion c10
tjswarbrick is offline   Reply With Quote Quick reply to this message
Old 05-17-2015   #21
Rep Power: 145 lv_v will become famous soon enoughlv_v will become famous soon enoughlv_v will become famous soon enoughlv_v will become famous soon enoughlv_v will become famous soon enoughlv_v will become famous soon enough
Are there any real-world reviews on these? How do they stack up against other offerings? These or the GB25's look interesting for my a-pillar install as part of a 3-way with an 8" on bottom.
lv_v is offline   Reply With Quote Quick reply to this message
Old 03-06-2016   #22
Fyalinks's Avatar
Rep Power: 15 Fyalinks will become famous soon enoughFyalinks will become famous soon enoughFyalinks will become famous soon enoughFyalinks will become famous soon enoughFyalinks will become famous soon enoughFyalinks will become famous soon enough
Thanks Erin!
Andy, since you have created drivers for specific applications like mentioned above about your 4" drivers for BMWs, do you have any plans on creating an 8" woofer for the growing number of manufacturers who have that size driver as factory equipment, such as BMW, Infinity, Chevy, Porsche, and maybe other?
I know the 8" driver market is a small one but its growing, and I would rather having a matching driver that blends with the rest of the system rather than be relegated to relatively expensive Morel and Dynaudo 8" drivers, or pro audio drivers that aren't designed to thrive well (untreated paper cones) in a Car environment.
My cayenne comes with 6.5" or 8" drivers in a 3 way system and I've heard both, the eights sound a lot fuller and more effortless in the mid-bass region is such a big vehicle. I know your speakers may be way better that the stock Porsche 6.5" and even the factory upgrade Bose but something just doesn't feel right about downgrading the size in my system. I love the effortless sound created by bigger woofers, especially when there is already a 4" to handle all that midrange goodness.
Well enough rambling, I just tired of seeing so many new speakers coming out and the 8" market being neglected. Yes, its a small market, but it is growing, and deserves more attention. Besides, a lot of folks are alway either doubling up on 6.5" drivers or upgrading to 8s or 10s to get the desired impact from their front stage.
Thats it, I'm done, just some food for thought, this probably shouldn't even be in this thread lol.
Fyalinks is offline   Reply With Quote Quick reply to this message
Old 03-06-2016   #23
alachua's Avatar
Rep Power: 115 alachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enoughalachua will become famous soon enough
Andy weighed in on the need for an 8" GB series driver in another thread here.
Sorry guys. Traveling in China and this website isn't easily available here because it uses some Google sign in thing. No Google in China.
The GS and GB are completely different drivers but they both sound great. GB has a copper cap on top of the pole piece to dramatically reduce distortion, a really stiff paper cone and milled flat single layer coils and neodymium magnets. The GB60 is a much better midbass driver than most 8". It had a 2" coil and 9mm of linear one way excursion. No need for an 8".
I added the emphasis. It seems that people on the site lust for a shallow 8" driver, begging any manufacturer who stops by to produce one. The fact that nobody has leads me to believe that either it is technically difficult to do so at a price point people will pay for (see: Stereo Integrity 'I can sell as many speakers as I can Build as long as I make no money on them'), the market is small enough that the first mover (Illusion Audio) has captured enough of the potential buyers that it makes no sense to enter, or while everyone on the site says they want one, nobody will actually buy them when they are available (see: Soundstream Human Reins amps 'we Build what people begged us for and were left with a warehouse of unmovable stock')
alachua is offline   Reply With Quote Quick reply to this message
Old 03-06-2016   #24
Rep Power: 24 Shapin will become famous soon enoughShapin will become famous soon enoughShapin will become famous soon enoughShapin will become famous soon enoughShapin will become famous soon enoughShapin will become famous soon enough
@eddieg You really need to convince someone to import this products, i have to hear it.
Shapin is offline   Reply With Quote Quick reply to this message
Old 03-06-2016   #25
Fyalinks's Avatar
@ alachua - Thanks for the link to the 8" inquiry. No further comment.
