SUNDOWN audio SD3 shallow mount -high excursion -small enclosure- 10"SUBWOOFER Review - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-03-2015   #1
Rep Power: 138 AAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enoughAAAAAAA will become famous soon enough
Default SUNDOWN audio SD3 shallow mount -high excursion -small enclosure- 10"SUBWOOFER Review
When Jacob first posted about his new project- the SD3 line of subs that were going to be for small sealed and aimed mostly at the SQ crowd- my interest was piqued and I kept a close eye on the thread. When I saw the box requirements I knew I had to give this a try once budget permitted and since the price is pretty low it didn’t take too long. Since the last sundown subs I had certainly delivered this was at the top of my list.
The sd3 line is targeted pretty much to guys like me.
-values highly cargo space
-values highly sound quality
-values highly value
I was going through the thread again and here were in Jacobs(sundown audio owner) design goals in his own words
Originally Posted by sundownz View Post
IMO they are going to be pretty incredible... SQ fans have been going nuts over the SD-2 8s and with the SD-3 the 10s and 12s will get a huge SQ boost.
Under-hung, relatively shallow, and relatively inexpensive
Either way I won't be satisfied until the specs nail it for small sealed
So were the goals met? Read on
Packaging is usual top notch doubled boxed secured with Styrofoam. Taking the sub out reveals this unusual beast with no vent in the back and inverted surround sound. Both tricks to minimize mounting depth requirements. The sub at first glance isn’t that shallow, there are clearly much shallower options but IMO and IME these subs are compromised in terms of xmax, output and of course box volume as they usually don’t ask for a smaller box. The inverted surround takes off about a half inch of typical “big” surround subs and no rear vent means you can mount this thing and have it sit at the bottom of the box. No vent means a typical depth saving of 1inch or more (usually the diameter of the vent itself is recommended as the minimum distance behind a sub). Keep this in mind as you take it out as at first glance it isn’t that shallow. The only that matters though is will it fit? If it does then there is no need for shallower.
“Relatively shallow”. Indeed building anything is always about choosing compromises and it seems that here there was no desire to compromise on amount of output and quality for its sealed purpose. This explains its depth and why we get over 14mm of xmax one way. This is certainly nothing to scoff at in any design, especially in a shallow design. It will of course move more at the expense of added distortion (like every sub). Make no mistake, this thing moves a lot.
I didn’t measure the TS parameters this time myself unfortunately, the kids and I were excited to put this thing in so in it went pretty much as soon as I had some spare time.
SD3 10" specs
RE : 7.00 ohms
FS : 25.5 Hz
VAS : 39.3 L
QES : 0.50
QMS : 3.53
QTS : 0.43
LE : 7.49 mH
BL : 18.57 NA
MMS : 152 g
CMS : 260 uM/N
SENS : 83.1 dB
Xmax : 14.5mm one-way by 70% BL
RMS : 500watts
Enclosure : 0.45 cf
Shorting ring for lower distortion
mounting depth 4.48"
Inverted surround that saves 1inch of front mounting.
Solid heavy basket along with typical quality found with SD products, my first impression was that it is substantial. Woven leads into the spider, pushing the cone in and out is smooth. It looks good from every angle. Anyone with experience with sundown subs will get what they are used to.
The SD10 in particular requires a minimum of about 0.45 cubic feet. I have about that much so I made sure to stuff it full of polyfill. It ended up being a perfect replacement from the Dayton titanic that was there before.
The logo, unfortunately, doesn’t line up perfectly since I didn’t want to make new holes.
So how does it sound? I have it in its smallest box config hooked up to a JBL MSa-5001 @2ohms rated for 500rms (but we know it’s closer to 800 thanks to andyW).
I have been through a bunch of subs in a variety of configs be it IB ported, sealed. I have been playing a variety of music in the past week and a half. It’s broken in a bit I believe and it delivers. Often with subs they can be designed to be peaky at certain frequencies or recommended to be in smaller boxes that are deemed “acceptable” yet far from optimal, at least in terms of sound quality. But am I ever thrilled with the SD3. Its shallow, it’s beefy and it is in a tiny box. So tiny. Yet there I am listening to my music and it sounds amazing. Often I have heard and had subs that translate pretty much everything into various loudness of BURRR BuRRRRR BUUUURRRRRRR. Not here, not the SD3.
The beauty is that it adds depth perfectly to kick drums and bass, songs don’t all sound the same, the sub can be front and center if you put it loud enough but it is so easy to blend in. There is a thread about how some subs are easier to integrate then others. I can’t really speak to that, but this was just dropped in and perfect from the get go. I use MS8 but the sub runs off of the fronts and didn’t get any ms8 magic optimisation. So this is what Jacob meant when he is targeting SQ guys, and it leaves nothing to be desired. This adds incredible punch and has that stiff kick you feel deep within your body, something the Dayton didn’t deliver. Often we get excited during the first listen. But I have had almost 2 weeks of listening over an hour at a time each work day. I have gone through most of my top songs and I love every moment of it. There are 2 major things I need to highlight.
No song has been out of balance, often I have come across songs that have peaks and luls, parts of the song that either sticks out way to much or is the opposite, barely audible. Two songs I like to use that have been notorious for this would be up and down from venga boys where at the very beginning I like to be able to feel the one note that keeps playing and then not be overwhelmed by bass afterword. Here the SD3 delivers perfectly.
Next one is Jarule (Yes I know everyone loves jarule right?) titled between me and you. The chorus has base that varies from higher to lower and I have often had configurations where one part may be to loud or to low. But the SD3 delivers it just as I would expect, just right and satisfying.
Some songs have some really quick kick drum that can easily sound muddled or no longer remains distinct kicks and just sounds like a muddled mess. My favorite for this is DRAGON FORCE. Specifically the title “reasons to live”. Right at the beginning it starts off very intense and super-fast. Everything remains distinct yet punchy and precise.
The SD3 is the sub I had been waiting for. I love super punchy, I always say it for both midbase or subs, I like the midbase or punch to be a bit exaggerated and this is exactly it all while adding depth and letting the song take center stage and precedence, only adding to the experience and not taking over. It’s wonderful. No regrets and like many other components I have been going through all the time this is the final one that won’t get swapped out, it’s staying.
Secondary thoughts
We all know that sealed is easier to design and to implement well but that it is also compromised in terms of overall output. The SD3 does make my hole vehicle shake with jut the one and I can make it to loud for my personal taste. But this wouldn’t be the ideal sub for a bass head…at least not just one. Some reports of people using it ported are intriguing and I might try it in the future if I can figure out a more efficient way of storing all my amps and sub.
The sub delivers on the highway with all windows open, I little twist of my remote bass know and it brings it inline to a level of satisfaction that it certainly hard to achieve in my santa fe.
The sub has an MSRP of only 199 with free shipping for most of you US folk. It’s a hell of a value IMO and for anyone like me that values storage and utmost sound quality with the fun to boom factor then this might just be your final destination. Highly recommended.
Did Jacob meet his design goals? I would say yes. Absolutely.
This is where my amps and the tiny enclosure containing the Sd3 reside.
In conclusion I didn’t think I would be able to get a high excursion, small enclosure sub that is so inexpensive and delivers in terms of detail, punchiness, depth and balance like this. Thumbs of to sundown to always be able to deliver such products, I’d like to say it’s because of his passion but like AndyW has said ,passion can only get you so far, you need skill and knowledge, testing and hard work to get quality products out and this is certainly the case here.
I hope you guys enjoyed it.
SD-3 Series
Old 08-03-2015   #2
Babs's Avatar
Scott
Rep Power: 174 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
Default Re: SUNDOWN audio SD3 shallow mount -high excursion -small enclosure- 10"SUBWOOFER Re
Great write-up. I've been enjoying the heck out of my SD-3 10" in probably a too large box (Audio Integrations Civic corner fiberglass box) of somewhere around .85cf sealed. It's been stellar, I think.
2008 Civic Si Sedan - DEX-P99RS, Helix DSP Pro-2, JL Audio XD1000/5v2 (2), Audiofrog GB10 & GB25, Stereo Integrity TM65, Acoustic Elegance SBP12 (2)
Build Log
Babs is online now   Reply With Quote Quick reply to this message
Old 08-03-2015   #3
sirbOOm's Avatar
Rep Power: 85 sirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura aboutsirbOOm has a spectacular aura about
Nice write up. I'm still waiting on those 8"s.
sirbOOm is offline   Reply With Quote Quick reply to this message
Old 08-03-2015   #4
Approved Vendor
Sundownz
Rep Power: 207 sundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond repute
Thanks for the in-depth review !
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- I DO NOT USE PMs -- Email me at sundownz@sundownaudio.com
sundownz is offline   Reply With Quote Quick reply to this message
Old 08-05-2015   #5
A bigger box is easy to fill in. I guess you would have less Power with the bigger enclosure but I would expect it to play a bit lower...but maybe not as balanced and punchy. Not sure.
Old 08-05-2015   #6
Babs's Avatar
Scott
I've thought of something easy to fill in, such as tightly rolled up towels etc just to see what difference that might make. Should give it a go, but other goodies taking preference.. One item being placing in and test playing some new coax's (you read that right.. sure enough coaxials) as a potential for top portion of the front-stage.
But trying out something for taking up some volume in the corners of the box I think would be a worthy test. "Tight" has been a term folks who've heard it have described the sub though so far. However, I'm sure I can eek out more SQ though that might be at the cost of lower extension.
What's interesting is currently I'm doing a blasphemous thing by having my low-pass at 12db vs 24db slope right at 80hz. My thinking was if phased in right with my mids, the shallower slope would help with a bit of a swoop in my curve in the lower mids where the SB17's weren't getting it done down near 80hz. I suspect though with the amp swap and bridged channels on the PDX though that has filled in a bit on it's own.
So at that 12db slope even, I've noticed this sub seems to blend in nicely (after phase aligning).
I can also confirm this if anyone wondered.. A PDX V9 sub channel will push an SD-3 10" with ease and very good control. I think that little upgrade "tightened" the sub up quite a bit actually.
Build Log
Old 08-05-2015   #7
Rep Power: 57 crackinhedz will become famous soon enoughcrackinhedz will become famous soon enoughcrackinhedz will become famous soon enoughcrackinhedz will become famous soon enoughcrackinhedz will become famous soon enoughcrackinhedz will become famous soon enoughcrackinhedz will become famous soon enough
I have my 12"s in .8 ft^3 each with 700rms each, and they handle it just fine. No bottoming out, dont even notice any stress...now whether im getting 700rms in real world application is unlikely...but yeah they handle whatever im giving it just fine.
These subs blend in quite well too. They get low when needed and have great output...though I will say my single ported 15" had a smidge more output. (apple to orange comparison though)
My goal was to sound great, and return my cargo space for family travels.
Mission accomplished.
crackinhedz is online now   Reply With Quote Quick reply to this message
Old 08-10-2015   #8
Rep Power: 98 kkreit01 will become famous soon enoughkkreit01 will become famous soon enoughkkreit01 will become famous soon enoughkkreit01 will become famous soon enoughkkreit01 will become famous soon enoughkkreit01 will become famous soon enough
Thanks for the review. I'm planning a shallow sub in the exact same location in my Edge. The SD3 is my first choice, but have to plan, build, measure box first.
www.SparksAI.com
Great Brands, Good Prices, Excellent Customer Service
DIYMA members receive 10% off their entire order with Code: DIYMA10
kkreit01 is offline   Reply With Quote Quick reply to this message
Old 08-10-2015   #9
bmxscion's Avatar
Rep Power: 78 bmxscion will become famous soon enoughbmxscion will become famous soon enoughbmxscion will become famous soon enoughbmxscion will become famous soon enoughbmxscion will become famous soon enoughbmxscion will become famous soon enough
Just for reference....SD-2 12" next to SD-3 12".
2005 Scion xB: RF 551X 4ch (X2), RF 501bd, MS-8, HAT Imagine I61-2, HAT L3, Knu 1/0 CCA on Big 3, Mechman 220A alt. w/ adj. voltage boost, XS D3400, Custom made RCA's, Knu KL3 14AWG speaker wire, Pioneer DEH-P8400BH, Sundown SD-3 prototype D4, 12" sub
bmxscion is offline   Reply With Quote Quick reply to this message
Old 08-10-2015   #10
sirbOOm's Avatar
Why can't I see any photos? Just a grey circle with a - in the middle. Did I not pay the fee?
2016 Ford Mustang GT Performance Package
Steeda Ultralite/Pro-Action Suspension | Solo Performance Exhaust
Old 08-11-2015   #11
Who's pictures aren't you seeing? Mine are hosted on Google so no fees
Old 08-11-2015   #12
Salami's Avatar
Rep Power: 124 Salami is on a distinguished roadSalami is on a distinguished roadSalami is on a distinguished roadSalami is on a distinguished roadSalami is on a distinguished road
We are not seeing any pictures in your first post.
Salami is offline   Reply With Quote Quick reply to this message
Old 08-11-2015   #13
dallasneon's Avatar
Platinum Mobile Audio
Quality Control
Rep Power: 145 dallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enough
Can't see pics either.
dallasneon is offline   Reply With Quote Quick reply to this message
Old 08-11-2015   #14
I asked a mod to modify my initial post... in the mean time here is a link to the pics. Thanks guys!
Old 10-01-2015   #15
Kellyo77's Avatar
Rep Power: 93 Kellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enough
What an awesome write up! Well done! I want to order one just from reading that. I've been using the same 10w3v2 for the past 10 years I think now. Want to try something different. And want it to fit behind the back seat in my f250. Thanks again Sir!
Keep Calm and Chive On!
Kellyo77 is offline   Reply With Quote Quick reply to this message
Old 10-02-2015   #16
Thank you kellyo77, very kind words.
Old 10-02-2015   #17
Rep Power: 34 turgin will become famous soon enoughturgin will become famous soon enoughturgin will become famous soon enoughturgin will become famous soon enoughturgin will become famous soon enoughturgin will become famous soon enough
Fantastic write up on a fantastic subwoofer.
FWIW I have two of them behind the seat in my 2008 crew cab F250. I don't have the Power sliding rear window so that helps with the fit.
turgin is offline   Reply With Quote Quick reply to this message
Old 10-04-2015   #18
Classifieds Access
Bolding220's Avatar
Rep Power: 114 Bolding220 will become famous soon enoughBolding220 will become famous soon enoughBolding220 will become famous soon enoughBolding220 will become famous soon enoughBolding220 will become famous soon enoughBolding220 will become famous soon enough
Looking at these now that I cannot find 1more ID8 D2 V3
Bolding220 is offline   Reply With Quote Quick reply to this message
Old 10-05-2015   #19
Thanks turgin!
I do find a lot of the shallow offerings go overkill on the shallowness, so much so they compromise to much on other aspects of the sub. The SD3 is really just right.
Old 10-23-2015   #20
ousooner2's Avatar
Rep Power: 86 ousooner2 will become famous soon enoughousooner2 will become famous soon enoughousooner2 will become famous soon enoughousooner2 will become famous soon enoughousooner2 will become famous soon enoughousooner2 will become famous soon enough
How would these work in IB. Thinking of pulling the stock 'sub' that's an 8" and putting in a 10" or 12". Obviously reinforced deck and it would be hung on mdf that's not really attached to the deck. I'd open up the hole larger to the cabin too.
'13 Accord Sport (black): looking at options now
'04 TL (sold): RF BLD/ MS-8 / IDmax-Audison SR1dk / ID CXS62v2- ID Q450.4 / CLD,MLV,CCF
ousooner2 is offline   Reply With Quote Quick reply to this message
Old 10-26-2015   #21
I'm really not sure how it would perform IB.
Old 10-26-2015   #22
fourthmeal's Avatar
DIYMA Been here long time
Rep Power: 914 fourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond repute
Soft suspension and a HARD stop (meaning, you're going to hit hard parts against each other and possibly damage them) means DO NOT run these IB. Jacob explained this a few times, saying it was designed to be in a sealed box. Now think about this though, you could Build a box behind them in your trunk and it would be a small enclosure. Or you could port them if you tune very low in a fairly big box, and watch the Power levels. At least I modeled that and it looked very promising.
2017 Colorado just starting
Old 10-27-2015   #23
Rep Power: 94 aholland1198 will become famous soon enoughaholland1198 will become famous soon enoughaholland1198 will become famous soon enoughaholland1198 will become famous soon enoughaholland1198 will become famous soon enoughaholland1198 will become famous soon enough
You can IB just about any sub as long as you stay within its limits, no? Obviously a 10" running IB isn't going to get too loud, but with the proper subsonic filter and modest Power it should work in theory. However, this just the theory. Most guys are running 15" and 18" for a reason I assume.
aholland1198 is offline   Reply With Quote Quick reply to this message
Old 10-27-2015   #24
fourthmeal's Avatar
Yes you absolutely can, but you'll note that the limit happens really quick in this sub, in that configuration. Model it and draw out a box at least 3x the size of the Vas and you'll get in the ballpark. If you run an extremely modest output, cut the low end with a sharp filter, etc...you can get there but you have to ask yourself,....why do that? Plenty of other subs (some less expensive) would be happier in the role, including other Sundown subs.
Old 10-27-2015   #25
I completely agree, just playing devils advocate.
