JL 800/8 review - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-28-2016   #1
Hillbilly SQ's Avatar
iNCORRECT pOLITICALLY
Complacent Audio
Incoherent rambler
Rep Power: 245 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Default JL 800/8 review
One of my Mosconi One 120.4's has been showing its rear for months now and finally got fed up with it. It would work perfect and then out of nowhere go POP and then work fine for several more hours. Checked everything and tracked it down to the amp. I asked around and the clear winners for my needs were the Arc xdi and JL xd. I decided to pull both of my a/b 4ch amps out and replace them with a single 8ch amp. I still have one good 120.4 to use if the available Power from the 800/8 isn't enough, but after hearing what this little guy can do it has enough to get crazy loud without falling on its face.
I'm running a 3-way front plus a sealed 10" sub. Sensitivity for all my speakers is what I would consider "standard". All of them 4 ohm and sub is a d2. I'm sending 75x6 to the fronts and 200x1 to the sub. The sub is in a box laying in the rear passenger floor of my Ram and firing over the tranny hump towards the drivers side. This makes the sub the closest Speaker to me. I have the gain sensitivity set to "low" which tops out at 2v input with gains all the way down. My processor has 2v outputs so this works out perfect. It has settings to set it up just about any way you want. Read up on it if you haven't already. For those of you that think you need double the Power for midbass and double again for sub, THINK AGAIN. Yes some systems require you to send more to the sub and midbass but in my setup I had to pull the midbass level down a couple clicks with the processor and even more on the sub. I used to think you needed crazy amounts of power to cut down on noise and distortion but now I've seen for myself that as long as you have a QUALITY amp you can get by with something that's rated for less than 100rms per channel.
Compared to the Mosconi One 120.4's the JL seems to have better control of the speakers and is also making the little nuances in the music pop out and be noticed more. I was a diehard a/b guy but now I know that fullrange d tech has come far enough that amp topology simply doesn't matter anymore as long as you avoid the turds in the punch bowl. I've spent enough time with this amp to know that it's a step above the Mosconi amps which were more "gentle" if that makes any sense. Best way I can describe the difference between the One series and xd series is the One series was like a big cushy granny car. The JL xd amps are more like a nimble sports car. Both have their place and I love big cushy cars but for articulation the sports Car is where it's at. It's really cool being able to run the whole system with one amp. This 800/8 does a great job and don't see any benefit in throwing more power at my 7 speakers in my system that what it's giving them.
In closing I know I was all over the place in my review. I seem to do a lot better with answering questions than I do with giving speeches. I tend to ramble a lot when I'm not sure if I'm giving the info people are looking for. Big thanks to 1800collect for sending me a link to refurb JL amps from Creative Audio. I got an amp that retails at $699 for $489 shipped. And the way it looked and was packaged when I got it I would have thought it was brand new if I didn't know any better. Who knows, they might have sent me a brand new one for all I know. It came with a 90 day warranty through JL. I figure if an amp is gonna puke it's gonna do it in that 90 day period, but my luck it will be on day 91, lol. I think it will be OK though and if I get 3-4 good years out of it I'll be happy.
2014 Grand Cherokee Limited-bone stock "premium" 10 speaker system for now. In the works-JL Fix 82, c-dsp 6x8, JL XD800/8, Soundstream TN1200.1, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, ID15, SB Acoustics SB17NRXC35-4, Tang Band car tweeter
Old 08-28-2016   #2
Rep Power: 116 Bluenote will become famous soon enoughBluenote will become famous soon enoughBluenote will become famous soon enoughBluenote will become famous soon enoughBluenote will become famous soon enoughBluenote will become famous soon enoughBluenote will become famous soon enough
Default Re: JL 800/8 review
I was just looking at this model last nite! Thx for the review!
In my music, I'm trying to play the truth of what I am. The reason it's difficult is because I'm changing all the time.
- Charles Mingus
Bluenote is offline   Reply With Quote Quick reply to this message
Old 08-28-2016   #3
knever3's Avatar
Rep Power: 108 knever3 will become famous soon enoughknever3 will become famous soon enoughknever3 will become famous soon enoughknever3 will become famous soon enoughknever3 will become famous soon enoughknever3 will become famous soon enoughknever3 will become famous soon enough
$489 for an 8 channel quality amp, where were these when I was 16! Good Car audio isn't nearly as expensive compared to what was available in the early 90's. Heck, you could buy a Orion 225 HCCA 2 channel for or this for about the same money I would expect.
knever3 is offline   Reply With Quote Quick reply to this message
Old 08-28-2016   #4
Rep Power: 11 D34dl1fter will become famous soon enoughD34dl1fter will become famous soon enoughD34dl1fter will become famous soon enoughD34dl1fter will become famous soon enoughD34dl1fter will become famous soon enoughD34dl1fter will become famous soon enough
yeah man, I told ya!
when I listened to cooks smart Car with two of the xd's in there I was utterly blown away...as you stated I experienced similar thoughts to you....control...volume...and at a size and price point that was hard to believe...
D34dl1fter is offline   Reply With Quote Quick reply to this message
Old 08-28-2016   #5
MrGreen83's Avatar
Rep Power: 27 MrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enough
2 questions.
1) When u say D2...are u speaking of the Audiofrog subwoofer?
2) Which Arc XDi amp were u looking at?
MrGreen83 is offline   Reply With Quote Quick reply to this message
Old 08-29-2016   #6
Rep Power: 57 jode1967 will become famous soon enoughjode1967 will become famous soon enoughjode1967 will become famous soon enoughjode1967 will become famous soon enoughjode1967 will become famous soon enoughjode1967 will become famous soon enough
he means dual 2 ohm coils on the sub. and I believe he was looing at the xdi v2 amps. I have the xdi v1 amps and think they are ok as well
jode1967 is offline   Reply With Quote Quick reply to this message
Old 08-29-2016   #7
MrGreen83's Avatar
Gotcha.
Old 08-29-2016   #8
Complacent Audio
Incoherent rambler
Yup, Jon is correct since he's been in the loop this whole time. Sub is an Arc 10d2. Standard subwoofer that doesn't need a ton of juice to get the job done. I'm done with subs that have a big motor, heavy cone, can work in tiny box, and need its own nuclear reactor to be happyAs for the xdi amps the 1200.6 with a matching mono or 2ch amp for the sub would have been awesome but after running the 800/8 I just don't see any benefit in doubling up on Power for my needs. I had the Mosconi amps turned way down anyway to put the gain structure where I wanted it. In my install the 800/8 is just meant to be.
Old 08-29-2016   #9
my xdi v1 amps will move you when its on kill with the single alpine type r 12. Those mosconi are tempting- but would need more Power for the sub and the coil config isnt what they would like either.
Old 08-29-2016   #10
Complacent Audio
Incoherent rambler
If the Mosconi's aren't right for your needs they aren't right. For what I paid for the 800/8 it was worth a shot. It sure is a sweetheart.
