eDead V1SEČ - Be Careful - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-08-2008   #1
Approved Vendor
Sound Deadener Showdown
Rep Power: 188 Rudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond reputeRudeboy has a reputation beyond repute
Default eDead V1SEČ - Be Careful
More than a year ago I ordered pieces of Elemental Designs then new butyl adhesive eDeads - V1Č, V1SEČ and UE. At the time, the V1Č's adhesive demonstrated very poor performance and soon after, people started to report failures. V1SEČ and UE had adhesives that tested well. I didn't care for any of these products because the choice to substitute a much less expensive Mylar facing for the usual aluminum foil compromised the product's effectiveness in ways I won't go into here.
A couple of weeks ago, two posters on the Realm of Excursion forum independently reported failures with eDead V1SEČ. One went so far as to claim that the stuff wouldn't even stick to itself when pressed together, adhesive to adhesive. The same guy claimed that ED refused to do anything to make things right. Since he was stuck with most of a roll of a product he couldn't use, I asked him to send me a sample and he obliged. A few days later a package arrived containing several square feet of eDead V1SEČ in pristine condition. The physical dimensions matched the samples I bought more than a year ago.
The first thing I did was press two pieces together as described. Sure enough, it was very easy to peel them apart. Seemed very odd. The next thing I did was run my standard adhesion tests. I run one test as soon as the product is mounted on the testing surface and another after a second sample has been mounted for 96 hours. Good quality butyl adhesive creates an increasingly strong bond with time, so this is information worth having. Since some butyl adhesives are activated by heat, I attached two more samples and heated them. The adhesive bond strength results were really poor, but the stuff was at least sticky to the touch so I figured something else must be going on. The heated samples did no better than those held at room temperature.
Since it was 97°F here today, I decided to mount some test strips to the sheet metal I use for heat testing and just set it outside for the day to see what happened. Here's the starting sample sheet:
I mounted samples of the year old V1SEČ, the V1SEČ I had just received and samples of Dynamat Xtreme as a control. I mounted a single strip and two strips stacked for each product. I angled the sheet metal mounting surface approximately 20° forward of vertical. The samples were mounted to meticulously clean metal and careful gone over with a roller.
I put it outside, on my deck, and positioned it so that the sun only hit the back of the sheet metal. The samples were never in direct sunlight. I left the samples there from 9:00 AM until 5:00 PM. I checked the temperature of the substrate and the samples every 1/2 hour. The highest temperature I ever recorded was 120°F.
120°F is nothing for a car sitting in the sun. A light colored car can easily reach 160°F and darker cars will get to 180°F. These are temperatures inside the doors, at the roof, etc. - all of the places sound deadener lives. 120°F should be a walk in the park.
At 5:00, I found this:
The new V1SEČ samples are number 4 and 5 from the left, labeled 6-1-2009. It's a little hard to see here, but there is significant separation on the lower 2/3 of each sample. The older V1SE showed very slight separation at the very bottom and the Dynamat Xtreme looked exactly as it did when first applied.
These details show the damage more clearly:
This is ridiculous. The adhesive formula has been changed. This stuff is guaranteed to fail. If these results hadn't been as conclusive as they were, I would have tried a curved substrate. Since it wouldn't even stick to a perfectly flat surface, that seems pointless. What I did was less taxing than a single day when installed in a car that's parked in the sun.
Using absolutely rudimentary tests, I could tell in 10 minutes that this adhesive was completely different than what I had tested a little over a year ago. This suggests, to me. that ED does absolutely no quality control before shipping. The guy who sent me the samples says that ED told him they couldn't help him because he wasn't a professional installer. It's hard to imagine how that would make any difference at all. Between the two guys reporting failures, 3 rolls were involved.
Sorry for the wordy and detailed descriptions. I've found that if I don't start that way, I end up having to provide it all later.
Old 06-08-2008   #2
captainobvious's Avatar
more SQ
Rep Power: 194 captainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of lightcaptainobvious is a glorious beacon of light
Default Re: eDead V1SEČ - Be Careful
That sucks. Guess I'll make sure I dont buy there product than seeing as how it fails, AND they dont replace it with a working solution.
Old 06-08-2008   #3
unpredictableacts's Avatar
The Anti-Rice
Rep Power: 158 unpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enough
If they are indeed avoiding taking responsibility for the problem that does not sit good with me. Honestly anyone can sell any item, but it takes a real business minded company to back that product once it leaves its showroom/warehouse/garage.
unpredictableacts is offline   Reply With Quote Quick reply to this message
Old 06-08-2008   #4
Approved Vendor
I can't vouch for his claim, just reporting what he told me. I started a thread in the General section asking if anyone else has had experiences with this product and ED's response to it. Nobody ever reported back about what, if anything, ED did about the failed V1Č.
Old 06-08-2008   #5
The Anti-Rice
Understandable....not usre why being a dealer/installer has anything to do with a failing adhesive?
Old 06-08-2008   #6
ehiunno's Avatar
Rep Power: 116 ehiunno will become famous soon enoughehiunno will become famous soon enoughehiunno will become famous soon enoughehiunno will become famous soon enoughehiunno will become famous soon enoughehiunno will become famous soon enough
Send a message via AIM to ehiunno
I'll be taking off the rear deck where I put some v1SE in a few days and I'll report back with the results. This is certainly unsettling. We'll see how it does in another unbiased install.
It certainly seems like it doesn't matter how cheap their stuff is, its not worth it to buy from a company with the kind of customer service ED has...
ehiunno is offline   Reply With Quote Quick reply to this message
Old 06-08-2008   #7
ClinesSelect's Avatar
Rep Power: 145 ClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enough
Wonderful. I have about 40 sq ft that I received in a trade. Fortunately it does not get very warm here so it should be fine to use.
ClinesSelect is offline   Reply With Quote Quick reply to this message
Old 06-08-2008   #8
Rep Power: 143 mikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura aboutmikey7182 has a spectacular aura about
It only hit 101* today... not too bad! I used this crap in my Ford last year and then pulled the door panels off 2 months later to swap out components and it was peeling at the edges and several smaller pieces had actually fallen all the way off. Sorry Dave- I shoulda told ya!
P99---JBL 2408H-2/ID minis---PHL 1120---Ciare NDC10-2.5---SI HT18---Gladen XL250c4 (x2)
mikey7182 is offline   Reply With Quote Quick reply to this message
Old 06-09-2008   #9
Electrodynamic's Avatar
Approved Vendor
Stereo Integrity
Rep Power: 138 Electrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enough
Wow. Thanks for the write up and pictures. Thankfully I've done most of my car in Second Skin. *whew*
Electrodynamic is online now   Reply With Quote Quick reply to this message
Old 06-09-2008   #10
Boostedrex's Avatar
DIYMA Sneetch
Rep Power: 174 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
That's just terrible! For a company that sells decent amps and subs, the rest of their product line sure is lacking! And the fact that they're coming up with BS excuses to not cover product problems is unacceptable. I hope that someone from eD will chime in on this thread as I for one would LOVE to hear what being a pro installer has anything to do with the adhesive on sound deadener failing/not working at all.
Boostedrex is offline   Reply With Quote Quick reply to this message
Old 06-09-2008   #11
Rep Power: 112 ianbiz will become famous soon enoughianbiz will become famous soon enoughianbiz will become famous soon enoughianbiz will become famous soon enoughianbiz will become famous soon enoughianbiz will become famous soon enough
Send a message via AIM to ianbiz
Someone needs to post this one their forums and see how fast the thread disappears or if eD will give an explanation.
Mint JL 300/4 for sale. PM me
ianbiz is offline   Reply With Quote Quick reply to this message
Old 06-09-2008   #12
Approved Vendor
Since we were "lucky" enough to have another near 100°F day, I thought I'd give the samples another day to see if the problem got worse. I thought it might be possible that the damage I recorded before might have reached some sort of equilibrium. Nope - got worse.
After another 8 hours, the separation is worse and now runs all the way along each side of each sample. No change for the old V1SEČ and Dynamat Xtreme.
Old 06-09-2008   #13
Boostedrex's Avatar
DIYMA Sneetch
The thread would get deleted and your username/IP address would get banned from ICIX in less than 10-15 minutes if you were to post that up over there. eD could be a good company if they would actually sell what they advertise and if they would back up the products that they do sell. Such a shame.
Team Stereo Integrity member
Old 06-09-2008   #14
ANT
ANT's Avatar
Rep Power: 370 ANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond repute
I have no quams with anyone from ed signing up to our forum.
They are welcome here just as anyone else is.
Perhaps they should be invited.
I for one won't sign up to their forum. Don't think I would last very long, but if anyone else wishes to invite an ed rep here I am fine with it. (No spamming or trolling on behalf of DIYMA please)
ANT
ANT is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #15
Rep Power: 114 What? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enough
I thought all sound deadening products were exactly the same, just like the home depot roofing material. Hmmm...
What? is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #16
jonnyanalog's Avatar
Rep Power: 124 jonnyanalog will become famous soon enoughjonnyanalog will become famous soon enoughjonnyanalog will become famous soon enoughjonnyanalog will become famous soon enoughjonnyanalog will become famous soon enoughjonnyanalog will become famous soon enough
i have some v1SE and its begun to peel off of my rear deck. It has been hot here in TX and the stuff is mounted upside down.... but I'm a bit surprised by this. Some could be installer error as i did not use any tools to put it down with. But come to think of it niether did my friend who used dynamat extreme in his doors and they have no issues with adhesion.... hmmm.
we'll see how it holds up over summer.
jonnyanalog is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #17
i will be using dynamat etreme in my dooes when it comes time to install....
Old 06-10-2008   #18
hibuhibu's Avatar
Rep Power: 134 hibuhibu will become famous soon enoughhibuhibu will become famous soon enoughhibuhibu will become famous soon enoughhibuhibu will become famous soon enoughhibuhibu will become famous soon enoughhibuhibu will become famous soon enough
Send a message via AIM to hibuhibu
Mine fell off miserably when I used them last time.
Never will I use them.
Mazda CX-7
AVN2210P, RF 360.2, Cerwin Vega EXL400.4, Premier TS-C720PRS Component, Alpine MRP-M850, Diamond HEX Shallow
hibuhibu is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #19
simplicityinsound's Avatar
Diyma Ninja
Simplicity In Sound
owner
Rep Power: 183 simplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nicesimplicityinsound is just really nice
hey Don,
see if you can get a chance to try out some V1UE, i am curious as well as how well it fairs against the Se, i myself have not used an ounce of Se for umm two years? whenever the UE came out, i switched over completely...and like i have said, i have yet to see any major failures using the stuff...
i heosntly have no reason to stay wtih Edead if it starts to fail but i honetsly havent seen it, juts to give you an example, when i ripped out my old system, my spare tire well, which was dmapened with a combination of V3 liquid, V1se (long time ago) and UE (about 1.5 years ago), looked like hte picture below, this is just pulling it out, and as you can see, i dont see much of it coming unglued? and only the floor portion was pinched against the subbox, the rest was just open, so if it wanted to come off, it could, and over the last two years, we certainly had 110 degree weather for prolonged periods of time..
just curious thats all
2012-2013 Mobile Electronics Magazine Top 100 Installer
Facebook
Website
Yelp
simplicityinsound is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #20
Approved Vendor
Originally Posted by simplicityinsound View Post
hey Don,
If anybody wants to send me an 8" square of recently purchased UE or V1Č, I'd be happy to test it and compare the results to the tests I did last year. PM me for my address.
The problem with the V1Č was immediately obvious - the adhesive bond strength was extremely weak and the Mylar facing had a very strong intrinsic curl. Oddly the v1Č Mylar was 3.5 mils thick vs the V1SEČ's 1.5 mils. With the adhesive removed, a 1" square piece of V1Č' Mylar curled up to the thickness of a toothpick. The V1SEČ curled up to the thickness of a drinking straw. The UE used a 4.5 mil Mylar with less curl than either of the other two. Since the V1SE's adhesive formula has apparently changed, I guess it is possible that UE is different now too.
Old 06-10-2008   #21
Approved Vendor
One more note on the Mylar vs. aluminum foil debate. Everything I've seen convinces me that that foil is superior - both in terms of vibration damping and the ability of the product to act as a barrier. These features are difficult to quantify. There can be no doubt that foil and Mylar behave differently in use. Foil deforms to the contours of the underlying surface to which it is applied. Once it's installed, foil doesn't fight to resume it's original shape.
If you want to use liquid and mat, aluminum foil is again the better choice. The logical way to combine these products is to apply the mat and then apply the liquid on top of it. The liquid will reinforce the constraining layer - improving that response. It also lets you apply the butyl adhesive, which is impervious to moisture, directly to the sheet metal instead of to the porous surface of the cured liquid. If you haven't let the liquid cure completely (takes up to 30 days), you risk trapping moisture between the mat and the substrate.
ED actually recommends applying liquid and then mat on top of it. I can not find a single supporting reason to do this. The problem is that liquid doesn't adhere to plastic very well. eDead is faced with Mylar (plastic). A shortcoming of the product requires you to follow their procedure. There's no advantage for the user.
Old 06-10-2008   #22
Aaron Clinton's Avatar
Supporting Vendor - SSA
Sound Solutions Audio Inc.
Co-Owner
Rep Power: 149 Aaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really nice
ANT
I have been talking with an eD rep over on CA.com via PM and he has been very cool to me. He said there has not been a thread that has been edited or deleted in a long time from ICIX.
Aaron Clinton is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #23
spl152db's Avatar
Rep Power: 128 spl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enoughspl152db will become famous soon enough
i still need to send you samples of the stuff i have. I can't remember which i bought. i'll check online brb. i have v1^2 not the se. i'll send samples to test.
spl152db is offline   Reply With Quote Quick reply to this message
Old 06-10-2008   #24
Bikinpunk
Rep Power: 25980 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
Made it to ICIX...
http://www.icixsound.com/vb/showthre...651#post517651
Follow my blog:
http://medleysmusings.com/
Time Delay Calculator:
My 2006 Honda Civic LX Sedan Build Log
Old 06-10-2008   #25
ItalynStylion's Avatar
Stereo Clarity
Rep Power: 136 ItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enough
I talked with an ED rep via their online chat tool on their site before lunch. He said that they test the mat in temperatures up to 900 degrees with a heat gun and haven't had any problems like the ones in this post.
I'm not for or against this product. I've only used second skin stuff and have had nothing but great results so I have no reason to switch.
ItalynStylion is offline   Reply With Quote Quick reply to this message
eDead v1Č Failures Rudeboy Technical & Advanced Car Audio Discussion 51 06-10-2008 04:16 PM
What can I do with my semi worthless edead? 89grand Technical & Advanced Car Audio Discussion 20 01-30-2008 12:14 PM
eDead v1 any good??? transaman98 Technical & Advanced Car Audio Discussion 31 09-06-2007 08:16 PM
Quick question on eDead HondAudio Technical & Advanced Car Audio Discussion 10 06-15-2007 10:19 PM
Got a car warranty? Be careful. MarkZ Off Topic 14 11-16-2006 04:24 PM
