#226 |
Now I see what you guys mean.
#227 | |
![]() They are the only setups I've actually been pleased with in cars. My rant was more about Bose than anything else.
Pioneer PREMIER Zed/Arc/Diamond ~ Seas\Peerless\DIYMA12
#228 | |
#229 |
Solder melts at around 190 degrees Centigrade, and the bit reaches a temperature of over 250 degrees Centigrade.
It takes 200-degrees for copper to double resistance which would be 3db power compression. It takes 190-degrees to melt solder. At what point am I to be embarassed now? |
#230 |
Proof:
Power compression question - CARSOUND.COM Forum Power compression comes from heating the voice coil. As you heat metals, the resistance of the metal increases. Heat copper by 200 deg C, and you double the resistance of the copper. That means you just doubled the DCR of your woofer, which will cause a 3 dB loss in output. Dan Wiggins Adire Audio --------------------------------------- Hi tspence, I'm sorry for the delay. I was waiting on a reply from one of our engineers. According to our engineers, we do not test for power compression in our full range component systems or the coaxial type speakers. Testing has found the effects to be negligible when listening to music at the speaker's rated power or lower. The result of serious power compression caused by excessive heat would cause the speakers to fail. Sincerely, James Pagano Internet Support Specialist Harman Consumer Group Woodbury, NY How much more proof do you want? I'm sure I can find more if you want it. I'm sure you "know what you guys mean" now, huh? You shouldn't just trust what others tell you without links and proof like I'm posting here. If you disagree with me, then you disagree with the sources of the info I'm posting. |
#231 | |
#232 |
It's magic!. I've also seen it happen on my pots and pans. Those babies get scorching hot but the rubber handle on them never melts. Spooky physics!
#233 | |
#234 | |
#235 |
#236 |
#237 |
When I know everything then I'll stop asking for advice. I'm not the most knowledgable person but I try to apply what I know the best I can. I take advice, think about it and apply it as I think I should. Only here does it seem to be wrong to ask I suppose. So sue me for not taking every piece of advice offered. I'm thankful for what people want to share and some of this info has been good to add to what I'm trying to accomplish. Some of it is optional.
#238 |
#239 | |
#240 | |
#241 |
Sound Deadener Showdown Position:
Owner iTrader: (0) |
#242 |
The heat will escape to its surrounding or the wire will burn up well before it can transfer to the terminal. Pots and Pans!
#243 | |
Only speakers playing outside their RMS ratings have power compression. Okay if you say so. Seriously, if you don't what you're talking about (which is almost always), then don't say anything. Audio and Loudspeaker Design Guide Lines http://www.soundonsound.com/sos/Jul0.../monitors2.asp Feel the magnet or the cone the next time you've been blasting the system and tell me the VCs aren't reaching well over 120 degrees. |
#244 |
#245 |
In other words, if your coil stays too long at a temperature of 200 degrees celcius, bye bye voice coil. 200-degrees = 3db of power compression. Most speakers will not be a 200-degrees at any time and if it is, it's reaching the thermal limits of the voice coil or it's surrounding components. Hence, it's unlikely my subs are reaching anywhere near 200-degrees celcius with an average of 300-400 watts spread amongst 4 voice coils. Therefore the power compression, if any, is likely less than 1db of loss, hence INAUDIBLE. That was my point. Power compression in my subwoofers at my current settings are not going to be an issue. The argument on that point should be closed now.
#246 | |
I'm not minimizing the impact. I'm pointing out that Tspence is calling other people stupid, then goes on to make an inaccurate statement and has now followed it up with another inaccurate statement. Technically even 1 db has some impact. FYI, I believe it's 10db = "twice" as loud. |
#247 |
#248 |
#249 | |
#250 | |
| another alt whine problem | Mat Dope | DIYMA SQ forum - Technical & Advanced | 7 | 04-01-2007 03:00 PM |
| alternator whine with HU powered off | ronp | DIYMA SQ forum - Technical & Advanced | 8 | 03-22-2007 11:56 AM |
| check my calculations | legend94 | DIYMA SQ forum - Technical & Advanced | 5 | 01-20-2007 01:52 AM |
| Troubleshooting noise... What's next? | rbenz27 | DIYMA SQ forum - Technical & Advanced | 11 | 04-08-2006 08:52 PM |
| Help out a hottie! Check Summer out! | xencloud | Off Topic | 8 | 02-15-2006 06:59 PM |
